Question about Roper RT21SKXLQ Top Freezer Refrigerator
Not cooling refrigerator part
Freezer on top is working but the lower refrigeration part is not working
  • Roper Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fgjkgd
Posted on Sep 29, 2010
aasc
  • 1606 Answers
SOURCE: Maytag MTB2156GEW Freezer works but refrigerator (lower part) not
Is the freezer fan working ? Is there frost on the rear wall , inside the freezer section ? If frost , in the middle of the control panel , you will see a hole slightly larger (1/2 " ) . Insert a screwdriver slightly into this hole and turn slowly until you hear a click slightly louder than the rest . Once you hear this click , stop . The freezer fan should be off ( you set it into the defrost cycle ) . Close the fridge door . Using a short extension cord with all 3 wires split (without bare wire showing) check the amps . 2 to 5 amps is good , this would indicate the heater and bimetal are good , also , indicates that the timer is probably bad . If you get no reading on the amp meter , then either the bimetal or heater is bad . Remove the inside rear freezer panel . Trace the heater wires (1 on each side) and disconnect . Useing an ohm meter , or beep meter (tells continuity) , test the 2 heater wires for continuiny . No continuity , replace the heater
pt # 61002046 . If continuity thru heater , then bimetal is bad (small disk clipped onto the coils , with 2 wires attached . Pt # 61005254 .
Posted on Aug 26, 2009
jumptrout51
  • 3361 Answers
SOURCE: freezer is not cooling at top - ice melted -not
Check the back wall of the freezer for a ice buildup.(failure to defrost)
Check the freezer fan motor. Is it running?
Posted on Feb 12, 2010
rayname
  • 70 Answers
SOURCE: Freezer on the bottom model # PBF2555HEW Freezer works refrigerator not cooling at all
I replaced my evaporator fan behind panel in freezer this was not spinning had to remove ice maker and panel to access got parts list emailed from kitchen aid and picked up part at local appliance dealer
Posted on Jan 03, 2009
  • 22 Answers
SOURCE: My whirlpool refrigerator (Model ET18DK) does not cool
Most likely one of two conditions are the root of the problem. Either the fan in the freezer is stalled or the defrost system has failed. The fan in the freezer should run any time the comressor is running; if it's not, there's your problem. If you can hear the fan, check for frost or snow developing across the back panel in the freezer. Local repair service could probably supply replacement parts quickly for defrost failures (most likely a bad terminator if defrost system isn't working).
Posted on Apr 25, 2009
relaga58
  • 158 Answers
SOURCE: no cooling in refrigerator
air passage from freezer to the lower door maybe blocked with ice build-up
Posted on May 06, 2009
The top freezer compartment cools but the lower refrigerator compartment does not. Please help.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 28, 2011 | Frigidaire Refrigerators
My samsung ref (top freezer) does not cool well in the lower compartment but the freezer is fine.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Feb 14, 2011 | Samsung Refrigerators
My fridge is not cooling
My Refrigerator is not cooling. The Freezer works perfectly,but the lower or cooling section stop
working
Nov 09, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Water poors into lower section
heatman101
Oct 27, 2010 | Gladiator Freezerator Top Freezer...
My Lower freezer is too cool n ice build up inside there.... The top side working properly. What is this cause to happen?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 31, 2010 | Samsung RS2630SH Side by Side Refrigerator
Back of freezers seems to form ice after a month and this chokes off the cool air to lower section if i take off back and defost it with hairdryer it will work fine for a month
heatman101
Aug 31, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
No cooling in refrigerator
May 06, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Roper RT21SKXLQ Top Freezer Refrigerator Logo
391 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
