Question about Toshiba 62HM95 62" HDTV
480i is displayed on the 62HM95 even when I play my Sony BluRay
I have my Sony bluray hooked up via HDMI and when I hit display on the TV, it reads 480i. But when I watch Directv on my HD DVR, it will display sometimes 1080i. How can I set this to read this resolution all the time? I would think that with the HDMI and the BluRay, it would process the 1080 and display it on the bottom left corner
I called toshiba (the television manufacturer) and they told me that the tv recognized the devices and then adjusts to the resolution according to the device of where its receiving the signal (HDMI).In this case my blu ray was not set to the 1080i resolution. Yesterday I set it up and BAM there it was.
Posted on Dec 04, 2008
How I get a 1080p display. I only get 720p
You need to have a 1080p source. Most TV channels broadcast in 720p. Otherwise, a bluray player hooked up via HDMI will give you 1080p. The TV will switch to the correct resolution automatically.
Feb 18, 2016 | Westinghouse 48 1080p LED HDTV
Playing bluray through xbox one on toshiba TV
Make sure the display resolution is set correct for your TV,
How to change the display resolution for your TV on your Xbox One...
Also make sure the TV is on and set to the correct HDMI input before using the Blu Ray.
It is also possible the TV does not support HDCP, if not, it will not work with the XBOX one Blu Ray. You may be able to use the Component (Red Green and Blue) cable though.
Apr 07, 2014 | Toshiba Televison & Video
No picture
It sounds like the Bluray player may be outputting the signal at a higher resolution than the TV supports. If the Bluray player has a scart or composite connection, connect with those first, and adjust its settings to output a lower resolution. Then reconnect the HDMI. Hope this works for you.
Jul 17, 2010 | Sharp LC-32SB23U 32 in. LCD TV
I need a firmware or software update to play a hddvd in my flatscreen/dvd combo. its an emerson 19inch flat screen model ld195em8
Sorry to say, but a firmware update will not reformat your DVD player into BluRay or HDDVD capabilities.
There is only one way to get your TV to display BluRay DVDs, that is to purchase a BluRay player and connect it to your TV with a HDMI cable, now this will also require your TV to have a HDMI port to connect to, and your TV must be able to display full
1080p resolution,with that said I don't know of a 19" TV that is full 1080p capable,especially not a combo unit.
Good luck !
Jan 11, 2010 | Televison & Video
I do not know how to work the display resolution
The tv display resolution will automatically change depends on your source/device output resolution and TV inputs used as well. Television component and HDMI inputs accept 480i up to 1080p signal while composite and s-video accepts 480i(lowest resolution) signals only. You will get high resolution signals from cablebox, game consoles, bluray etc through their component or HDMI output jacks.
Dec 25, 2009 | Sanyo DP50747 50 in. Plasma TV
Sharp Aquos 40lcd will not play bluray
You need to change the resolution on the Blu-ray to 720P to match the Tv native resolution.
Jun 26, 2009 | Televison & Video
Ps3 all of the sudden will not play bluray discs my tv is 1080p and ive been playing them for awhile but not it will start the bluray and then a little circle in the upper right corner will be moving then...
Try using a cleaner disc to clean the lens assembly. If this dose not produce results, replace the entire optical lens assembly.
Contact Sony for this repair.
Jun 25, 2009 | Sony Playstation 3 (PS3) Console
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Jan 04, 2009 | Onkyo TX-SR506 Receiver
Cant play blu-rays on lcd hdtv connected with hdmi
The software playing the bluray disc (PowerDVD) will only play it on the primary display. You will have to set your tv to be your primary display in order to watch the movie.
This only happens with bluray and HD-DVD discs.
Dec 06, 2008 | Sony VAIO Notebook
480i is displayed on the tv even when I play my Sony BluRay
You have to go into the blueray player menu and select the type of output. And, yes the display on the TV will automatically indicate the type signal it receives from the source.
michtech
Dec 03, 2008 | Toshiba 62HM95 62" HDTV
Toshiba 62HM95 62" HDTV Logo
215 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
