My seagate external hard drive will no longer power on.
  • 61 Answers
Reset the power cable or try diffrent power cable for the hdd or try diffrent USB cable or Port
Regards
Samson Ved
Posted on Dec 03, 2008
    Sergeant:
  • 291 Answers
1) If you constantly plug & unplug the power plug going to the h/d for any and all reasons like testing different things inside the desktop, you could have (more often then not you pulled the plug from the wires!! , then repluged in again ) damaged the power wires going to the h/d. replace one of the other power plugs (if you have extra connectors) or substitute another for the one that the h/d is connected to.
2) connect a bootable floppy and boot up to see if the computer is working.Boot up with a floppy & a simple game to load up and see if the game will play FROM the floppy.
get back to me if that works.
Seagate freeagent keeps dropping disconnecting
Seagate manufactures both internal and external hard drives, and their sleep modes can be managed in different ways. The hard drive is one of the top energy consumers among computer-hardware components, and Windows operating systems support options to reduce power consumption. Internal hard drives are typically turned off and stop spinning ("sleep" mode) after a certain period of system inactivity. However, the system usually takes longer to come back when the hard drive's sleep mode is activated. Furthermore, turning off hard drives may result in failure of some constantly running applications.
Windows includes options to turn off sleep modes for internal hard drives, and external hard drives can be managed using a utility program.
Log in to an administrator account and click the "Start" button in the lower left corner of the screen. Click "Control Panel" and then "Systems and Maintenance." b> Click on "Power Options." Open "Change plan settings" under your current power plan. Note "Radio button" is selected for the current plan. Click "Change advanced power settings." Expand the entry "hard drive" by clicking on the "+" sign. Click on "+" to expand the entry "Turn off hard disk after." Select "Never" for this option and click "OK." b> In Windows XP Log in to an administrator account and click the "Start" button in the lower left corner of the screen. Click "Control Panel" and switch to the "Category" view on the left panel. Then click on "Performance and Maintenance." Click on "Performance and Maintenance" and open "Power Options." The select the tab "Power Schemes." Using drop-down list, set the option "Never" for "Turn off hard drives." Click "OK." b> Using "NoSleepHD" for External Hard Drives b> Click on the "NoSleepHD program" link in Resources. Click "I Agree" and save the program (as a zip file) on your computer. Open a folder where you have saved the file using Windows Explorer. Right-click on the zip file and select "Extract All." Then click "Extract" to get the program file "NoSleepHD v1.0.exe." Double-click on the program (.exe) file to execute NoSleepHD. Click "Select External Hard Drive" in the Program menu and choose your Seagate external hard drive. Choose "10 minutes" under the option "Write File every" and click "Start NoSleep Mode." The program will write an empty string every 10 minutes to the Seagate hard drive and prevent it from going into sleep mode. Hope this helps.
b>
Dec 29, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My external hdd has is not detecting
Seagate is a company that manufactures external hard drives.
These hard drives can be used to house large files or even to backup an entire hard drive.
When your Seagate external hard drive is not working properly, you might ready to send it into the company for repair.
Before you send it away, you can troubleshoot the problem and potentially save yourself a lot of time and grief.
Look over the power cable going from the wall outlet to the back of the Seagate hard drive. Make sure that there aren't any breaks or tears in the electrical wiring.
If there are breaks, replace the power cord.
Look over the power cable and make sure that it is plugged into the wall outlet in your home as well as plugged into the back of the hard drive.
Plug the power cable directly into the wall outlet or into a surge protector.
Do not plug the power cable into an extension cord.
Seagate Data Cable
Disconnect all of the USB devices that are plugged into your computer's USB ports except for your mouse and your keyboard.
Disconnect the Seagate external hard drive from your computer.
Unplug the power cable from the back of the Seagate external hard drive and restart your computer.
Wait until your computer has fully booted and then plug the power cable back into the hard drive.
Look over the USB data cable to make sure that there are breaks or tears in the cable.
Look over the ends of the cable where they meet the computer and the hard drive.
Make sure the pins are straight.
Replace the cable if needed.
Plug the data cable into the back of the hard drive.
Plug the data cable into your computer.
Hope this helps.
Nov 23, 2012 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Hi I Have an I O Error On My External Hard (500 GB Seagate) and I can't open or copy my files. Please Help Me. Thank You
  1. Unplug both the power cord and USB cable from the external Seagate hard drive.
  2. Restart your computer
  3. Plug back in both the power cord and USB cable from the external Seagate hard drive.
Comment back if this doesn't fix the issue.
Mar 01, 2011 | Seagate FreeAgent Pro 1TB External USB...
Seagate barracuda external 500 gb hard drive usb not seen any longer,cables and power okay , tried on three computers
Verify what Drives have been detected by your Operating System by using Windows: Control Panel -> Admistrative Tools -> Computer Management -> Disk Management -> Your Hard disk(s) will be displayed with all existing partitions and any assigned drive letters.
Your external (or internal) drive must be recognized as having formatted partitions that have a drive letter assigned to each required partition.
Hope it helps: let me know how you go!
Dec 30, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Please i need the power adapter rating for seagate
Have you got the original power adapter?
If so the voltage details are printed on the label on the bottom of the adapter.
If the external USB Seagate hard drive houses a 31/2" drive then it requires an power adapter that provides +12 volts and +5 volts both supplying approx 2000mA of current.
If the Seagate uses a 21/2" (laptop) hard drive then it only requires +5 volts power adapter.
The only problem is the power connector to the external drive, make sure it suits the external hard drive unit and the power pins are correctly wired for the Seagate. If the polarity of the plug is incorrect lt wired (ie reverse polarity) then it could damage the USB hard drive and adapter case.
Nov 20, 2009 | Seagate (ST3500601CB-RK) (ST3400601CBRK)...
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
Aug 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Drive manager is grey and says that no drive is attatched.
You need to get a Seagate Harddisk Utility software to check the disk intergrity.
Although hardware issues like can sometimes be very difficult to fix due to the impact on a volatile component on the harddisk which are most times not replaceable
Apr 06, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Freeagent desktop external hard drive will not power up
I have my own Seagate hard drive and with mine you have to plug it into the computer and power source for it to power on.
Jan 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
No Power to my Seagate FreeAgent Pro 500GB
I think you screw yourself... you have just burn your files
Sep 24, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
