Question about Fujitsu LifeBook C2330 Notebook
Fujitsu Lifebook C2330 Monitor dark
This laptop will start and seem to function properly but the monitor is really really dark. I can see that the computer is working, but I cannot seem to get the screen to brighten. I mean REALLY dark. I would appreciate any input.
  • 624 Answers
Your LCD backlight is not working. It is fixable but it is not a repair I would recommend to the typical user. The reason is that you have to disassemble a fairly good portion of the laptop to access the light source and/or the electrical components that control it. If you have excellent attention to detail, patience, experience with the disassembly and handling of electronics and the tools then give it a try. It is also important to also realize that by doing it yourself you risk the real possibility of damaging your laptop beyond economic repair then it may also be worth a try. Otherwise I would strongly suggest you take your laptop to the local authorized repair shop.
Posted on Feb 03, 2007
SOURCE:
Fujitsu lifebook screen will not come on
Could be a dead screen, use your vga, hdmi or svideo port to an external monitor or tv, if you get video there, then your laptop is still working and it is your screen. Check to see if you see any pictures on your screen but it would show in really really dark picture... if that is the case it is your screen backlit bulb that gone bad and the screen will need to be replaced. If nothing appears on your screen but you get picture to a external monitor via s-video, hdmi or the vga port then it could be that you have a loose cable connection or bad wireing somewhere between your latop base and the screen. If nothing at all appears on your screen or the external monitor source then you have a promblem with your laptop.... and those promblem can be in a wide range of trying to seek out the defective part.
Jan 14, 2011 | Fujitsu LifeBook S6520 Notebook
Fujitsu LIFEBOOK N3510 PC Notebook. The VGA CARD of my laptop is not functioning properly as the screen is showing all hazy and garbled words. I have reloaded driver,but did not help. What should I do...
Hook up an external monitor to the video output on the back of the laptop to see if the problem clears up, if it does you have screen issues on the laptop. If the same problem persists it is a Video Graphics Card problem on the motherboard.
Jan 04, 2011 | Fujitsu LifeBook Notebook
Screen is black with flashing cursor
Try to make sure that the first boot is set to CDROM.
May 02, 2010 | Fujitsu LifeBook C2330 Notebook
I need to replace my internal dvd drive on my fujitsu c2330 laptop computer
gently pull out dvd unit,disconnect connections,find new dvd by using model number
Sep 23, 2009 | Fujitsu LifeBook C2330 Notebook
ih some older lap tops have a wheel on the side of the screen that enables you to adjust the screens light or darkness. please excuse me if I am stating the obvious but I am not totally familiar with this model
as for the hissing this sounds like the fan needs cleaning as it is running under speed and causing the system to slightly over heat which is why the light keeps flashing..
In reply to your question with regard to can it be fixed is it worth it. if it was mine I would take it apart and clean the fan. In your case you should take it to a small out let to get it checked over. Hope this helps
Sep 15, 2008 | Fujitsu Siemens AMILO Pro V7010 Notebook
Fujitsu Lifebook Monitor
http://www.fairpriceshop.com/xFUJITSU.HTM
try this website
Oct 29, 2007 | Fujitsu LifeBook S6231 Notebook
Fujitsu LifeBook C2330 Notebook Logo
202 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Carlo Barzo
Carlo Barzo
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
