Mitsubishi WD-52525 52 in. Rear Projection - no picture lamp light goes red
I have sound but no picture and the lamp light goes red after a power up. I tried a new lamp but it still doesn not work.
The lamp connector did comes loose from the lamp hosuing and I did fix that so the lamp now is making connection. but it still has the same problem. Today I cehcked the voltage with a DVM by cheated the front cover interlock and doing a power up. The meter read 60.5 volys AC.
Do you know if there is a common problem with these sets have a pwoer problem to the lamp?
Any help is appreciated.
Thanks.
my personal email is larryditizio55@aol.com
I have a Mitsubishi WD-52525 52 in. Rear Projection HDTV
  • Larry DiTizio Dec 06, 2008
    thanks. this is very helpfull. I placed an order for the repair kit. I do hope this fixes the problem, but will not know until I recieve the kit and get some time to do the repair. I will let you know the outcome of the repair.
  • seattlemlee Dec 16, 2008
    I have a similar problem. I installed the new lamp with no sound, no picture and yellow lamp light that turns to red. No status light either. Can anyone help?
    michaellee@windermere.com
  • 8,617 Answers
Yes the capacitors go bad on the power pwb . You can get the V26 Power PWB repair kit at the following link which has the replacement capacitors and instructions. Heres the link its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Posted on Dec 03, 2008
I have a mitsubishi wd-65736 no picture just sound
do you have a red lamp light on, if so you need to replace the lamp
Nov 28, 2010 | Mitsubishi WD-62525 62" Rear Projection...
I have a Mitsubishi TV Model# wd-62528, the red light comes on on the lamp light
Need to replace a new lamp. Or if you still see picture, go to menue and reset lamp. I f no picture, need to replace a lamp.
May 09, 2010 | Mitsubishi WD-62525 62" Rear Projection...
WE HAVE SOUND BUT NO PICTURE.. RED LIGHT IS ON
YOUR LAMP IS MOST LIKELY OUT PULL IT OUT AND SEE IF IT IS SHATTERED.
Oct 07, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD 62927 not turning, no picture...
It sounds as if you have the lamp unit out. Had the same problem myself. Sorry.....
Aug 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Picture went out completely flashing red status light 4 flashes pause constant
Most likely the lamp is burnt out (indicator goes to constant red status). Replace lamp (get lamp P/N from User Manual for replacement), clean any dirt around lamp, fan, and rear filter. Do NOT get any fingerprints on new lamp.
Aug 11, 2009 | Mitsubishi WD-62825 62" Rear Projection...
WD-52525
You have a bad DM Board. You need to replace it. Changing the capacitors will not cure the problem. Completely replace the entire board
May 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD 52525
HELLO . IT SOUND'S LIKE YOU NEED TO REPLACE THE BALLEST .!! AND THAT SHOULD FIX IT.!!! "GOOD LUCK"
Aug 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525-Code 34-Sound OK-No picture!
I had another problem kinda the same and emailed ctechnicians.com and they gave the fix.
Nov 02, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Open Questions:
I have horizontal white lines across the display of my LCD Tv, I've included more info in the details section below I have an Insignia model# NS-46L780A12 LCD TV MFG date July, 2011 , recently the display has been acting very strangely because the issue comes and goes consistently dependent to whether or not there's caption writing on the screen - examples being programming information , channel , time etc.....these info blocks are each in their own particular areas on the display , where this gets odd is when your watching live TV ,these info blocks are always filled in with whichever program that's on, the best description of this issue is from these individual blocks of written captions on the screen example - from the top , there will be a continuous vertical row of horizontal lines starting directly underneath said caption all the way to the bottom , this will happen consistently wherever there happens to be writing on the screens display, so you get multiple rows of these horizontal lines from top to bottom of the display and they'll stay there for the entire time you watch your show , some shows have more ,some less ,depending on the writing for that show , this is all on cable TV / live TV I guess you can call it , and when I use my Fire TV stick with certain apps , I'll get no vertical rows horizontal white lines on the display with the exception that I push the mute button or change the level of the volume and the lines start to want to show up and do partially just for a little while ,but almost as soon as the info on the screen disappears as far as mute/ no mute or the volume level , the vertical rows of horizontal lines go away , I should also say that in either case Fire TV stick or cable , these vertical rows of horizontal lines take a little time to develope all the way from where the caption lettering begin and same process for when they go away , it's not instant in either case , it can take up a couple of minutes for either process to happen , one other oddity I guess you could say , in watching a cable tv program where you may get let's say 5 vertical rows of horizontal lines top to bottom at the beginning of the process , if you happen to try to watch that show ,those individual vertical rows of horizontal lines of varying widths will eventually connect with each other horizontally across the display
Feb 18, 2018 | Insignia Televison & Video
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
