Richard (Rick) Drennan Global HVAC Distributors RUUD Field Support Representative / Instructor rdrennan@globalhvac.com 900 Spreckels Ave Manteca, Ca. 95336 Office (877)448-7263 Cell (209)456-0513
is it a heat pump? if not the a/c is not relavent,how are we providing heat? electric resistance? air to air or geothermal heat pump? Natural Gas or LP gas? hot water or steam? forced air or radiant?
HI, I have a ruud UBHC AC system, a couple yrs ago i replaced the old honeywell stat with a shiny...
(More)
HI, I have a ruud UBHC AC system, a couple yrs ago i replaced the old honeywell stat with a shiny new ritetemp,(which i was told would work) but now that it finally got chilly here in Florida i'm finding that may not be the case .. Wires coming from my old Honeywell were H(blue 24v from one side of transfomer in the heat exchager) W(white) Y(yellow) G(green) and R(red 24v from the other side of the transformer in the exchanger) I wired to the ritetemp as following g to g .. w to w .. y to y... r to RH/RC and H to C which was as per the manual.. when i turn on my AC to Heat the heat pump seems to run but i get no Aux heat so inside the ritetemp stat theres jumper to kick in AUX only heat (no heatpump) so i jumpered that.. NO aux heat .. the fan runs but no heat, i went inside the exchanger and no mattter how i configure this i cannot get 240v onto the heater element. The reason i need the aux heat is it seems that the heat pump is not working properly and it needs the extra push.. it only gets to 60degrees before settling there and providing no more heat.
solid green led followed by flashing green led which flashes five times before resetting, followed...
(More)
solid green led followed by flashing green led which flashes five times before resetting, followed by a solid red led
I am installing a used heat pump into my exsisting gas furnace. All have left to do before charging...
(More)
I am installing a used heat pump into my exsisting gas furnace. All have left to do before charging is wire up the low voltage for the heat pump. I can't seem to find out where the wires go from the heat pump. It has 4 wires: Brown
Hello.. slight problem. Rudd silouette II a/c gas furnace. Fan runs on low speed, and will not shut...
(More)
Hello.. slight problem. Rudd silouette II a/c gas furnace. Fan runs on low speed, and will not shut off. a/c comes on, and get cold, but blows on low. seem like the switch is switched to on, instead of auto.. CVould this be control board? Thanks
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
