Question about Canon imageRUNNER 5000 Copier
Cannon Imagerunner 5570 changed toner now printing light. Also the check toner light on. Re-seated toner, powerered off printer still have he same problem. What else can be done? One unhappy Puppy.
  • 76 Answers
When the wait period is over, start service mode and execute toner supply (thereby
supplying toner from the hopper to the developing assembly).
1. Press the following in sequence to start service mode: ‘user mode’, ‘2 and 8 at
the same time’, and ‘user mode’.
2. Select COPIER>FUNCTION>INSTALL>TONER-S.
3. Check that the following indication has appeared: “CHECK THE DEVELOPER.”
4. Check to make sure that the developing assembly has been mounted properly
and press the OK key.
5. See that toner is supplied from the hopper to the developing assembly (about 8
to 10 min).
6. Press the Reset key twice to end service mode.
Posted on Dec 08, 2008
On my Cannon runner 5570/6570 why my printing jobs come out too light?
If it's a reconditioned toner cartridge.. Then it's fine. It won't be as original cartridge ink.
If new check setting there will be option - Save Toner, unselect this option
Nov 13, 2015 | Cannon Office Equipment & Supplies
My Canon IR5570 shows error E000020-0002. What shall i do?
This is the error indicating that the connection for the developing hopper toner sensor is not detected at power on. Check this connection and the toner sensor for the hopper may need to be replaced. Good luck.
Sep 14, 2011 | Canon imageRUNNER 5570 Copier
Replace waste toner container message on IR 5570
on right hand side is waste toner you should be able to dump it yourself the main problem is reseting the counter that is not included in your manual Go into service mode by depressing the additional function key, then 2 & 8 at the same time, then aditionall function key. Select copier, then at the top far left side select counter. I blieve the counter is under MISC as waste toner. Select waste toner, depress the " C " buton on the keypad and it should reset to all 0's
Jan 15, 2010 | Canon imageRUNNER 5570 Copier
ImageRUNNER 5570 is printing slow. If I print the same on our 5065 it is about 10 times as fast.
1. Recommend to change the driver of the printer on local.Connect the printer through cable port USB. The Cable must not be long.
2. Change driver a device on local from computer without network
Nov 02, 2009 | Canon imageRUNNER 5570 Copier
Remove the waste toner cartridge from a canon imagerunner 6020. I wasn't sure and couldnt get the instructions from the 5570 to work
i think the waste toner bottle is on right side, its on the lower level of right side of the machine there is four screws, unscrew them and empyt the bottle, but u have to clear the waste toner bottle mode after. if this machine the waste toner in the front cover, just open the front cover, left the green handle and pull the waste toner,.the empty it and put it back
Jul 08, 2009 | Canon imageRUNNER 5570 Copier
Toner out light
Open an close the front door on the machine a few times and it will add enough toner to extinguish the toner add light.
Feb 17, 2009 | Canon ImageRUNNER 1670F Copier
Where is the waste toner cartridge on a Cannon Imagerunner 5570?
on one back-side corner. You need to remove at least two covers to make it easier. I suggest you to remove the back (the lower, big cover) and there you should be able to see the deposit. It must be close to the bottom, on one corner. Once you see it you may want to remove the cover that has it trapped (do not try to pull it towards you since you might break a locking mechanism it has) and then you will be able to easily slide the deposit out. Vaccum it and (Important) clean the bottle neck up with a wet rug. then get it back in making sure it follows its little path.
Jan 26, 2009 | Canon imageRUNNER 5570 Copier
5570 imagerunner question
If you can find the main power switch to the machine, you can find the waste toner bottle. Find the doors on the right side of the copier that are used to clear paper jams, or find the bypass tray. Then look towards the rear of the machine and you will find a small cover where the on/off switch is located that is attached with two screws. Remove the screws, pull out the bottle and dump the waste. Slide the bottle back, reattach the cover and you are done.
Jun 05, 2008 | Canon imageRUNNER 5570 Copier
Cannon Image Runner 5570
If the copier is indicating to empty waste toner bottle do as previously described. Until you reset the copy counter for the waste toner you will still get the message. Go into service mode by depressing the additional function key, then 2 & 8 at the same time, then aditionall function key. Select copier, then at the top far left side select counter. I blieve the counter is under MISC as waste toner. Select waste toner, depress the " C " buton on the keypad and it should reset to all 0's.
Nov 16, 2007 | Canon imageRUNNER 5570 Copier
Canon imageRUNNER 5000 Copier Logo
108 people viewed this question
old marine
old marine
