Question about E-Machines eMachines Desktop PC
Reboots every time i start my computer it reboots nothing happens i have to hit it a couple of time to get t to start and it takes about 30 minuets to get it right this is really killing me please i need help!!!
  • 37 Answers
The problem has to be with the ram contacts being dirty. Detach your ram and clean the contact leads with an eraser.It should clear the problem.
have u recently made any changes in your hardware configurations?
if yes, reset it to the previous state(remove any hardware you recently added)
hopes this will help you. feel free to notify.
Posted on Dec 03, 2008
How to reboot a hp laptop
Is Is the screen stuck with the boot screen? A couple of things to try- Hit ctctrl, alt, and delete buttons at the same time. That should reboot the computer. Also, you could unplug the power and pull out the battery. Leave it for about 30 sec then put the battery back in and reconnect power.
Feb 19, 2013 | Computers & Internet
The power comes on; however, nothing happens. We took the cover off and nothing happens. We hit :"open/close" and nothing happens, no spinning sounds, nothing. What can be wrong? Where can we...
Looks like the motor is Shot, Don,t evan waste your time to take it in to get repaired, It will cost you more, then to just get a different one, I have got good use ones for friends of mine for $7. to $30, at the most,
Nov 10, 2012 | NexxTech N500D 5-Disc
Toshiba satellite not opening after i cleaned the cooling fan.
Did you take the Heat Sink off that is over the CPU? If so you probably need to apply a fresh coat of Thermal Paste.
Remove the Power Cord, Remove the memory cover and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 06, 2012 | Computers & Internet
Why wont my car start even after i tried the security reset. i turned key to on position for 10 minutes turned it off then tried to start it 3 times. security light still flashes
turn the key on and wait till the security light stops flashing ( this could take as long as 30 minuets ) then turn the key off then back on but do not try to start the engine and wait till the security light stops flashing ( again this could take as long as 30 minuets ) then turn key off then turn key on and start engine.
Jan 31, 2011 | 1996 Buick Regal Olympic Gold
I have a 1997 Oldsmobile Cutlass Supreme Sl. I have recently been having problems with getting it started. The first time it happened was this past summer. I though it was just the key (PASS KEY 2 SYSTEM)...
your tumbler possibly worn and keys are now not reading or both keys are worn down to where not working correctly ---also ignition switch can be failing
Apr 17, 2017 | 1997 Oldsmobile Cutlass Supreme
I try to boot up my Fujitsu 6410, N series but it will not fully load, and stops before it loads the task bar. What can I do?
Reboot your computer.. hit f8 a few times at the logo and your menu will come up with an option to restore computer to an earlier time. Select this option and hit enter. If all goes well, you should be able to restore your computer back to before this started happening, pick a date in the list that you know your computer was working fine. It will reboot and you should be able to use your computer like nothing was wrong. This won't delete any of your programs or settings.
Oct 07, 2010 | Fujitsu Siemens LifeBook N6410 Notebook
Miko tim4, operating system won't start easily, needs 80% of the time power cut to reboot, after the 2nd or 3rd time it starts normally...any ideas ?
In this case I would take and restart it a couple times. Or, if you wait and not click or anything, it might work. You could also lose all your data and unplug the main power cord(leading to your main pc box) for 5 minutes. This will delete all the users on your computer. I would only do this if nothing else works or you have nothing on your computer you want to save.
May 04, 2010 | A Computer By Design Open Labs MiKo TIM4...
Why does my bike take so long to reach a normal operating temperture? It will keep cutting out until at least 4 miles is reached.
only 4 miles????? thats not bad realy,,after all its darn cold air out there!!,you never start it and let it run up for a fuw minuets before you drive away then? a cold engine will have maximum engine were done to it if driven cold! have you checked the thermostat out? if its stuck open the engine will take longer to warm up,,,but 4 miles???? thats nothing my BMW takes forever to warm up,,,the fan has only ever started up once in 3 years of riding it??? i was sat in a jam up for 30 minuets first with the engine ticking over!!! dont worry it will warm up quicker when the wether warms up
Jan 28, 2010 | 1995 Suzuki GS 500 E
'Crackling' Noises
This happened to my phone not too long after i purchased it.
I had to have the curcit board replaced.
Aug 08, 2008 | LG KU990 Viewty
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
