Question about Canon NP 6050 Copier
Have code EO20 on an NP4050
I had slid out the dev. chamber and reinserted ,plugged back-in connectors ,then bypassed the door switch..... screen came on saying EO20 "turn off then on" . I'm a tech(10yrs.) but not sure with this puppy what I need to do . I restrung the lower corona that was missing hoping to correct orginal pbm. which ..was no image.
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
"E020" Black toner feed problem
the4050's were notorious for this problem.
open the hopper and vacuum out all the tone and locate th thin metal arm that rotates. I used to bend it inwards, so there would be a hump in the middle of the arm( so it does not touch the sides of the hopper. also check the auger that feeds the toner into the Devellopper to see if it is clogged. thirdly the motor for the hopper does go bad ( this is the one that turns the metal arm to mix the toner)
Posted on Dec 03, 2008
Where is the memory card located?
The memory card slot is near the battery chamber. There is a small slot parallel to the battery chamber. Check the bottom of the camera. There is a door that can be slid outside to open.
Jun 14, 2015 | Canon PowerShot SD500 / IXUS 700 Digital...
Manual samsung double door fridge
You may have to replace the bracket but first check to determine whether the door is out of alignment. Usually the brackets are strong enough to resist bending
Oct 05, 2013 | Refrigerators
C2500 problem with keyocera mita 3035
A C2500 Code is as follows (direct from tech manual.)
Paper feed motor problem.
Poor contact in the paper feed motor connector terminals.
Defective paper feed motor rotation control circuit.
Defective drive transmission system.
Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable.
Replace the paper feed motor.
Check if the rollers and gears rotate smoothly. If not, grease the bushings and gears. Check for broken gears and replace
if any.
Most of the time it is the motor if you power the unit down and unplug it. Wait 30 seconds power it back up and it should (key word) bypass the broken cassette. To find out if it is the motor you can switch the motors with cassette 1 and 2 they are the same.
Hope this helps.
Aug 02, 2010 | Kyocera Mita KM-3035 All-In-One Laser...
My t3065 e machine was powered down manually 1 week ago when I got back to it to turn it on nothing happens, the power cord and wall plug are fine
Perhaps during the interlude that the eMachines wasn't being used, there was a power outage, or lightning struck nearby.
The first hardware component that I would check, would be the Power On switch, and Power Supply.
Bypass the Power On switch to see if the problem is the Power On switch, or the Power Supply.
If bypassing turns the Power Supply on, the problem is the Power On switch.
If bypassing does Not turn the Power Supply on, the problem is the Power Supply.
Inside the plastic Power On button, is a Power On switch.
It is a Momentary Contact Switch.
Below is one example of a Power On switch, I have found to fit many computers.
Bypassing is done with a jumper wire, inserted into the back of the 20/24-pin ATX main power cable connector.
The jumper wire Briefly, touches the Soft Power On wire (Green) terminal down in the connector, and ANY Ground terminal. (Black)
I listed 20/24-pin above, because I don't know if the T3065 uses a 20-pin ATX main power cable connector, or a 24-pin ATX main power cable connector.
Below is an example of a 20-pin ATX main power cable, and it's corresponding connector,
The photo all the way to the Right, shows the back of the connector.
It is plugged into the motherboard.
The Front of the connector is plugged into the female socket on the motherboard.
The Back of the connector is shown, and this is the area the power wires go down into.
Here you can see the green Soft Power On wire.
ANY of those Black wires are Ground wires.
I have Not detailed this procedure yet.
Do Not attempt it until I do.
I want to know first, if you are interested in doing the procedure, and will also outline any safety issues involved.
Jun 04, 2010 | E-Machines T3065 PC Desktop
Washer will not turn on. the door is closed and it is plugged in but nothing happens.i have bypassed the door switch
If you bypassed the door switch already then you need to try and pull the back off and make sure the plug it's self has not come out from the wires inside it sounds like alot but it's really not it's all there and pretty much self explainatory.. If you need further help just let me know :) Hope this helped
Jan 07, 2010 | Kenmore Washing Machines
Need to replace heater core
big job, dificulty 8 on a 10 scale Heater Air Plenum Chamber Removal
  1. Remove heater outlet floor duct (18C433) as described.
  1. Remove instrument panel (04320). Refer to Section 01-12 .
Instrument Panel SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Radio Removing Tool 415-001 (T87P-19061-A)
Removal and Installation
  1. Disconnect battery ground cable (14301).
  1. Remove RF wheel and tire assembly. Refer to Section 04-04 .
  1. Remove three nuts in radiator coolant recovery reservoir area.
  1. Remove bolt retaining front fender apron (16054) to front fender (16005) .
  1. Position front fender splash shield out of the way.
  1. Lower vehicle.
  1. Tag and remove main harness connector from jumper harness (located in front of blower motor).
  1. Remove steering column. Refer to Section 11-04 .
  1. Remove RH cowl side trim panel (02344) and LH cowl side trim panels (02345) .
  1. Tag and disconnect wiring connectors in LH and RH cowls.
  1. Remove ground wire located on LH cowl side.
  1. Remove RH instrument panel upper moulding (04268) and LHinstrument panel moulding (04389) from instrument panel (04320) by pulling away from instrument panel and snapping out of retainers. Disconnect wiring connectors as required.
  1. Remove glove compartment (06010).
  1. Remove instrument panel upper finish panel (044A90) and disconnect the A/C sunload sensor (19E663) and anti-theft indicator, if equipped.
  1. Disconnect the heater water hoses (18472) from the heater core tubes. Plug the ends of the heater water hoses to prevent coolant loss.
  1. Plug heater core tubes securely to prevent coolant leakage from heater core (18476).
  1. Remove one nut retaining the upper LH corner of the A/C evaporator core housing (19A559) to the dash panel (01610) .
  1. Disconnect two vacuum supply hoses from vacuum source. Push grommet and vacuum supply hose into passenger compartment.
  1. Disconnect wiring harness from A/C electronic blend door actuator.
  1. Disconnect the white vacuum hose from the heater and A/C air inlet duct door vacuum control motor (18A318).
  1. Remove nuts from the studs along the lower flange of the heater air plenum chamber (18471).
  1. Disconnect connectors to A/C electronic blend door actuator and electronic module on side of heater air plenum chamber.
  1. Remove heater air plenum chamber by pulling rearward.
Heater Air Plenum Chamber and Air Inlet Duct
Item Part Number Description 1 19C836 Suction Accumulator/Drier 2 56956-S2 Screw (2 Req'd) 3 386877-S36 Screw 4 45445-S36 Nut and Washer Assy 5 19C928 A/C Recirculating Air Duct Screen 6 386877-S36M Screw (2 Req'd) 7 45332-S12 Nut and Washer 8 19B762 A/C Air Inlet Door Inner Seal 9 19C590 A/C Recirculating Air Duct 10 18471 Heater Air Plenum Chamber 11 18C433 Heater Outlet Floor Duct 12 55734-S2 Nut 13 19A559 A/C Evaporator Core Housing 14 45332-S2 Nut and Washer A — Tighten to 2.5-3.2 Nm (23-28 Lb-In)
  1. Route the vacuum supply hose through the dash panel and seat the grommet in the opening.
  1. Position the heater air plenum chamber under the instrument panel with the A/C register duct opening up and the heater core tubes down. Connect wire harness connector to A/C electronic blend door actuator and electronic module on side of heater air plenum chamber .
  1. Rotate the heater air plenum chamber up behind the instrument panel and position the heater air plenum chamber to the dash panel. Insert the heater core tubes and mounting studs through their respective holes in the dash panel and the A/C evaporator core housing.
  1. Install three nuts on the studs along the lower flange and one on the upper flange of the heater air plenum chamber.
  1. Install three nuts below the windshield wiper motor (17508) to retain the LH end of the heater air plenum chamber to the dash panel.
  1. Install one nut to retain the upper LH corner of the A/C evaporator core housing to the dash panel .
  1. Connect the white vacuum hose to the heater and A/C air inlet duct door vacuum control motor.
  1. Connect the vacuum jumper harness to the plenum harness at the multiple vacuum connector near the heater outlet floor duct. Install heater outlet floor duct.
  1. Connect the sensor tube to the evaporator case connector on EATC-equipped vehicles.
  1. Connect vacuum supply hose to vacuum supply.
  1. Unplug the heater core tubes and connect the heater water hoses to the heater core tubes.
  1. Fill the cooling system with coolant to replace coolant lost during removal of the heater air plenum chamber.
  1. Install heater outlet floor duct as described.
  1. Install instrument panel. Refer to Section 01-12 .
Section 12-03A: Air Conditioning System—Manual A/C-Heater 1998 Crown Victoria, Grand Marquis Workshop Manual
NOTE: If a heater core leak is suspected, the heater core must be pressure leak tested before it is removed from the vehicle. Refer to Section 12-00 .
  1. Remove the heater air plenum chamber (18471) assembly as described.
  1. Remove the heater dash gasket (18570) from the heater air plenum assembly.
  1. Remove the four retaining screws from the heater core cover (18B300) and remove the heater core cover from the heater air plenum chamber assembly.
Dec 15, 2009 | Mercury Marquis Cars & Trucks
Every time I insert the tape, the screen says "Reinsert the tape"
make sure the camera internal battery is charged. using the ac charger plug the camera in for 24 hours. if the internal battery is dead then you will need to turn it in and have it replaced. that is why is says reinsert the tape
Apr 05, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
Canon np4050 copier
Very Simple Just Get $ on The Screen
Press `*` 4 `*` then Use Aero To get RAM-INT (its 10th Option)
Then Press OK Restart Your Machine
Mar 11, 2009 | Canon NP 6050 Copier
I have a problem with my clc 1180 machine.. i have an error code E020 subcode 00A3... i changed the black sensor ,the developper assymbly, the dc controll board,drum..... still i have same error....can you...
ok so this is a code for the atr sensor.. you said you changed it is that the one right above the black dev that has the connector that plugs up under the control panel. if it wasnt take that one out and clean it... you can also check under serv mode copier display dens and see what iy says under window for each color they should be around 100 you may want to try to clear R-CON but then you need to put all adjs back to door specs
Dec 24, 2008 | Canon CLC 1180 Copier
Canon NP 6050 Copier Logo
69 people viewed this question
old marine
old marine
