Question about HP Color LaserJet 2600n Printer
HP Color LaserJet 2840 making awful noises
It sounds like groaning, grinding, dead cow noises. I'm not sure if it's the motor, gears, Imaging Drum, or what. Please help!
  • william95 Dec 23, 2008
    I have the same printer and problem.
  • 53 Answers
This can be numerous issues really.
Either the paper being used the printer does not like, this can be the texture, type, size etc try making sure all the rollers are clean. If problem persists Id take it to get a service done.
Good luck
Posted on Dec 03, 2008
Hp laserjet 5200 grinding noise from left side
front, rear ? I'd say fuser assembly gears or drum on toner cartridge; check the gear teeth on the toner cartridge's drum.
Dec 20, 2012 | HP LaserJet 5200 Printer
Groaning noise when turning wheel in either direction. almost sounds like a cow mooing.
Have the tie rod ends checked for no lubrication, they are the common source of this type of noise. I think a tire shop can listen to the noise give you an answer as to what it may cost to fix at little or no charge.
Nov 04, 2012 | 2002 Mazda Tribute
Grinding loud noise in the transaxle
sounds like the bypass lever might not be re-engaging, push it in firmly. OR, the brake is sticking. this, of course, is if the noise is a growl or a groan. if it IS a grinding noise, look for something stuck in the trans cooling fan or between the axles and wheels, otherwise it's inside the trans and that's not good [re: replacement]
Jul 10, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
HP Color Laserjet 2840 now makes ear-splitting whine every time
Did the noise start right after you replaced a toner? If so it must be a bad toner which is causing the gears to grind. If this noise happened out of the blue then it might be a bad fuser drive gear which is the gears that connect the fuser to the machine.
Jun 25, 2009 | HP LaserJet 2840 All-In-One Printer
Color Laserjet 2550 Loud Noise when starting up and printing
Remove toner cartirdge and check gears on cart as well as all of the gears you can see inside the unit for any signs of wear. You may also need to remove the fuser assembly and perform the same task with the gears back there. MAKE SURE THE POWER HAS BEEN TURNED OFF AND THE PRINTER UNPLUGGED FOR AT LEAST 30 MINUTES BEFORE ATTEMPTING TO TOUCH THE FUSER. IT WILL BE HOT!!! Most frequently these kinds of noises from the printer are due to gears slipping. Sometimes simply reseating the fuser assembly or toner cartridge will fix it. If there appears to be excessive wear on any of the gears, you will need to replace them.
May 29, 2009 | HP Color LaserJet 2550n printer + HP Color...
A motor in the Ref. started to make a groan like noise.
sounds to me that the fan motor is bad,write down the model number and go to a parts store(Sunberg),and the fan motor usually is about $50.00-$60.00
Apr 21, 2009 | Refrigerators
Roper model #RAS7133pqo
I'm having the same problem. The noise we hear is the water pump, does your washer have a belt?
Please forward to me any tips you may get, I'll do same
Feb 03, 2009 | Roper RAS8445KQ Top Load Washer
Hp2820 noise when printing
Try substituting a new imaging drum. The problem may be a bad bearing.
Oct 09, 2008 | HP LaserJet 2820 Printer
Loud groaning noise when copier is turned on.
sounds to me like the laser unit is going bad. common problem on this model.
Nov 28, 2007 | Copystar CS-1510 Copier
There is a tiny little magnet that falls off and/or has reportedly been put on backwards (fell off is what happened to me) on the auger assembly. It's near the black auger chute on the end of a shaft. It's tiny--a little bigger than a grain of rice. I had to replace the auger shaft assembly but if you can find the magnet, you can super glue it back on.
Apr 03, 2007 | Xerox Phaser 7400/DXF Laser Printer
HP Color LaserJet 2600n Printer Logo
510 people viewed this question
Ben Johnson
