Question about Ricoh Aficio 1018 Printer
Fax Print Sideways
Ricoh Aficio 2020 D; occasionally prints 8 1/2" X 11" fax as if sender laid on copy plate sideways. Upon contacting sender, not possible -- their fax machine is feed only, so it could't be sent sideways!
    New Friend:
  • 63 Answers
Problem has to be on the sending side..
Posted on May 01, 2009
Out of focus
Out of focus - Ricoh Aficio MP C4500 Copier with Print, Scan, Fax, Finisher
Jan 29, 2014 | Ricoh Aficio MP C4500 Copier with Print,...
Price of print cartridge
Depending on the vendor, you can get the Ricoh 406464 toner for the Aficio SP 3410SF (regular cartridge, not the high yield one) for between $65 and $90 . Some sites to look at http://www.bluedogink.com/ricoh-406464.html and http://www.staples.com/Ricoh-406464-Black-Toner-Cartridge/product_332848 .
I hope this helps.
Sep 15, 2011 | Ricoh Aficio SP 3410SF Laser Multifunction...
My ricoh aficio 3025 copier has the capabilities to scan, print & fax but it only copies. Can we add those modules?
you need to buy a enable sd card for print and scan... and the problem with the fax function just conect it., the line and the phone.
Jul 09, 2010 | Ricoh Aficio 3025 All-In-One Laser Printer
I have ricoh aficio 1018d can it fax or print and i cannot find connection points on machine
Sir,
You can fax or print with the aficio 1018d provided that you have the fax and printer options. these connection points are located at the back of the machine.
Mar 06, 2010 | Ricoh Aficio 1018D Copier
Trying to get my Ricoh Aficio 1035 networkable
This is all you need to upgrade your copier to a network printer/scanner and fax.
Good Luck.
32MB Memory Unit Type B 400516
Postscript 3 kit type 1045 410713
64MB Memory Unit Type B 400517
Fax Function Upgrade Type 185 410284
Print Unit Type 1045 410706
Printer/Scanner Unit Type 1045 410699
Network Interface Board Type 1045 410714
Fax Option Type 1045 410680
Fax Stamp Marker Type 30 334049
Jul 08, 2009 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1232 c SC-101 and SC-142 codes what do they mean?
It is a scanner problem....could be lamp, lens defect, or as simple as the lamp, and lirrors undeer the glass being very dirty, because the code refers to the 'white level"....a calibration that the machine does when switched on. It could be as simple as, the white plate which is underneath the left scale (beside the main contact glass) is dirty (or missing). Try cleaning this (2 screws), and while you're at it, try removing the main contact glass (3 more screws)and cleaning it as well as the scanner bulb, and mirrors (slide scanner to the right with the machine unplugged).
Good Luck
Mar 02, 2009 | Ricoh Aficio 2015 Copier
How do i print the fax log and error report??????
The fax log or Journal is printed automatically after every 50 communications (tansmissions and receptions). If you want to print a copy of the journal;
Select Fax mode and press <Information> icon on the upper right corner of the touch panel.
Press <Print Journal>
An error report is printed whenever the transmission or reception has failed.
If Transmission result report is on, a report is printed every time so you have a record of whether it was successful or not.
Good luck and please rate me, thanks.
Jan 27, 2009 | Ricoh Aficio 2022 Black and White Copier
Reprint Last FAX on RICOH Aficio MP 3350
Once the fax was received and printed you can't do nothing.
It is not stored in the machine.
Please call the sender to send you the fax again.
Dec 30, 2008 | Ricoh FAX2210L Plain Paper Laser
Ricoh Aficio 1018 Printer Logo
356 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
