Question about Optoma EP719 XGA DLP PROJECTOR 2000L 2500:1 CONT DVI-D WITH HDCP Multimedia Projector
Can't get projector to display from HP laptop. Press Fn-f4 as usual but projector can't find source
  • marcojimenez Mar 12, 2009
    i have hp pavilio dv4 1125 nr i have tried with many projectors with no success. Adjusted resolution, reset BIOS, upgraded drivers....
    what next?
  • Anonymous Mar 24, 2014
    F4 key doesnt change the screens but projector works fine with a different laptop
    Problem Solver:
  • 4 Answers
I have sold over 100 of these (useless)... projectors so i can tell you that you need to;
go to display properties in the laptop and make sure you can see 2 screens otherwise you wil get nothing out of the video output/vga depending which model you have. go to the projector menu and make sure auto is set for the source/input. if your laptop has VGA out set optoma to VGA. start the projector up again and then the laptop in that sequence. if you need any more help email me.
Posted on Dec 03, 2008
When i connect my projector to computer correctly it says no signal
Please perform thebelow steps :
You may follow these steps to connect the notebook to an Projector
1. Turn Off Computer.
2. Connect the monitor cable from the monitor to the monitor port on
the rear of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
* Switching the display to the external monitor
Press FN + F4 to toggle the display between the Notebook display and
Projector
May 20, 2010 | Computers & Internet
Pavilion dv4000 PC Notebook: I want to use power point using hp laptop and acer...
you need to hold down the fn key then hit the f4 key to switch to external source.
May 16, 2010 | HP Pavilion dv4000 Notebook
Projector Pj556d can find my hp computer
on the laptop,you will need to press the Fn key and then the f1,f2,f3 ect key until you find the display key,hold down fn and press the key untill you clone the screen
Apr 10, 2010 | ViewSonic PJ551 Multimedia Projector
I can't get the display from my laptop to project to a screen.
If you connect the data projector to your laptop and power it up first then your laptop, the video will switch to the data projector automatically.
If you had powered up the laptop first then you can divert the video information to the external video port/data projector by holding the Fn key and then press F4 key.
You can toggle between the LCD screen, the data projector or both LCD and data project together using the Fn & F4 keys.
May 25, 2009 | Compaq Computers & Internet
Unable to transmit image to projector
Usually you can use a VGA connection cable to connect your computer with a projector. They also have inputs for s-video and RGB but these are much rarer on computers. Once you have connected the projector press the key on your keyboard that looks like a square with two lines on either side (mine is FN+F4) This will shuffle through different setups (mirrored to screen, extended to screen and back to normal) if this doesn't work try plugging in the vga cable and restarting the computer with the projector on.
Jan 06, 2009 | HP Pavilion dv4000 Notebook
Which function key allows to switch to tv
You need to press hold the FN key and press the F4 function key once which toggles the display to the External Display source like the television connected along with the LCD of the Notebook.
If the FN and F4 key combination is pressed again, the display will dissappear from the LCD of the Notebook and remain only on the external source.
If the FN and F4 key combination is pressed third time, the display will be back on the LCD of the Notebook and will not remain on the External display source.
Here are these details in other way :
First time pressing FN + F4    ---> Display on LCD and External display
Second time pressing FN + F4 ---> Display not on LCD but on the External Display
Third time pressing FN + F4 ---> Display back on the LCD and not available on External Display (Normal position).
Below are the details of what the Function keys in your DV1000 Notebook work :
fn + f1 Opens Help and Support Center fn + f2 Opens print options window fn + f3 Opens default Internet browser fn + f4 Switches the image among displays fn + f5 Initiates Standby fn + f6 Initiates QuickLock fn + f7 Decreases screen brightness fn + f8 Increases screen brightness fn + f9 Plays, pauses, or resumes an audio CD or DVD fn + f10 Stops an audio CD or DVD fn + f11 Plays the previous track or chapter on an audio CD or DVD fn + f12 Plays the next track or chapter on an audio CD or DVD fn + esc Displays system information.* (*To clear the system information display, press esc.)
Hope this helps...
Oct 11, 2008 | HP Pavilion dv1000 Notebook
Cinema projector
please start your laptop first and then your projector-----test after that---press fn key with f4 or f5 or f6 or f8 if no display---and check your input source(compter)in our case.
Sep 22, 2008 | Radio Shack Cinego D-1000 Multimedia...
Hitachi projector
Is your video source using a suitable resolution for your projector?
Is your laptop set to output video through the vga port? Try "FN" + "F4" on an HP, Fn+F7 on an IBM or Lenovo.
Is your projector looking at the correct source? TV / VGA / S-VHS etc...
Sep 15, 2008 | Office Equipment & Supplies
Video projector from a laptop
You can connect the Projector to the VGA Port of the Notebook which is a Blue Port which can be seen at the rear of any desktop computer to which we usually connect the Monitor to.
The VGA Port will have 15 holes on it and should be in Blue colour.
You can locate the VGA Port at the Left side of the Notebook.
Locate the port according to the information available below :
http://h10032.www1.hp.com/ctg/Manual/c00726464.pdf
Refer to page number 14 (18 of 32) in the manual.
Once you connect the Projector to this port, hold the FN key and press F4 key once.
This wil get the Display on the Projector connected to the Notebook.
If you just want the display only on the Projector, hold the FN key and press the F4 again.
Now, if you want the display back on the LCD of the Notebook, Press the FN + F4 third time.
Hope this helps..
Aug 31, 2008 | HP Pavilion dv2000t Notebook
Hooking up projector to my computer
If it's a laptop, you might need to activate the vga output, using the blue "fn" button in combination with f4,f6, f7 or f8, depending on your manufacturer.
On an HP, you press FN+F4 once, to turn off the LCD, and use the projector. Press it again to run both at the same time, and press a third time to use just the LCD. The cycle repeats on each press.
Aug 23, 2008 | NEC VT460 Multimedia Projector
428 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
