When i start to use my copy machine, it takes multiple times before the scanner bar? moves across. sometimes it takes 10-15 times before it finally works. it acts like it gets stuck on the bar it slides on. the copier is relatively new and when it does finally start the copies are fine. do i need to lubricate it
It doesnt sound like to much is rong with the scanner they all judder at start up. if there was a scan drive issue you would get a L3 error code. does the m/c continually tick over? if so then you may just be out of toner as the m/c will be trying to reach its toner levels and that can take some time.
Posted on Dec 06, 2008
Your copier this problem solve
You clean Heat roller, Thermostate or thermostator
if you does not solve you can clean your machine laser unit
Posted on Dec 04, 2008
check your toner label
Dear sir follow up when machine is on many times your copier scanner move front to back after ready so problem is developer image last time or label check or drum charge check change it then solve your problem
Problem on your copier mother Board Or RAM
Solve: Clean by White thinner all surface and dry before attempting or assembling.Must be fix your p[problem.It is my practical experience.
Jun 03, 2011 | Sharp AL 1631 Copier
Feb 15, 2011 | Sharp AL 1631 Copier
Oct 08, 2010 | Sharp AL 1631 Copier
Jul 15, 2010 | Sharp AL 1631 Copier
Apr 21, 2010 | Sharp AL 1631 Copier
Feb 26, 2010 | Sharp AL 1631 Copier
Nov 25, 2009 | Sharp AL 1631 Copier
Aug 09, 2009 | Sharp AL 1631 Copier
Apr 30, 2009 | Sharp AL-1655CS Copier
Apr 23, 2009 | Sharp AL 1631 Copier
Jun 12, 2014 | Sharp AL 1631 Copier
Mar 17, 2014 | Sharp AL 1631 Copier
143 people viewed this question
