Question about Braun Tassimo Espresso Machine/Coffee Maker
Leaky Tassemo coffee maker
I have a Tassemo coffee maker which i purchased because the Melita coffee maker i had was a leaking mess, WELL guess what when I brew coffee, cappucino or espresso in my new Tassemo maker, it spills more water in the base than in the cup HELP
How do you insert the water filter in the tassimo water reservoir?
Posted on Dec 01, 2009
All you have to do is push the filter down into the base of the water caraf. You have to be careful as there are now 2 different types of filters being sold. The Bosch filters will not fit into the Braun machines and vice versa. The only local store to me that sells the filters is Bed Bath and Beyond and they have stopped carrying the Braun filters. The only place I have been able to find them is on the Tassimo website. Good luck!
Posted on Dec 19, 2009
I think it's supposed to do that. the cup at the base is supposed to be catching all the water that the tassimo is 'leaking'. it should be dumped after every cup of tea/coffee. if you have taller cups, and do not use the cup base that comes with the machine in order to fit the taller cups under where the tea/coffee comes out, then you are right. it seems like it's 'leaking' because it is. there should be enough room in the base for one cup, but then it can also be removed so as to dump the excess water out after the cup is made. hope this helps!
Posted on May 27, 2007
SOURCE:
Is the Kurig coffee pot dangerous
It is not any more dangerous than any other coffee maker. Every coffee maker needs to be kept clean and descaled regularly to keep them safe. If you want to be "squeaky clean" use something like a one cup at a time drip coffee maker (Melita) and always use boiling water.
Nov 23, 2014 | Coffee Makers & Espresso Machines
Leaky Keurig B70
Return for replacement. Factory problem. Many have experience this condition.
Feb 10, 2012 | Keurig Platinum B70 Coffee Maker
Our coffee maker leaks out of the bottom of the unit when we make coffee. Only when we make coffee.
id guess the silicone gasket between pan and tank is leaking or you have scale blockage athe outlet to the sprayhead (clean with bunn spring) or directly at where the pan connects to the tank(poke it with a screwdriver or somthing.
Sep 01, 2011 | Bunn NHB Coffee Maker
Need to replace my spigot on my 30 cup revere ware coffee maker because it leaks. Where can I get one to "pop" into that hole so I can pour the coffee out of the pot into the cups.
I have a Westbend 24 cup coffee urn with a leaky faucet. I tried finding areplacement spigot for it but so far no luck. My spigot has a screw in the top that allow for disassembly. It looks to me that if I could get a replacement rubber O-ring I could fix it myself. Does anyone know where I could get this?
Thanks
Kelvin
kelvinlov@gmail.com
Sep 16, 2010 | West Bend (59055) Stainless steel 60-Cup...
Water leaks
unds like there is a leak in the tank. Take it back for a refund/exchange.
Jun 12, 2009 | Black & Decker TCM700 Coffee Maker
Leaking coffee maker
Unfortunately there are many reviews for your coffee maker that are negative as far as leaking is concerned.
Most have had leaking problems about 6 months after purchasing this machine.
I don't know what to say, but you may have to bring or send it back and get another one. Maybe a different brand?
May 08, 2008 | Waring Pro WC1000 Coffee Maker
Grinding Coffee Beans
You go my interest (I gind my own as well but not with a **** ginder), read THIS set of forum posts and maybe try some of the ideas there. Most sites I read said that it goes away with time and usage, but could take as long as a year! WOW.
Enjoy,
Geno
Apr 03, 2008 | Coffee Makers & Espresso Machines
LEAKING WATER
I had the same with a Saeco it was caused by a leaky boiler, after replacement, it was fine...
Aug 08, 2006 | Waring Pro WC1000 Coffee Maker
Braun Tassimo Espresso Machine/Coffee Maker Logo
2,578 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Norman Al-Anbar
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
