Question about Mitsubishi VS-45607 45" Rear Projection Television
Convergence problem i have a 50 inch mitsubishi tv model# vs-5052. the kids bumped into the screen and knocked the convergence off. i cant get the settings right (close but not right) is there any presets in the service mode for it? can you find a repair manual for it? or do you think it might be something elce?
  • smallblocks2 Dec 05, 2008
    there is no advance convergence settings
    Novelist:
  • 100 Answers
I have a VS-45607 and If the VS-5052 has the same menus then there are two options for convergence. One is the basic convergence where there is one set of crosshairs and you line them up. Then there should be an option for "advanced" calibration where the whole screen looks like a grid and you go to un-converged crosshairs and align the screen. Most likely not all of them will need to be adjusted, but for me, the lower right hand corner wasn't aligned right and this cleared it right up.Good luck
Posted on Dec 05, 2008
Mitsubishi VS-55609 distorted Picture Flickers
This is a convergence problem and not really a DIY Many amateurs try it to save money but end up spending more on it than a professional. There are dozens on here that managed to fix it for a day or two only to have it fail again.
cost of fix about $300.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | Mitsubishi VS-5059 50" Rear Projection...
We have a 52 inch rear projection Mitsubishi not sure of the model number and the picture is starting to go blurry with reds and greens at the bottom of the screen
Here is another similar problem with a Mitsubishi Rear Proj. TV and it has some things to try and an estimate if that is the problem.
"Cost of convergence repair is always around $400"
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Mitsubishi-WS55511-Projection-TV-1.htm
You could also try messing around in the menu for convergence adjustments. Usually it will let you adjust at 8 points on the screen.
Oct 26, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi vs 5052 has no picture
There seems to be a lot of people having problems with this TV. My TV is doing it too. If you find out the answer, can you email me please? griff378@msu.edu
Thanks!!!
Oct 17, 2009 | Televison & Video
Colors have seperated on tv, and curve
You have a convergence problem.
Maybe need change the IC of convergence, or the power supply of these parts.
Bye.
Apr 04, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi vs-55707 or vs-50707????? bouncing horizontal lines weird color
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visually inspect the STK Ics for dry or crystallized solder joints.
IC8C01 - STK392-110
IC8C02 - STK392-110
Dec 11, 2008 | Televison & Video
Mitsubishi 50 inch projection tv
you probably have a problem with the convergence board.
Nov 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi projection tv
I have a similar problem. I have tried to fix the convergence via the remote and that has not helped. My three colors are separated and the edge of the picture is bent in toward the center. I am going to try a hard reset but i suspect the convergence IC are fried. Since the set is not HD, I will probably replace it if the hard reset does not work.
Nov 22, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Year 2000 mitsubishi 64 inch tv
Have convergence IC's changed in your 60" TV. I only use ORIGINAL IC's, not generics or knock offs. Most companies that fix have no idea what the difference is.....
Oct 31, 2007 | Mitsubishi VS-60703 60" Rear Projection...
Need info onhow to fix
Fix convergence issue first = bowing / distortion will go away.
Requires changing large STK IC's and possibily a pico fuse
in the power supply......................T.
Oct 23, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi vs-50605
does not sound like convergence have had a few with bad capacitors. any good at soldering
Mitsubishi VS-45607 45" Rear Projection Television Logo
127 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
