How can i get the normal keyboard to work without having to use the function key to type some of the letters?
  • lillylion Dec 03, 2008
    Thanks!!!!!!!!! typing is much easier and quicker now :)
  • 53 Answers
You either have scroll lock or num lock off, try pressing these to turn them off.
Posted on Dec 03, 2008
  • Emma J
    Emma J Dec 03, 2008
    Good glad I could help
How i can enble function key
HP laptops have the ability to lock the blue special function keys on, making numerical data entry easier on laptop models that do not have the room for dedicated numerical keypads. Because the key combination to lock the function keys is so simple, however, it is easy for those who wouldn't normally use this ability to do so accidentally. When the function keys are locked, pressing certain keys will result in numbers being typed rather than letters. Unlock the function keys to alleviate this issue.
Press the "Fn" and "Num Lk" keys on the keyboard simultaneously. The "Number Lock" indicator light should turn off, indicating that the letter keys will once again type letters when pressed. This combination should work on the majority of recent HP laptops. If it does not, try one of the alternate key combinations in this article's remaining steps. Press the "Fn" and "F11" keys simultaneously, then attempt to type a letter. If the combination does not work, continue to the next step. Press the "Fn" and "Scroll Lock" keys simultaneously, then attempt to type a letter. Continue to the next step if this does not work. Press the "Fn," "Scroll Lock" and "F11" keys simultaneously.
Jan 16, 2013 | HP 4440s Probook
What is function of letters into key board
The function of letters into the keyboard is to type the specific letters and do what are the commands given to the computers.
Because if the letters on the keyboard without its functions, it is useless.
Jul 19, 2011 | Acer NSK8458AN Keyboard
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
I own an HP 510 laptop, when i type the function symbol on the right side of the keyboard is displayed for eg if I want an L 3 is typed, O is 6 etc. To eliminate this I must press the FN key to get the...
You have the Num Lock on.
To turn it off just hit the Num Lock key or press Fn and hit the Num Lock key to return the keyboard to normal.
Jun 28, 2010 | HP 510 Notebook
My dell laptop types numbers instead of letters on some keys without pressing fn key
If you Are writing numbers instead of letters when you press the keyboard of your laptop and you must hold down the Function key (Fn) to write normally.
This is due to the fact that the digital lock is activated. To solve this, simply press the Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
Hope This Helps
Feb 27, 2010 | Dell Vostro 1510 Laptop
When I type letter keys, numbers come up with the letters
check your keyboard: T and 5 are relatively close to each other. Try to clean the area under keyboard buttons especially these two buttons. may be it can help you.
Sep 07, 2009 | Toshiba Satellite A105 Notebook
Locked keyboard buttons
You need to find the special function key that, when used with the Fn key, locks the Fn function on. On my keyboard it's the F11 key.
Press the Fn key and that key and your keyboard will return to normal.
Apr 20, 2009 | HP DC170B Keyboard
NC10: Can't type without holding function key down
I set up my girlfriends this morning, to turn off Num Lock, you need to have the machine on and select Fn + F11.
That'll turn it off and you'll have the bliss of typing normally again!!
Jan 06, 2009 | Samsung NC10-14GW Notebook
Keyboard probs advent 9115 laptop
Sounds like your num lock has been toggled on by mistake. Look for a key that says NmLK. It will be in the same color blue. That key may also be the scroll lock key(ScrLk) that should solve your problem.
Apr 23, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
