Question about Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2 OHMS => Model PV2000 Car Audio Amplifier
The volume cuts out completely.
I have a Peavey Session 500 Mark IV. When I turn it on it usually comes on and works fine. After playing a short while, the volume will go completely down and you can't hear anything at all. I can turn the gain control all the way up and move it around alot and the sound will come back, but it is blaring loud.
I sprayed the control knobs with contact cleaner. Is the power supply possibly going out?
    Problem Solver:
  • 5 Answers
You probably have a lose connection. check all connections at both ends of the wires. if that dosen't solve the problem there is something wrong with the amp
Posted on Dec 05, 2008
Peavey bandit 112
cracked solder joint, bad pot, dirty insert jack
Aug 14, 2014 | Peavey Bandit 112 Guitar Amplifier With...
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
Peavey session 500 a few seconds after turning on the limit lamp lights up and volume halves
Usually this is due to a cold solder joint in the low voltage supply of +15V -15V, does it make starnge noises or hum? Let me know further.
Oct 29, 2013 | Peavey Music
No volume on phone at all
the speaker is damaged due to loud music played... when playing loud sounds more power go to the speaker thus damage it... only solution is to replace the speaker. hope this helps...
Jan 28, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
What is DDT my system cuts out when DDT lights up
Go to http://peavey.com/support/searchmanuals/archived.cfm Their main site also has info. DDT is an active compression feature to protect the product .
Jul 04, 2009 | Peavey Pv 2600 Power Amplifier
Peavey TNT115 AMP cuts out
The problem is in amplifier section caused by change value resistor or leak capacitor or cold ,loose or crack solder joint parts this the common problem of over heating and shuts out the amplifier caused by abnormal distribution of current,try to check all the capacitor and resistor and replaced the defected parts ,so your receivers works normal again.
Hope it may help you;
Regards;
VOTIT
Jan 05, 2009 | Peavey Audio Players & Recorders
Peavey Session 500 Mark IV guitar amp sound loss
Hi Benjamin,
Electronics get things called dry joints, this is where the soldered components become insulated from their surrounding components intermittently. This usually manifests itself some years in use.
The symptoms are just like you describe the system cuts in and out.
I have repaired heaps of these over the years and it takes patience with a magnifying glass and a hot soldering iron to repair..
Id start with the socket connections on the main circuit board where you push cables in and them pulll them out again...as thats where mechanical pressure is
placed onto the conection between the socket and the circuit board.
Good hunting....YU BEUT..
Dec 03, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
PEAVEY 6 CHANNEL MIXER (PV6) - Right Fader Crackles
its obvious that the fader in question needs replacing ..parts are available from www.peavey.com
Aug 09, 2008 | Peavey 32fx USB 32 Channel Mixer
Durabrand DB1215 car radio
I have a db 1210 and i need the wireing plug for the speakers can you help
Jun 04, 2008 | Durabrand DB1200 CD Player
Car Audio & Video Logo
126 people viewed this question
Top Peavey Car Audio & Video Experts
Tom Chichester
FastHarley
FastHarley
Are you a Peavey Car Audio and Video Expert? Answer questions, earn points and help others
