Connecting NC 10 to BT Homehub. refuses to connect.
Screen shows Homehub -B5B8 as available, but will not respond to ''connect''
  • krobinsonN10 Jan 02, 2009
    we have connected several pc's/laptops/iPod Touches, running Vista, XP, Mac OS, to our BT Home Hub but my newly acquired Samsung N10 running XP SP3 refuses to connect (Limited or no connectivity). Is this a Samsung or BT problem?
  • gkinuk Jan 09, 2009
    I have dell inspiron 6000 and bt home hub 1.5. I don't have any problem with with ethernet cable connection. Problem with my wireless connection its connecting only for 2 minutes and disconnecting. Some times it's not connecting at all...Strange can any one help me pls reply or post gkinuk@gmail.com
Hoe do I connect a sonytv KDL26EX302 to bt tv
In order to connect your TV - any sort - you need:-
1. A BT broadband package.
2. A BT YouView box.
3. A network connection to your HomeHub or other router.
If one of these is missing (or if your broadband connection is too slow) you will not be able to connect to BT TV.
If you have all 3, then on the TV select the signal source to the socket that the YouView box is connected to and it will be installed automatically.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 11, 2014 | Televison & Video
How can I recover the password for my bt homehub 2
This page will show you where the default password is for all the BT Hubs. Where to find admin password BT Home Hub Help BT com Help If you need to reset the device as the password has been changed then look here How do reset my BT Home Hub to its factory settings Help BT com Help This will change the passwords to what are written on the BT Hub.
Oct 09, 2014 | AccessData Password Recovery Tool Kit (ftk...
I can't connect my kindle to my homehub. How do I find the hub password or re-set it?
if this is a bt homehub then the password for the wireless is on the hub on a sticker that says security key or network/WEP key, you will also have to press the hub button to allow the kindle to connect
Mar 28, 2011 | Computers & Internet
Can i put a Internet dongle on my home PC and connect to the Internet i don't have a bt line.
If you have a wireless router then yes you can use a wifi dongle. The only reason BT users can is that BT comes with a free wireless router (bt homehub) Max
Feb 11, 2011 | Dell Dimension 3100 PC Desktop
My Sitecom 300N repeater resularly loses its connection to my BT homehub. I think this is when the H homehub goes down sometimes. Resetting the Sitecom from scratch is a pain but resolves the problem. 3...
I also had this problem when the BTHomeHub goes down, power loss etc. I seem to have fixed the problem by changing the wireless config in the homehub to use a fixed channel, (the default is automatic which means it changes each time it restarts). This has been running trouble free for a couple of weeks through a number of power outages.
Can't help with Qs 2&3, get the same problems but less of an issue now that the thing works all the time.
May 16, 2010 | Computers & Internet
How can I make my canon mp140 wireless? I have a BT home hub on a secure network and it has a USB port, Is is possible to make this printer have some sort of wirless capabilities so i canb print from...
Its not an offical part of the homehub, but connect the MP140 and the HomeHub by USB, then on the computer you need to tell the PC that the printer is attached to the homehub rather than the PC. So on windows, start the add new printer wizard, and follow the steps on http://www.wallaceit.co.uk/Hardware/BT-Home-Hub---Use-it-as-a-print-server---Windows-XP-guide/80/article.aspx
Dec 11, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
CAn u help? The wifi on the lap top has stopped
check the drvier stats of the wifi is it there or not
Sep 02, 2009 | Famous Brand Notebook
Wireless not working from netgear wg311 to a new bt homehub2
Hi Backatya,
Check what kind of security you upgraded BThomehub 2 uses. Since the hub supports more security-types then your adapter does, I suspect an incompatibility there.
You can solve it by connecting through cable and changing security to WEP or WPA (not WPA2).
Regards Ronnie
Dec 15, 2008 | NetGear WG311T 802.11g/b (wg311tge)...
Computers & Internet Logo
524 people viewed this question
David Payne
David Payne
