Question about Xerox CopyCentre C20 Black and White Copier
Our company has a Xerox C20. Pages keep printing out with white streaks in them. The ink cartridge has been recently changed, and I cleaned the drum cartridge. What should I do stop the white streaks from printing?
    Problem Solver:
  • 7 Answers
Well Jennifer it sounds like it might be the corona wires have a buildup of toner or developer on them.. remove the slide in corona wire housing, and using the eraser end of a pencil lightly slide the eraser on the lenght of the wire blow on the wire to clear away cleaned particles and carefully replace housing back in machine. the crona wires charge the drum so an image can be made on the drum if toner or developer clumps on wire where ever that happens... the drum does not charge and will not pick up in that area of image leaving a white streak. another concideration is moisture in the paper leaving white blotches
Posted on Dec 22, 2008
    President:
  • 2,072 Answers
It could be a couple of things. Either the scanner or the laser. We can eliminate the scanner by you printing out a report. Either the meter read report or system data. If the reports print with out the white lines, you have eliminated the laser. If the lines are on the report, then the problem is in the laser.
Now, to clean both.
1. To remove and clean the laser, you first want to shut down and unplug the machine. On the left side, ( the side with the on off switch) you will see 2 screws in the cover. You want to remove those screws, pull the paper tray out slightly and then lift slightly up and pull on the cover, It has these tabs on it that make it tight to remove. But don't be afraid to pull, it will release and you may think you broke something, but you didint .... Now you look in about 10 inches you will see a black box with a some red wires running to it. That is the laser. You will need a stubby magnetic phillips screw driver to remove it. There are 3 screws holding it in place. On in back and two on the front sides. Remove those screws and then disconnect the 2 connectors to the laser and remove the unit. Then place it on a table, there are zero screws holding the laser cover on, Just about 5 or 6 tabs that you have to release with a screwdriver and the cover will pop off. Clean all the lenses and mirrors with a soft damp cloth, and be sure not to leave any dust on those mirrors or lenses. You will also see a silver 7 sides mirror array on a motor. Clean the front of those mirrors. They are the front curved surfaces on that rotating assembly. Clean them well. Then snap the cover back on and reinstall the laser. DO NOT remove any of the laser lenses or mirrors. Just be sure they are dust free.
Now, if you need to remocve and clean the scanner.
Open the door where you install the toner/drum. Above the cartridges you will see 2 phillips screws. You have to remove those. Then on the back of the machine, you need to remove the rear cover, ( 6 screws) then there are 3 screws under the lip of the scanner that have to be removed. ( Oh yea, I forgot, take the document feeder off first, unscrew the connector and lift the feeder off). Once you remove those screws. locate the processor board on the right side, on the top of that there is a plug with red wires from the scanner conected to the board, and then there is a white ribbon cable, remove it, and a green ground wire screwed to the metal bracket. Remove that also. Pull the scanner back and up to remove.
Once you have the scanner removed, flip it upside down. You will have to remove the 3 screws on the front bottom side and remove the consol, then unplug the consol and set asside.
Then there are 5 or 6 screws that hold the glass and bottom part of the scanner together. Remove those screws and flex the scanner cover out on the sides to release a couple of plastic tabs holding hte scanner together. Then clean the bottom of the glass. Set the bottom of the scanner upright and you will see the scanner head, the black box like item with the lamps. You have to very carefully release upper portion of the scan head with the lamps from the bottom portion to access the mirrors. Use a small screw driver to release the tabs. I caution you not to be forceful or you can slip the screwdriver to far in and brean a mirror. Once again clean ALL the mirrors and the small lens.leave no dust on the mirrors. Then carefully reassamble the scanner and machine.
Once you clean that you must then do a shading adjustment. ( Calabrating the scanner).
Once the machine returns to ready, press the keys in this order. Menu,#,1934. YOu should then see a " T " on the screen. You are in the tech mode. Press your machine status button, then scroll to maintenance, then scroll to adhust shading or just shading.
Place 5 pieces of white paper on the glass, press start, when it asks you if you want to adjust shading press start again. Then shut the machine off and back on.
Should fix it by cleaning the scanner or laser.
Posted on Dec 03, 2008
A 1/4 inch stripe of magenta ink runs down the side of all pages printed.
Hi ,
Dirty print out is mostly due to cartridge related issues. In this case it seems that magenta is the issue. Take out the cartridge and clean its drum/ (green roller) with a dry, soft, lint-free cloth. The drum is located under a cover. Checkout for any spilled toner inside the printer and clean it also. Print a few pages so that the parts get further cleaned. I think, this would solve the issue.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located just behind the green drum inside the cartridge. Try cleaning it or replacing the Magenta Cartridge. If required, get the PCR Roller changed by a professional.
Let me know if any further clarification is required.
Hope it helps! Good Luck!
CreativeTECH
Mar 03, 2011 | Brother MFC9450CDN Colour Laser MFC...
I have black streaks on my 1600n prints. I have tried cleaning the drum, however the streaks still exist.
Dirty print out is basically due to cartridge related issues. Take out the cartridge and clean its drum/ (green roller) with a dry, soft, lint-free cloth. The drum is usually located under a cover. Checkout for any spilled toner inside the printer and clean it also. Print a few pages so that the parts get further cleaned. I think, this would solve the issue.
Moreover, black streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Cartridge or get the PCR Roller changed by a professional.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Feb 06, 2011 | Dell 1600n All-In-One Laser Printer
Xerox Phaser 8560, produces cyan colored streaks whenever this ink is used. No other colors produce streaks.
You are probably using "Media Sciences" ink sticks (Non-Xerox).
This means the printheads jets are clogged, and the printhead needs replacing.
Media Sciences released a defective lot of cyan ink sticks.
They are currently replacing printheads (at their cost) if you call them.
Aug 12, 2009 | Xerox Phaser 8560DN Laser Printer
Black Prints
The toner might be bad, because the old cartridge is working fine.
Jul 31, 2009 | Xerox DocuPrint P12 Laser Printer
Xerox CopyCentre prints out faint copies. DIrty?
You have a dirty laser, I will tell you how to clean it when I am awake.
Mar 20, 2009 | Xerox CopyCentre C20 Black and White...
Streaks in prints
What I would do is remove all cartridges, wipe the belt w/clean cloth use an air can to clean the machine, check the drum on each cartridge see if there is something, it could be there was a change in Voltage and it burnt the drums. change 1 more toner cartridge to see if that color goes away, if it does then you will know if the drums are the problems.
I've had a problem w gen toners doing the exact same thing, so I had to OEM and it went away. Good luck>
Feb 02, 2009 | Xerox WorkCentre M-24 Color Copier
Brother HL2070N printed 1 page fine,then nothing but light streak
turn off printer, remove cartridge and drum and clean internally.
reinstall drum and cartridge and do a test print, hopefully all will be better.
Jan 18, 2009 | Brother HL-2070N Laser Printer
Streaks on left side
REPLACE DRUM CARTRIDGE THE CLEANER BLADE IS BAD
Jan 20, 2008 | Dell 3100cn Laser Printer
Xerox CopyCentre C20 Black and White Copier Logo
148 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
