Question about Motorola Mobility RAZR V3
Camera Not Working
Hi All I have a V3 Razr Black. Everytime I try to load the camera progrm it pauses and then a message box appears saying busy try again. I know this is not caused by the phone just being turned on because I never turn it off. Any Auggestions? Thanks
  • Sean Carr Feb 05, 2007
    ill try that
    Im still open to sugestions in case its a much worse problem.
  • kkev1211 Nov 05, 2008
    I have the same problem . camera is busy try later. or cannot initialize the video camera.. could it be the software.
Thanks lot for ur suggestion , i refered these steps and its worning fine.
Thanks Lot........
Posted on Nov 04, 2008
Have u tried using the smart keys @ the side of the model? (The small 1 contols the camera) I am not sure it will help, but it is worth a try. Also try closing the phone and holding the small smart key down for 5 seconds. The camera should appear. Sorry if it doesn't work!!!
Posted on Feb 05, 2007
When calling someone i get no dial tone utnil i put it on speakerphone. when call connects it says it is forwarding. also when trying to use camera it says busy try again later.
That means your buzzer speaker is bad. You will have to get that replaced. When the camera says it's busy you will have to get the camera replaced. It may also be a loose connection internally. I have repaired quite a few with this issue.
"Please leave me a feedback or testimonial if this helped you,Thanks!"
Oct 27, 2010 | Motorola Mobility RAZR V3
When try to operate the camera a message appears saying " application busy"
this is because of insufficient RAM of ur mobile or phone memory . Because camera requires more memory than other program try to clean the phone memory & use memory card 's memory
Feb 22, 2010 | Motorola Mobility RAZR V3x Cellular Phone
Motorola RAZR V3X
hi, this isn't a solution but it might help explain the possible problem. The v3x camera has a connector in order to connect it to the rest of the phone parts. If that connector is loose or possibly has broke you will get error messages. The only way to know is to have a technician take the v3x apart and check. The V3X is not as easy as the v3 or v3xx to take apart and you must have the correct tools. If needed the camera unit can be replaced so that you don't have to purchase a new phone. If you can find a technician in your area you can ask if he has a v3x that he uses for parts. It would be less expensive. Good Luck.
Jan 12, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Razr v3 camera
the firmware needs to be reflash on the phone
Aug 17, 2008 | Motorola Mobility RAZR V3
Motorola RazorV3 Camera Error
hi there, your camera is faulty and needs to be replaced or it could be a problem with the phone. I suspect the camera once everything else is working o.k. You need 2 take your phone to the nearest service technician to get it replaced. Replacing the camera is fairly easy from my experience as a repair tech. Sam !
Jul 10, 2007 | Motorola Mobility RAZR V3
Help for mobiles Razr V3
Try master reset under "settings". Sometimes if there is any trama to the phone the flex cable connection to the camera does pop out. If the phone is under a year old and there is no physical damage send it back to motorola thru your phone service. If not crack it open and check the connection. Manuals can be fould online. Its very tight inside this phone so if you think it is very important to get the camera working give it a try.
Jun 02, 2007 | Motorola Mobility RAZR V3
Camera
Well, it sounds like you need to get it checked out. I'd suggest Radio Shack or Best Buy. There should still be a warranty on it.
May 25, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
154 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
