Question about Panasonic DMR-T3040 DVD Recorder
Panasonic DMR-T3040 won't read Hard Drive
Unit powers up and HardDrive indicator on display rotates once, then unit stops and only the time of day indicator is on the display. This happens regardless of what button I push (HDD, DVD, Open/Close, Power). I can hold the power button for 10 secs. and unit powers off. But when I power back up, I get the same result. Is HardDrive gone?
  • gmsteve455 Jan 10, 2009
    Same problem here. I believe that this is a cold solder connection on the board that the hard drive and DVD drive connect to. I've flexed the board and was able to get it to come up. No long term fix though, sometimes it goes right back out when I move the unit. I tried reflowing the board with a heat gun with no success - careful if you try this because the board has surface mount components on both sides.
4 Suggested Answers
  • 38 Answers
SOURCE: Panasonic DMR-EX77 - Error code DVD3
Pan use a version of Linux on the recorder. If you change the hard drive there is a format command in setup to format a new hard drive. Put a DVD in and try selecting and playing both DVD and HHD via the front panel buttons. Sometimes you can get error codes on a unit when the batteries in the remote are low. Try changing them Sometimes the remotes are faulty and not communicating properly. A fix in some cases is to press the number button corresponding to the number shown on the display together with the enter or OK button for at least 2 seconds. Good luck
Posted on Feb 07, 2009
  • 25 Answers
SOURCE: Panasonic dmr-es35v dvd/vcr recorder reads hello, then u61, then
Plug AC power cord to wall electric socket if it is plugged into a surge protector or extension, if not try a different socket, if issue still exist have unit service.
Posted on Sep 25, 2009
steven_mower
  • 9 Answers
SOURCE: F60 ERROR CODE ON PANASONIC DMR-ES40V
Unplug the unit for 24-hours. I know, it should not take that long, but in this case I tried shorter periods WITHOUT success!
Just before plugging in unit depress and hold POWER button. You are supposed to hold it for 30-seconds after plugging in, but in my case I did it for 60-seconds. This results in a MASTER RESET that clears all errors, resets interlocks, etc. I could not get past a DVD failure problem, but when I discovered this process everything worked fine!!
Good luck! Hope it works for you too.
Posted on Jul 21, 2010
Why can't my Panasonic DVD recorder read my portable harddrive? I want the DVD record to read the harddrive?
hi anonymous, it may well be that you need to change settings on your DVD Recorder and/or on your TV. On my LG 42" TV I need to select the input mode ie. Movie, USB, music etc, as necessary. Maybe your DVD Recorder or TV can't handle the file format on you Portable Drive, check the manufacturer specs.
Jun 08, 2014 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hi My Panasonic DMR-E85H Won't let me record to the Hard Drive it is displaying NO REC message on the Display ? Any ideas are most welcome .
it's the same problem with panasonic dmr-e55 recorder ; must we slack them for another one !!! we need help seriously
Jan 13, 2013 | Panasonic DMR-E85H DVD Recorder
I have the Panasonic DMR EZ28K and while in stand by mode and even while playing a DVD, the display will show U99. When this happens, the unit will not turn on to record whatever I have programmed. To...
You can probably fix this issue by updating the firmware and doing a system reset. First, download the latest firmware and burn it to a CD. You can download it from here: http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Drivers-Downloads/model.DMR-EZ28K.D#ts
Now, power the unit down, press Skip/Rev + Time Slip + Open/Close for 5 seconds. The CDR should be in the disc drive as you do this. This will install the new firmware and re-initialize the system settings.
The complete manual is here: http://service.us.panasonic.com/OPERMANPDF/DMREZ28-MUL.pdf
Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this answer. Happy holidays!
Dec 05, 2010 | Panasonic DMR-EZ28K DVD Recorder
Panasonic DMR EH56 permanent U88 Error on DVD- and HDD-Drive
displays when ther was somthing unusal detected with the disc while recoding playback or copy this is diplayed when the unit is in the recovery process to return to normal operation the unit is not broken once the display clears you can use the unit again
Jul 14, 2009 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-EX85 fault code U99
This is the solution from the on line owners manual for you product at www. panasonic.com. U99 ≥The unit fails to operate properly. Press [POWER í/I] on the main unit to switch the unit to
standby. Now press [POWER í/I] on the main unit again to turn the unit on. I hope this helps you with your problem.
Jan 30, 2009 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Jan 21, 2009 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Panasonic dmr-es35v
Is the Remote Control sensor in direct fluorescent lamp light or other strong
sources of light?
Press unit POWER button down over 7 seconds. The POWER indicator goes
out. If the Power was On, the screen will also disappear. After 5 seconds, turn
Power On and operate unit normally. If the steps above do not restore normal
operation, disconnect then reconnect the AC plug and turn the power On.
If that does not work, Panasonic offers free tech support 6 days a week 1-800-211-7262 (pana).
Jul 29, 2008 | Panasonic DMR-ES35VS
Panasonic DMR-E80H Change Disc Error
If you haven't done so, try downloading the firmware update from their support site. Burn the update file to a cd-rom.
I have had numerous times where my unit recovered and I had to format the hard drive(losing all of my shows), but since I did the update this has not happened to me again.
Nov 26, 2007 | Panasonic DMR-E80H DVD Recorder
Panasonic DMR-T3040 DVD Recorder Logo
147 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
