Question about Mitsubishi WS-65809 65" Rear Projection Television
Picture turns to red & green and becomes blurred.
My rear projection 65" Mitsubishi has worked great for 8 years and recently the picture will become blurred shaking right to left and the colors switch to red and green. At first it would correct itself but now it's constant. Any suggestions?
  • 505 Answers
This is likely solder connections cracking on your convergence ICs. If you can bump the tv and it goes back to normal, it just needs resoldering, but if it doesn't, then it needs the ICs replaced. If the convergence is out, you will see a bowed picture and the red, green, and blue will be separated. Worth repairing if you can find a company to do it affordably, I can help you repair yourself if you have disassembly and soldering skills.
Posted on Dec 06, 2008
Picture becomes cloudy on my WS-65907 set.
You have a contaminated picture tube. One of the three (red, blue, green) will need replacement fluid. The best source with instructions on how to do this, is to see the website. They will have complete instructions and photos. I have used this site and quite impressed. Thanks for asking and show all hands of support!
Sep 01, 2011 | Mitsubishi WS-65907 65" Rear Projection...
Borders bowed inward,blurred red,blue, & green
the next time it is not working go into the customer menu with remote and call up the convergence grid and look---there---if convergence is way off and or comes and goes---this set uses 2 Stk-392-570 ic's and it is quite common to see them become intermittant.
Aug 03, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi Rear Projection 65" tv picture becomes blurred bouncing right to left and color is red & green. TV is 8 years old approx. Any suggestions. Have not had any problems prevoiusly. First it woudl...
Sounds like possible solder connections on the convergence ICs. If so, you will see the red, green, and blue not lining up on ever input and even the mits menu. If you can bump it to correct, its just a solder connection, but if its out all the time then the ICs need replaced. This is a difficult repair only recommended for skilled technicians (40 solder connections + possible re-alignment needed)
Dec 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi medallion 65" hdtv
the dm module power supply is developing leaky capacitors and will eventually cause the set to not come on at all. this may also be causing the snowy picture if you are useing the digital tuner. The dm module will require repair to resolve these issues.
Nov 29, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Blurred Picture Mitsubishi WS-65809 65"
the convergence IC's will most likely need to be replaced as well as a resistor or two
Oct 29, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Sony 61" Projection (KP-61HS10)
Your TV requires Geomatirc Adjustments in proper manner by qualified servcie person.
Jul 19, 2008 | Sony KP-57WV600 57" Rear Projection...
Mitsubishi 65
My TV did the same thing for a couple of years. It is the precursor to the capasitor going out on the DM board. The good thing is that the capacitors only cost around 4 dollars if you can soldier them yourself.
Apr 10, 2008 | Mitsubishi WS-65513 65" Rear Projection...
67" rear projection Mitsubishi....
Sounds like a cold solder joint, turn the main pcb over and see if you find any cracked solder or where the solder looks like it got hot.
Dec 04, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
114 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
