Question about Apple PowerBook G4 Mac Notebook
Problem starting the PowerBook G4
My computer will not start. When I press the power button, the apple background come up, and the circular loading sign begins. It continues only in this pre-load mode, and will not start.
  • Anonymous Dec 08, 2008
    I put and first aid I rec'd the start up disk in and after running disk utility I rec'd this message HFS volume needs repair
    invalid node structure
    volume macintosh needs repair
    It did not go on any further and now I cannot eject the disk.Does anyone know a way to eject the disk?
    Scholar:
  • 56 Answers
Sounds like the OS software has become corrupted and will need to be reinstalled. If you have the original CD's which came with your unit, you can begin by reinstalling the OS from here. I am sure that you have installed OS patches over the years and will need to reinstall any updates that have been done.
The key is to get your computer back up and running well enough so that you can back up any personal data files and prepare the unit to be restored as if it was new out of the box. I know that this will take some time to get it back to where you were, but that is the best that I can suggest. I have had the same thing happen to me once and I now perform a data backup at least once per week.
Hope this helps. If you do not have the original CD's, you will need to obtain a new copy of the OS from Apple and this will cost you a few dollars.
Cheers,
Keith
Posted on Dec 07, 2008
Reset button on a powerbook g4
The Powerbook G4 power button functions like a reset button if you hold the power button in for a few seconds until the computer powers down.
  1. Hold the power button in for a few seconds (until you see the screen turn off/go black and hear the fans & hard drive stop spinning).
  2. Press the power button again to turn your computer on.
  3. If you have more trouble, you may need to boot in Safe Mode or "perform a Safe Boot":
    Press and hold down the "Shift" key immediately after you hear the start-up tone. Release the "Shift" key when the gray Apple icon appears on the screen.
May 02, 2014 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Powerbook g4 17inch. when turned on iI get grey screen apple motif and loading symbol going round. when I start with start button and c key held down I get a mssg in top l/h corner saying : welcome to...
hmm well you could do 1 of 2 things Re install the OS, or Call there Amazing Tech Support cause there might be another way. Apples Tech support is by far the best I have ever dealt with.
May 13, 2011 | Apple Powerbook G4 1.33GHz 512mb 60GB...
My Powerbook G4 screen turned off because it was unplugged and the battery is no good. This has happened before and I remember there was a simple solution (some combination of buttons; Control + Option +...
It's called a Power Management Unit (PMU) Reset. Here are Apple's steps:
  1. If the computer is on, turn it off.
  2. Reset the power manager by simultaneously pressing and then releasing Shift-Control-Option-Power on the keyboard. Do not press the fn (Function) key while using this combination of keystrokes.
  3. Wait 5 seconds.
  4. Press the Power button to restart the computer.
Mar 24, 2011 | Apple PowerBook G4 Mac Notebook
Turn on my powerbook G4 but there isn't a chime and nothing comes on the lcd screen
If there's no chime, your problem could be anything from a dead battery or bad AC adapter to a dead logic board.
Does the tip of the adapter on your AC connector light up? If not, that's a problem.
When you push the button on the battery, do you get at least two glowing LCDs? If not, that's a problem.
Otherwise, try the following: remove the battery and the AC jack to make sure the machine is off. Now insert the AC jack, and reset the power management unit by pressing the following multi-key combination:
Shift Control Option Power-button
Wait five seconds, then press the power button to attempt to start the computer normally.
The instructions above are for the 1.5GHz PowerBook G4; the instructions MAY be different if that is not your model.
Nov 01, 2010 | Apple PowerBook G4 Mac Notebook
The circular timer startup screen NEVER STOPS! Powerbook G4
Hi
Safe Boot is a special way to start up in Mac OS X 10.2 or later when troubleshooting. Safe Mode is the state Mac OS X is in after a Safe Boot. To perform a Safe Boot, hold the SHIFT key as your Mac starts up.
Some features don't work in Safe Mode Safe Mode can be useful for troubleshooting. However, certain Mac OS X features do not work in Safe Mode. For example, you can't use DVD Player, capture video in iMovie, use audio input or output devices, or use an internal or external USB modem. The behavior of some devices such as an AirPort card may vary depending on computer and Mac OS X version.
Safe Mode in Mac OS X 10.5 or later also disables Quartz Extreme (hardware accelerated graphics). Applications that depend on Quartz Extreme will not open, and the Mac OS X menu bar will appear solid even if "Translucent Menu Bar" is enabled in Desktop & Screen Saver preferences.
Aug 03, 2009 | Apple PowerBook G4 Mac Notebook
Powerbook g4 going to white screen only!!
Do you have any external harddrive attached to it? If so, remove it before restarting. Try to start it up in safe mode by holding the Shift button down at startup: http://support.apple.com/kb/HT1455
Mar 24, 2009 | Apple PowerBook G4 Mac Notebook
Powerbook g4 15 not turning on
Something is wrong with the operating system. If there is a flashing folder with a question mark, then it might be with the hard drive as well. If you just get that warning, then you may only have to reinstall your operating system (OS X). Get your CD/DVDs out and insert the OS X disk. Hold down C when you start the computer so it will start from the disk and not from the hard drive. After the startup program has loaded, you can try to check the hard drive and repair permissions and such to see if that works, or you can just reinstall the OS. Good luck.
Mar 21, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
No sound what-so-ever
Do you have the Apple Hardware Test Utilities Disk. If so, restart the computer with that cd inside. It will do a diagnostic and determine if there is a defect with the hardware.
If not, power off the computer.  Wait about 2 minutes. Then press and hold down the power button til you hear a long beep noise. then release. allow computer to finish booting up. Then do a sound test again.
let me know if this helps.
enov8
Mar 07, 2009 | Apple PowerBook G4 Mac Notebook
Powerbook g4 will not turn on
pull the battery out, put it back in, plug the mac in, and hold down the power key till u hear the chimb
Feb 16, 2009 | Apple PowerBook G4 Mac Notebook
Apple PowerBook G4 Mac Notebook Logo
221 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
