Question about Creda W100FW Front Load Washer
Creda 1000 Superspeed, stacked: Motor does not run
Unit cycles, loads and drains water, but motor does not run.
Unit is Creda 1000 Superspeed, Economy Plus, ECO Wash Series, stacked unit
  • Creda Master
  • 3,463 Answers
Sounds like you have motor problem, I suggest u check the brushes in the motor, most likely cause of problem.
Also check that the belt is still on the motor.
Posted on Dec 03, 2008
Creda simplicity 1000 w100fw My washer is full of water and wont empty, where us the filter located?? Any helpfull info would be very grateful
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 19, 2011 | Creda W100FW Front Load Washer
I have a Zanussi Aquacycle 1000. It is taking in water and draining but the drum does not rotate both during wash cycle and spin cycle. Urgent help needed as we have people staying from England and NO wash...
Hi.
If the machine is filling up, then cycling and draining, the problem is usually the belt. The belt is reached disassembling the appliance . If the belt is OK the problem is usually the motor or the motor control unit, which is a sealed electronic module connected to motor and to control board and located inside the washer. If the motor has volts and does not turn, then the motor must be replaced. In some less common case the control module itself may be responsible. Motor assembly and belt are located at the back of the drum and get accessed disassembling top and back of the washing machine.
If the machine does not go through the cycle, but it starts draining from start, then the problem is overfill detected. In that case check the drain system, the drain hose, the inlet valve and the pressure switch.
Regards.
Ginko
Aug 29, 2011 | Zanussi FJS1225W Front Load Washer
The washing machine working but water dose not go out/model is simplicity 1000/w200fw
Not draining
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 30, 2011 | Creda W120VW Front Load Washer
Creda Simplicity 1000 (w100fw) - Drum does not rotate
you could try fitting new motor brush kit it wears down after 4/5 years and need replaced....please leave feedback
Apr 08, 2010 | Creda W100FW Front Load Washer
Water pouring out the bottom when it is spinning
Your drain hose is either disconnected or there is a hole in it. To see the drain hose you will need to remove the back of the unit. The hose will be connected to the lower bottom of the motor. You can put the unit in the spin cycle to see where the water is coming from once you remove the back panel.
Hoped this helped you some\
Dave
Jan 09, 2010 | Maytag LSE7806A Top Load Stacked...
Whirlpool wshser-dryer: water won't drain, cycles won't start
You need to give more info in order for a diagnosis. Is this a compact stack unit or an all -in -one unit or an interconnected washer/dryer pair ? Is it front load or top load washer ? What do you mean by "dry cycle"? Is that dryer cycle or is it washer cycle without water ?
Usually when water cannot be drained it is a bad coupling connector on the motor drive, or a bad or clogged pump (small socks have been known to get sucked in an lodged in the pumps); in either case you need a good mechanic or a service person to handle the repair because it requires opening up the shell of the unit and getting to the motor/pump assembly.As always, disconnect the power cord before diving into the unit. Good Luck, Macgivor.
Sep 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Creda W100FW Front Load Washer. access to service drain plug?
Hi.
Remove lower rear cover of washer, locate pump, and remove large hose attached to it, remove and clean filter inside hose, check pump for possible blockage.
Please rate my solution.
Thanks.
Apr 19, 2009 | Creda W100FW Front Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Creda eco washing machine won't spin
it is the carbon brushes in the motor. there cheap and easy to replace. go on give it a go
Dec 11, 2007 | Creda W100FW Front Load Washer
DOES NOT DRAIN WATER
If motor runs or sounds like it is trying to run, you have a sock caught in the pump. If no noise at all you have a bad lid switch
Jun 07, 2007 | Kenmore 94812 Top Load Stacked Washer /...
Creda W100FW Front Load Washer Logo
382 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
sonic boom...
sonic boom...
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
