Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Drainpipe leaking I just replaced my old washer with a new Whirlpool. Aside from being 20 yrs old and in need of a new belt for agitation, I was still able to use the washer with no major problems. I installed the new washer just as the old one had been installed..it seemed pretty easy. Until my drainpipe overflowed. I've never had this problem and the pipe is clear. I can't imagine a major block in the drain pipe from 3pm to 4pm the same day. I'm wondering if the water pressure from the new washer is too much? Any ideas? Thanks.
  • sarahgayewar Dec 01, 2008
    I have the same problem with a Whirlpool. My plumber told me the new washer pressure was too strong for my 50 year old house pipes and he would have to replace the pipe. Is this necessary or is their some kind of adapter for the new hose and old drainage pipe so that it wont' overflow?
Thanks for the feedback. i forgot to come back and post that my plumber fixed the problem. and it was the former of the two suggestions you gave. you may not be an expert, elkay, but you hit the nail on the head. good job.
Posted on Jun 10, 2007
Hi Mary, I'm going through similar experiences with my new Whirlpool which I learned to hate. I'm not an expert, however, I learned a thing or two about washers recently. Your problem could be related to one or two things: The drainpipe hose should not be placed more than 8" in length in the drainpipe as it creates a siphon effect. Also, the new washers are designed to spin fast, thus higher water pressure exiting into the drainpipe. If your drainpipe is clogged up for some reason and cannot handle the high water pressure, that may also create a problem. This can be solved by using some Draino in the drainpipe. Hope this helps.
Posted on Jun 09, 2007
Washer model LA5800XK is 28 yrs old; we stopped it during an unbalanced 'spin-cycle', a buring smell followed, now it only fills with water but does not agitate or pump water out - is this a...
May need a belt replacement. Belt could have gotten wet and slipped and burned a spot in it. I had one of these and replace a locked up water pump and belt once. I finally got rid of it when the transmission started growling loud it was 32+ years old lady kenmore. see http://www.appliancepartspros.com/ for a diagram.
Jan 17, 2011 | Whirlpool Washing Machines
Won't spin, agitator won't turn. Repair it or just get a new one? 8 yrs old.
Hello,if your washer won't spin first check to see if the motor is running, then proceed as follow.
1. If the motor is running, your washer probably has a frozen pump pulley or broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely or if it is frozen or stiff replace it.
If the pump belt is broken or looks quite warm, replace it but be sure to check the pump pulley before you change the belt.
AGITATOR: If the agitator won't turn, the likely cause is "Lid Switch" because if the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Thanks
Jun 09, 2010 | Maytag SAV2655A Top Load Washer
Washer won't fully drain.
If this washer has a self cleaning filter(cone shaped) it's probably plugged. Also could be the pump or the belt. Good luck..
Mar 17, 2010 | Whirlpool Washing Machines
Our LSR7233HQ0 washer is 10 yrs. old and the agitator stopped spinning. Any repair tips?
You may have broken the drive belt. Can you hear the motor spinning still? If yes, then it is definitely a broken drive belt.
Oct 25, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washer squeaks really loud while agitating. Drains great 6yr old
Could indeed be the belt or at worst it could be thr main bearing getting dry and gradually seizing up. Hope it,s the belt!!
May 20, 2009 | Washing Machines
Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Feb 15, 2009 | Whirlpool Washing Machines
GE washer approx8 yrs old
Slip a belt or rope under the agitator and attach both ends to a thick handle, rod, or pipe. Yank up hard. Agitator should come right off. Remove the plastic upside down can shaped agitator drive spline, which is held on by one bolt. It should come right off, but sometimes you have to crack the plastic to remove them. If you cannot turn the small grooved metal shaft (that you can now see) with your fingers that's good, you can just replace the agitator drive with a new one, replace the agitator, and you are set to go. If you can turn the metal grooved shaft with your fingers, you are basically screwed, as you would need to replace the transmission. (which is not really cost effective on your out of warranty low end washer)
Oct 30, 2008 | GE WVSR1060A Top Load Washer
Kenmore Washer
the problem could be several different things depending on the make or model. quick answer would be to replace the belt(s). after a while belts stretch and become worn. not so quick answer would be a problem with your transmission and or motor.
Oct 18, 2007 | Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
150 people viewed this question
Sal De
Marvin
Marvin
jimorris77
