Question about Estate TS25AFXK Side by Side Refrigerator
System was off
My Estate by Whirlpool Corporation water filtration system was off during the IKE hurricane here in Houston and the water and ice system still has bad taste to it. What can I do or what should I do to get my system back to normal status.
    Scholar:
  • 82 Answers
Hello. Did you try running the water through the door until it becomes room temperature? This will completely flush out the water resouvior in the fresh food section. When it comes to the ice tasting bad, a lot of the time it is from something that has gone bad in or behind the crisper drawers. Take the drawers out and check. You may be thinking how can something in the frig compartment effect the ice? The frig is cooled by the freezer by a opening in the top and bottom of the center divider. Hopefully this helps.
Posted on Dec 03, 2008
Water filtration system leaking at spout
sounds like you water inlet valve is failing, this is a electric water switch... i suggest you turn off the water to the frig...
Dec 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Moldy taste from Whirlpool side by side
The problem can still be in your lines, or in the dispenser itself. If you run hot water with a little bit of vinegar in the lines and let it sit for about 30 minutes and then flush the whole system this should take care of your problem
Apr 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water/freezing to ice at the bottom of the freezer MZD2766ge
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all that ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youll melt everything) or by pouring hot water down the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 17, 2008 | Maytag MZD2766GES Side by Side...
Freezer section not cold enough/fridge ok
sounds as if you might have a compressor related sealed system problem, youll have 5 year war on such an issue from the manufacture
Oct 29, 2008 | Maytag MSD2758GEW
Whirlpool Side by Side Refrigerator
You have a refrigerant loop that runs through the cabinet of the refrigerator and usually runs right under the door gasket seal. Usually, when you are getting too hot on the loop, it is because your refrigerator cannot shed the heat it is removing from inside the refrigerator. This is most likely caused my either a dirty condenser unit or a faulty condenser cooling fan. (both located underneath the unit). The fan should be running anytime the compressor is running.
Oct 14, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
I lost power for several days during Hurricane Ike. When the power came back on, I cleaned out the ice maker bucket and let it make new ice. It makes ice and the light comes on when you press the...
when you repl the filter it has to be purged to bleed all the air out just keep askig for wtr until you purge all the ait out dispence at least 15 large glases of wtr
Oct 14, 2008 | Whirlpool Refrigerators
Ice maker trobleshooting
We lost power due to hurricane Ike and now that the power is back on the ice maker is not working. Is there a reset button or what needs to be done to get it working again?
Aug 10, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
Estate TS25AFXK Side by Side Refrigerator Logo
96 people viewed this question
Top Estate Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Audie Bogus
Audie Bogus
Level 1 Expert
Are you an Estate Refrigerator Expert? Answer questions, earn points and help others
