Question about Fahrenheat Electric Convector Baseboard Heater, 3'
220 POWER TO BASEBOARD HEATER
MY BB HEATER HAS ONLY TWO WIRES RED BLACK AND OF COURSE GROUND TO THE HEATER IS IT CORRECT TO ATTACH RED TO RED BLACK TO BLACK WIRE NUT THE WHITE. WHERE IS THE RETURN OR NEUTRAL AM I NOT UNDERSTANDING THIS FROM A NORMAL HOOKUP STANDPOINT
  • 333 Answers
Copy and paste this link into your browser and it will help you. http://www.qmarkmeh.com/Develop/prod_pdf/2500wiring.pdf
Posted on Dec 03, 2008
I have a base board heater in the basement. It's never been connect up the wiring is all there from the breaker box to the heater,it has 1blk.1white and the ground. heater has 1blk. 1 red & therostat
You need to take a meter and see if you have 220 volts between the black and white. if you do have 220 then hook white wire to the red on the on the thermostat and the black to the black wire on the thermostat. on the other side of the thermostat hook the red and black to the red and black to the heater
Jan 01, 2012 | Marley Electric Hydronic Baseboard Heater,...
Im hooking up a base board heater for the first time with a non programmable thermostat that has 2 black wires on the thermostat. I'm hooking it up to a two pole breaker that means back wire to top screw...
Hello there
It sound alright but You should draw out a wiring diagram on paper first before you tackle the job that way you know you're doing it right.
Good luck Dickson
Nov 04, 2010 | Fahrenheat Electric Convector Baseboard...
The thermostat on my electric baseboard heater has a red and black wire out the top and the same on the bottom. The electrician ran the power wire from the box to both red wires, one on top and one on...
If is 120 volt heater.The thermo can use 220 or 110 volt.The elec is only using the 110v half/side of therm.Should be ok.Does it work?OK to leave blacks unused.
Mar 16, 2010 | Fahrenheat Electric Hydronic Baseboard...
I am trying to install a fahrenheat f2543 heater with a fta2a double pole thermostat. there is a 12/2 wire coming into where the heater is being installed. how do i connect the red and black to the white...
Hi, this is very easy for you to do.The 12/2 Romex wire coming in is the power which you know. What you do need to know, is the voltage coming in? Sometimes they will use 12/2 Romex with ground for 220, 240, operation. You need to know if the T-stat is Line voltage 220, or 240 volt. You have to have the same voltage for both for it to control. Reguardless of the voltage, lets say it is in the 220 and up range. You take one of the 12/2 wires, white or black and hook it to the black or red on the T-stat and the white to the other one, red or black. Thats it, you are done! If the T-stat is 2-pole I am sure it is a high, Line votage T-stat. Best of Luck,
Shastalaker7
Nov 09, 2009 | Fahrenheat Built-In Baseboard Thermostat...
No i didn't. I need instructions for wiring a
you have baclk and red wire supply and a black and red wire to load (baseboard).
your switch will have 2 black and 2 red.
connect blk supply to 1 black on switch ( it doesn't matter which one)
connect red supply to 1 red on switch
then
connect black from baseboard to black switch
connect red from baseboard to red switch
if multiple baseboards that have several loads at thermostat then just connect baseboard blacks together and reds together before connecting at switch.
Oct 17, 2009 | Heating & Cooling
I am trying to replace a electric baseboard heater that is 220 volts and I am unsure about the wiring. the heater has a red and black wire and there is a white and black wire coming out of the wall.How do...
if ur are replacing the heater and it was originally 220/240 ur wiring should b ok but to b sure trace the line wire back to breaker panel and look at breaker the white and the black should b hooked up to separate breakers if the white is hooked up to a ground bar usually on the inside side of the panel and the black hooked up to breaker ur line is 110/120 and will cause problems when hooked up. if the lines r 220/240 than red can hook up to white and black to black
Sep 25, 2009 | QMark FBE15002 electric baseboard heater...
I have 2-240V (4.2V) basebaord heaters, Need Wiring Diagram
you get 120V from any phase (black OR red) to neutral
you get 240V from phase to phase (between black and red) and in this scenario you don't need the white wire.
So for you, connect the black to 1 pole of the breaker and the red to the other pole, connect the green wire to the ground strip and you are done.
A white wire is NEVER connected to a circuit breaker anyway, it is a grounded wire, it would be like connecting a green wire to a black wire, bad idea.
the National electrical code specifies red and black wire color for 240VAC circuits.
As Ask Hank mentionned, nothing wrong with 10/3 wire.
Mar 22, 2009 | Fahrenheat Electric Hydronic Baseboard...
Wiring for baseboard heater
I hope you are using a Line Voltage Thermostat!! First, make sure that the power feeding the thermostat is coming from a two pole breaker of the correct amperage (20 amp). If you are using 12-2 wire with ground then please mark the white wire with black tape at each end to identify it as a HOT power source and not a Neutral wire (which is a grounded lead). Do the same for the 12-2 wires feeding the baseboard heater from the Line Voltage Thermostat. The wires from the thermostat (One Black & one White w/black tape) will be wired to each one of the two wires (one Black & one Red or two Black wires) at the baseboard heater. It doesn't matter which wire from the thermostat is wired to which wire at the heater, just as long as there is one wire to one and one wire to the other.(eg. Black from stat to Black at heater/White w/blk. tape from stat to Red at heater OR Black from stat to Black at heater/White w/blk. tape from stat to OTHER Black at heater). I have seen baseboard heaters with two black wires or one black and one red wire. Hope this helps, but if you are confused then please have an experienced tech. do it for you.
Dec 14, 2008 | Fahrenheat Electric Convector Baseboard...
Fahrenheat plf2004
I can help you with this if you still need it.
Oct 16, 2008 | Fahrenheat Electric Convector Baseboard...
How to wire 1 plf 1504d heater
I have the solution, finally after looking for 2 days.
First off, I couldn't quite put it all together based on what I was reading. I finally tracked down the Fahrenheat web site (www.fahrenheatpro.com). And called tech support (800) 452-4179.
To wire 2 BB units to 1 tstat.
1. Use #14 wire for 0-12 amps, #12 wire for 12.1 to 16 amps and #10 wire for 16.1 to 24 amps.
2. I have a 12/2 wire going from the tstat to BB#1 and another 12/2 wire going from BB1 to BB2.
3. Onthe left side of the heater, you will have 2 sets of black wires tied together with a nut (on right side it's 2 sets of Black/Red wires). You can use either side of the heater. For the purpose of explaining this, lets use the left side, 2 sets of black wires.
4. Undo one of the sets of black wires (it doesn't matter witch), the other set will be left alone.
5. Take the black wire coming from the tstat and tie it into one of the black wires from the heater and the black wire going to the second BB unit. So you will have those 3 wires tied together with a nut at the 1st BB unit.
6. Take the white wire coming from the tstat and tie it into the other black wire from the heater and the white wire going to the other BB heater. Again, you will have 3 wire tied together here.
7. At the second BB unit, tie the black wire coming from the 1st unit to one of the black wires in one of those 2 sets of black wires. Again, only undo 1 set of wires at the 2nd unit, leave the other one alone. Tie the white wire coming from the 1st unit to the other black wire.
8. Make sure ground wire in grounded at the tstat and at both BB units.
Hope this helps...... If I was less clear than I hoped, call tech support and they will walk you thru it....
Kevin.
Dec 08, 2007 | Fahrenheat Electric Convector Baseboard...
Fahrenheat Electric Convector Baseboard Heater, 3' Logo
192 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
