Question about Mitsubishi WS-65809 65" Rear Projection Television
Mitsubishi Rear Projection 65" tv picture becomes blurred bouncing right to left and color is red & green. TV is 8 years old approx. Any suggestions. Have not had any problems prevoiusly. First it woudl auto correct but now it is constant. Problem started only a few days ago.
  • aracelyrubal Jan 09, 2009
    there are lines bouncing all across the screen and also in red and green and i dont know what to do about them? could it also possibly need a new filter for the screen? please help........
  • 505 Answers
Sounds like possible solder connections on the convergence ICs. If so, you will see the red, green, and blue not lining up on ever input and even the mits menu. If you can bump it to correct, its just a solder connection, but if its out all the time then the ICs need replaced. This is a difficult repair only recommended for skilled technicians (40 solder connections + possible re-alignment needed)
Posted on Dec 07, 2008
Mits. rear projection tv ws65905 picture has blue color tint
Your blue picture tube is failing. Invest in a new TV. "If" you can find a new set of tubes(you have to replace all 3 red blue and green) they are around $800-1000. Not cost effective. Run the TV into the ground if you want to wait but do not invest any repair money in my opinion.
Jun 01, 2015 | Mitsubishi WS-65905 65" Rear Projection...
My tv color is blue and red is my lamp out or what
no your optic block is going south u need a new light engine big bucks
Sep 20, 2009 | Mitsubishi WS-55859 55" Rear Projection...
I have a Mitsubishi 55 inch rear projection tv, ws55819 on which the convergance is gone bad. I'm getting a concave picture with multiple colors and black lines with a blurred picture. this happens mutiple...
Your reference to concave picture suggests a high voltage problem and not convergence. If the raster can't scan from left to right , top to bottom, your having High voltage trouble. if your colors are not dropping on top of each other that is convergence. I would suggest it may be time to consider a purchase of the new HD set for the cost of this repair. good luck
Jul 03, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi tv model wd 73727 and how to take tv apart to clean marrow
my mitsubishi 73" set is 4+ years old. all of a sudden the color is all wrong. after a couple of minutes of clear picture the colors change--blue is green and red is yellow. a little while later everything has a red tint to it and there is a line going down the center of the screen. to the left the picture is still relatively sharp, but the right hand side is terrible. I'm hoping this is just the lamp.
Rick
Woodland Hills, Cal.
Apr 12, 2009 | Televison & Video
Picture turns to red & green and becomes blurred.
This is likely solder connections cracking on your convergence ICs. If you can bump the tv and it goes back to normal, it just needs resoldering, but if it doesn't, then it needs the ICs replaced. If the convergence is out, you will see a bowed picture and the red, green, and blue will be separated. Worth repairing if you can find a company to do it affordably, I can help you repair yourself if you have disassembly and soldering skills.
Dec 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Red and Green
check video IC or tv convergence sometimes yoke
Aug 12, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65908 picture problem
since this happened after you moved i would look for loose connections on the convergence ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Sony 65 Inch Projection TV Color Red Green Separation
Sounds like a convergence issue. Call Sony for an ASC that can come out and give you an estimate. You are probably looking at $200-400 to do the repair.
Nov 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
123 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
