Question about Arris SURFboard SBG900 (49402201900) Modem
SBG900 forgot password cant login
Lockedout of modem cant remember password
  • pv02008 Jan 07, 2009
    whenever i click login, a new page never loads. It simply keeps loading the same login page. Its like i'm hitting refresh
  • Anonymous Mar 10, 2009
    same thing i kno9w the webpage but i nedd to know logon details
Reset the modem from the back, you will need a needle or something, wait until it turns on. Then go to http://192.168.100.1 type on user: *admin* pass: (the HFC MAC ID as password you will find it at the back or at the bottom of the modem) ex: 0015a3e9570f. Remember is case sensitive, good luck. :)
Posted on Dec 16, 2008
  • chiari_man Jan 05, 2011
    Wow, took about three hours... But I found it, pretty simple. You must be plugged in to the modem to login. YOU CANNOT LOGIN VIA WIRELESS.
    Problem Solver:
  • 18 Answers
No nonsense solution ---
1- Ensure that you are hardwired to modem with an ethernet or USB cable.
2- Ensure that modem is powered on and "settled in" for a minute or so.
3- Use the pinhole at the top of back plate to reset.
4- Use a wire or needle to depress reset button for 30 seconds and release.
5- Allow modem lights to "settle in" again for a minute or so.
6- Enter "admin" for user ID - and "motorola" for password. [NO QUOTES]
7- User ID and password fields are case sensitive.
[Lower case in this instance]
8- Click Login and now you are talking to the modem.
Posted on Mar 16, 2012
How do I find my wep key? I cant remember it and cant get online wireless with out. I did go to http://192.168.0.1/login.asp but I cant seem to log in there. Please help.
Try to access 192.168.0.1 once again. Try to use "admin" for the username and "motorola" for the password. If "motorola" doesn't work, try "password".
Sep 03, 2011 | Arris SURFboard SBG900 Wireless Router...
Cant login to my sbg900, using admin for login but not recognising password
Try resetting the router. You can find a small hole with a button inside it at the back of the modem. Use a pin or a paperclip to press it for 5-10 seconds so that it will be restored to the factory settings.
Hope this helps! :D
Sep 08, 2010 | Arris SURFboard SBG900 (49402201900) Modem
I cant log in with my username and password
Reset the router to factory defaults by putting in a push-in in the small hold at the back of the router. You should then be able to login using the default password. Default password should be in the user manual.
Dec 05, 2009 | Arris SURFboard SBG900 Wireless Router...
I don't remember the password for my sbg900 motorola router and i need to connect one of my laptops to the network. How do I get the security key. I read another blog that mentioned pressing the reset...
Disconnect the Coax cable from the modem and restart it. Once the "Receive" light begins flashing reboot your computer. If the modem and the computer are communicating, the computer will get a 192.168.100.11 IP address (192.168.0.x with the SBG900) from the cable modem. Shut down your computer. Connect the Coax cable to the cable modem, restart it, and wait for the modem to sync up with the cable company. Once the modem is in sync (Power, Receive, Send, On-line are all illuminated) restart the computer. Once the computer has restarted check the IP address. The computer should have a valid IP address from the cable company. Computers attached to the SBG900 will always get a private (192.168.0.x) address regardless of whether or not the SBG900 is registered on the cable system.
Dec 01, 2009 | Motorola Computers & Internet
Forgot password for 2wire modem. the 1000sw.
well beneath the 2 wire system password field you will find a link which says "i forgot my password". click on it and it will show you the hint for the password. if still you cant remember the password then click on the link which says "i still cant remember my password". it will show you a 20 digit number. you will have to contact tech support for 2 wire and give them this number. they will give you a temporary password by which you can login in the 2 wire page.
Oct 08, 2009 | 2wire HomePortal 1000HW DSL Modem and...
I cant reset my Motorola SBG900!
Ok in the back of this unit or bottom there is a reset button or hole that you need a pin needle to access. Press it in for 15sec and let it reboot. Once it reboots, open a web page and type in 192.168.100.1 or 192.168.0.1 This will bring up a log in page. The login is admin and the password is motorola.
May 24, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Login for ip address 192.168.1.1
the usual username and password for this ip address is :-
username:- admin
password:- admin
let me know if that helpes
Jan 11, 2009 | Arris SURFboard SB5120 Modem
Cant login to router
When in doubt double check your work. You held the reset button down on the back of the router for long enough for the lights to go out then start blinking again? Then you went to 192.168.100.1 in your browser and tried admin for your login name and motorola for your password? If you did all of that and it's still won't accept your login try to power the router off for at least a minute by pulling the power cord and make sure you clear your browser cache before trying to access the default gateway address in your browser again.
Hope that helps!
Jill
Nov 30, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Sbg900 setup and login page
I had this problem just last night. I held down the reset button for 20-30 seconds. It worked when after pressing teh button the LEDs stayed on and then after the 20-30 seconds they started to blink indicating the reset. If they do not start reset while holding down the reset, let go and the modem should reset itself. It took me a few times to get this right since teh reset button is rather sensitive and a momentary depression/release will resutl ina reset of the modem but not to default password. I found out I was inadvertantly doing this momentary reset due to teh sensitivity of the switch.
Anyway, next make sure you type "admin" and "motorola" in all lower case. I was using Admin and Motorola - no good.
Nov 21, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Wep key
call your isp and they wilkl help you and if you go to there office they will give you a disk
Jan 11, 2008 | Arris SURFboard SBG900 Wireless Router...
Arris SURFboard SBG900 (49402201900) Modem Logo
23,208 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
