Question about Hitachi 35UX70B 35" TV
Tv power intermittant
After a recent brownout( low line voltage) we have had problems with our tv not turning on. Sometimes it stays on for a few minutes. Other times it stays on several hours. I need suggestions on finding and replacing the bad part probably in the power supply.
    President:
  • 1,284 Answers
As computer controlled as TV's are it is a good thing first to unplug the set for 2 minutes then trying operation again.
Posted on Feb 04, 2007
UPS shuts off intermittently and beeps
More than likely it just needs a new battery. If the power is sagging (called a brownout) the UPS is trying to switch over to the battery to keep the power consistent. The beeping is probably a code that indicates there is an issue with low voltage on the battery. New batteries are around $20-25. Here's a link to the replacement battery: http://batteryinternational.com/apc-backups-es-be350es-ups-battery-ups-batteries-f1.html
Hope that helps.
Jan 21, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
TV CUTTING OFF ON ITS OWN.
your problem is intermittent if you are not a tech have some one repair your tv the problem could be in your power supply,or horizontal circuit where the high voltage is.it can also be your micro processor. good luck.
Aug 13, 2008 | Philips Magnavox 27MS343S 27" TV
Intermittant white line with subsequent shut down
You have a vert ic problem very common tv problem.
POSSIABLE SOLUTIONS
1 COLD SOLDER JOINTS ON IC REPAIR COST IS 95.00
2 REPLACEMENT IC 120.00
CALL LOCAL TV SHOP AND ASK FOR PRICES ON A VERTICALE IC REPLACEMT. THANKS DOCTOR VIDEO
May 17, 2008 | Hitachi 36UX59B 36" TV
TV goes to standby mode
kindly check the capacitors on the low power section.....
Jan 29, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
TV video problem
If you have intermittent line horizontally across both tv screens then there is likely to be bad solder connections on the vertical ic's of both of them. This can be fixed by taking the back off with quarter inch nut driver and carefully sliding the chassis out and turning it up to see the solder side. I don't know the location numbers but the vertical ic will be mounted on a metal heat sink and the connections will be in a row. Sometimes you can see the bad connections. You may need a magnifying glass. I recommend someone who has experience soldering electronic circuits. No solder bridges etc. This is for intermittent (works sometimes) problem on vertical ic. If the line stays then the chip ic is bad along with a 1 ohm resistor off the flyback high voltage transformer. From what you described you likely have bad connections. Hope this helps
Dec 30, 2007 | Televison & Video
JVC C-21MU1 / High Voltage Problem
Try checking the filter in the 116v line. You may have an intermittent spike coming through the B+ line.(The filter may have decreased in value) Also a small filter in the X-ray circuit could have lost capacitance. There is a low value capacitor (about .047uf @400v) in the collector circuit of the horizontal output transistor that will detune the horizontal circuit causing the HV to go too high. If this cap is intermittent it may be causing your problem. Stargazer Hope this helps
Aug 25, 2007 | JVC AV-28-BD-5-Bl 28" TV
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
Picture tube doesn't turn off
The power relay driver or the relay itself is bad. Its sticking closed so the voltage is there for the power supply but the micro has turned off the tuner.
Sep 15, 2006 | Panasonic CT-27G23 27" TV
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
