Question about Canon Pixma MP500 All-In-One InkJet Printer
Loading paper-how? I've lost my manual to this new printer and can't figure out how to load the paper...where the heck?! lol
  • 53 Answers
You put the paper in the top, and it comes out of the bottom.
Remember to vote.
Posted on Dec 03, 2008
HP OfficeJet Pro 8600 tray can't be inserted all the way. Stops with 3 inches of tray sticking out.
  1. Grasp the handle on the front of the input tray, and then pull the tray towards you to open it.
    Figure 1: Pull out the input tray
  2. Slide the paper width guides out as far as possible.
  3. Remove all paper from the paper tray.
  4. Inspect and remove any foam or tape packaging materials in the paper tray.
  5. Insert a stack of unused, plain white paper (with the print-side down) in the center of the tray.
    Figure 2: Load paper into the tray
    CAUTION: Do not load any paper above the solid red lines on the sides of the tray. Do not use torn, wrinkled, perforated, wet, or folded paper. Make sure to remove all paper clips and staples before loading the paper. Figure 3: Stack label height
  6. Slide the paper guides in so that they rest against the edges of the paper, and then insert the tray into the product and push it forward until it clicks into place.
    Figure 4: Slide the paper guides in and reinsert the tray into the product
  7. Pull out the tray extender on the output tray.
    Figure 5: Pull out the tray extender on the output tray
Step two: Load paper in optional Tray 2
Tray 2 is an optional accessory. Follow these steps to load paper in Tray 2.
NOTE: Tray 2 supports only plain letter or A4 paper.
  1. Grasp the underside of the tray, and then pull out the tray from the bottom of the printer.
    Figure 6: Pull out the tray from the bottom of the printer
  3. Load a stack of unused, plain white paper (print-side down) in the center of the tray. Make sure that the stack of paper aligns with the engraved lines in the tray.
    NOTE: Load Tray 2 with only U.S. Letter or A4 plain white paper.
  4. Slide the paper guides in so that they rest against the edges of the paper.
  5. Carefully reinsert the tray into the printer, and then push the tray forward to close it.
    Figure 7: Reinsert the tray into the printer
  6. Pull out the tray extender on the output tray.
    Figure 8: Pull out the tray extender
Load specialty paper Follow these steps to load specialty paper such as card stock, envelopes, photo paper, or labels.
Before you proceed, verify that your printer supports the specialty paper on which you are attempting to print by viewing the product specifications . If the size, type, or weight of the paper is not available, the printer does not support printing it. Also note the tray loading capacity for the type of paper on which you are attempting to print.
Sep 27, 2013 | HP Officejet Pro 8600
Manual feed tray bypass
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Jul 25, 2012 | HP LaserJet 4250n Printer
Canon ipf605 paper error
Here is what I've found out by trial and error.
Paper Roll Won't Load:
    -Usually occurs when the roll is less than 50% full
    -Printer will give the error "paper loaded askew"
    To Correct This:
      - Press and hold Stop until Job Cancel comes up on the
      screen
      - Press Menu
      o Scroll Down until Adjust Printer menu comes up
      o Press right side arrow next to OK button
      o Scroll down to Manual Band Adjust and press right side
      arrow again (or select one of the other adjustments)
      - Select Yes and press OK
      - Load paper roll - make sure paper is straight
      - When asked (printer will beep) select Plain Paper and
      press OK
      - Let paper load
      - When printer starts to print press and hold Stop to cancel
      job
      - Paper should now be loaded
      When all else fails load a new roll.
      This would be a temporary solution until the sensor is fixed.
Mar 12, 2012 | Canon imagePROGRAF IPF605 InkJet Plotter...
I'm trying to print custom size papers. I've selected the mph on the printer with the settings for paper type. I've selected manual on the computer, with the settings for paper type and size....
What sort of printer are you using?
The printer may have a feed switch, which allows you to choose the feed location. Sometimes this physical button on the printer will override any software settings.
May 06, 2011 | Office Equipment & Supplies
I can't figure out where to load the paper at? Or is it the printer isn't grabbing the paper?
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=2613&modelid=15603#DownloadDetailAct
Here is your help...download the manual that you can view with you computer. It will show you step by step and you can pause and work at your pace... hope this does it. Now Email,
open the letter as though you were reading, at the top you see an icon of a printer, click..you got it. (or use your keyboard ctrl+P)...there now you know as much as I do...lol
please leave rating...thank you
May 11, 2009 | Canon PIXMA MX310 All-In-One Printer
Loading paper
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
takiqq18
Feb 01, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Paper Out message
Make sure that you are loading it in the back and not the front, I didn't figure this out until I looked at the manual. If you're used to HPs then you want to load in the front, but actually if you look behind the scan door, there is a black panel that you can open, and that's where you feed the paper. That thing in the front is actually where the paper comes out of. Go figure.
May 18, 2008 | Canon PIXMA MX310 All-In-One Printer
Can't load paper in new printer
You're in the Canon PowerShot camera area. Maybe try posting your printer question in a different place, where more people will see your question.
Oct 23, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon Pixma MP500 All-In-One InkJet Printer Logo
49 people viewed this question
old marine
old marine
