Question about HP P4015X LaserJet Printer with Automatic Two Sided Printing
Laserjet P4015 keep saying printing
  • 2 more comments
  • xman28 Dec 05, 2008
    i try to print the configuration page and do the same thing it keep saying printing .do you have the manual or do you know the part number for the main board
    thanks
    i replace the formatter already and still the same problem thanks for everything
    im going to order the dc controller thank you
  • Anonymous Mar 19, 2014
    black hold paper
  • 37 Answers
Unplug the cord that you are using to print to the machine.(USB, Ethernet). Clear the print que that is going to the machine. Power off then back on machine. Rehook up print cable and try to print again.
Hope this helps
Posted on Dec 04, 2008
  • Printelogy Dec 05, 2008
    Formatter assembly (base models) CB437-67901 (new)
    Formatter assembly (network models) CB438-67901 (new)
    This machine can't be that old. You should try calling for Warranty before replacing parts. Uncertified replacement will void your warranty.
    In that case it is probably the DC controller.
    DC controller PCA RM1-4582-000CN
How do I Fix HP Printer 50.9 Fuser Error online ?
50.9 Fuser error message HP LaserJet P4014 P4015 P4515 If you are seeing the message 50.9 Fuser Error on your HP LaserJet P4014, P4015, P4015 series printer, you have either a failing fuser or the wrong model fuser installed in your printer. (The fuser is the consumable part in your printer which heats up and bonds toner to the paper. Usually the fuser gets replaced several times over the life of these printers.)
HP makes 2 different model fusers that look very similar -- the P4014/P4015/P4515 series fuser, and the M600 series fuser. Because of the similarities in appearance, sometimes the wrong fuser gets installed in the wrong model printer and triggers a 50.9 error.
The easiest way to check which model fuser you have installed is to pull the fuser out of the printer and look at the fuser's barcode. It is easy to remove the fuser on these models; if you don't know how to remove your fuser see the removal instructions farther down this page.
Once you have the fuser removed from the printer, look at the barcode as shown below to determine which model fuser you have installed. For the P4014, P4015, P4515 series printers the fuser part# should read RM1-4554 as shown in the picture below.
Either way, whether you have a failing fuser or an incorrect fuser on your LaserJet P4014, P4015, or P4515, you can purchase a quality replacement fuser in the maintenance kit for the P4014, P4015, P4515 series. Click here to view our selection of fusers/maintenance kits. Call us with any questions toll-free 866-352-7108 or local 608-831-2396.
Removal instructions: How to remove the fuser from the printer
Turn the printer off and unplug the power cord. The fuser might be hot if you have been using the printer. As a safety precaution wait 30 minutes for the fuser to cool before proceeding.
If a duplexer is installed, remove it from the back of the printer.
Next fold down the rear door.
Flex the plastic arm-hinge (circled in red below) on the left bottom of the door . This will release the tab which holds the plastic arm in place, and will free the door.
While grasping onto both sides of the fuser, push the blue levers upward and pull the fuser straight out.
After you order a replacement fuser and it arrives, you can install the fuser by inserting the fuser and aligning the left side first. Push the fuser firmly on the left side, then the right--listen for the sound of both blue levers clicking into place. If the fuser does not click into place you run the risk of wearing out both the fuser and the gears that drive the fuser prematurely. Re-install the plastic rear output bin and you are ready to print.
Dec 28, 2017 | HP Office Equipment & Supplies
HOW TO SOLVE 57.07 ERROR ON PRINTER LASERJET P4015
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 29, 2015 | HP P4015X LaserJet Printer with Automatic...
Print black cartridge
Hi Ramesh
Go To Below official HP Printer Page For Your problem, Install Black Cartridge Message Displays on the Control Panel or... Still having Problem Then follow Us For
HP Printer Support
Feb 06, 2014 | HP LaserJet P4015 Printer
Squealing noise when printing
the gears might be faulty on the printer, but also the fuser can be faulty. get an onsite technician to have a look at the printer
Nov 12, 2013 | HP LaserJet P4015 Printer
Hp laserjet P4015 OPC is near end of life message
just replace print cartridge or recycle and continue using it and service printer/kits and pickup rollers or replace them
Jan 25, 2013 | HP Laserjet P4015x Printer
Can i do a printer path test on a hp 4015 printer
Yes, go to menu, scroll to diagnoses,enter, scroll to paper path test, enter, scroll to number of pages select,select tray,select if duplex, select test print enter..
Sep 27, 2011 | HP LaserJet P4015 Printer
My hp laserjet 4015 is displaying an error 50.3 after printing smarged copies
Thank you for contacting FixYa with your printer inquiry.
The 50.3 is a fuser Temperature error. If your pages have toner and image but are smudging or smearing you know the fuser is not heating and needs to be replaced.
If your printer is still under warranty contact HP Customer Care for warranty replacement of fuser part numbers: RM1-1082 for 110 volt, RM1-1083 for 220 volt. (888) 999-4747.
If your printer is out of warranty, suggest you purchase a maintenance kit part # CB388A HP maintenance kit for LaserJet P4014 P4015 P4515, includes other needed high wear parts.
Excellent Illustrations:
http://www.printertechs.com/tech/mkinst/P4015/mk-p4015-2fuser.php
Maintenance Kit Contents:
Contents
1. What is included in a LaserJet P4014 P4015 P4515 maintenance kit?
2. Fuser installation.
3. Transfer roller installation.
4. Cassette feed/pickup rollers.
5. Tray 1 (manual feed) pickup rollers/feed rollers.
6. Reset the maintenance count.
Please rate this solution and post a comment if you need additional assistance.
Jan 19, 2011 | HP LaserJet 4350 Printer
Jam in tray 2
This is an update to:
HP LaserJet P4015 - Not Picking Up Paper
HP now recognise this as a manufacturing fault and have released a service note for it and will send you a new fuser free of charge. The description of the fault is:
When a print job is sent to the printer, the printer will display processing job on the control panel, and will continually ramp up and down attempting to print the job. After several minutes the printer will return to ready without posting any error messages. Occasionally, after several minutes the print job will print.
The fix for the fault is:
The fuser needs to be replaced and firmware needs to be upgraded to version 04.060.7 or higher.
The customer will need to download the latest firmware from hp.com, version 4.060.7 or higher. The firmware can be downloaded from hp at "hp.com/go/support" . Select Download drivers and software (and firmware) in step 1 and in step 2 type in the printer name, LJ P4014, LJ P4015 or LJ P4515
It's probably best to update the firmware before you phone HP to report the fault, or at least tell them you have. If you do update the firmware, you will notice some extra numbers and letters on the display when the printer initialises. This is normal, it's probably used by HP staff for diagnosis.
The fuser is a customer replaceable part, and does not require a service technician to install. If the customer requests a service technician to install the fuser the customer will be responsible for the labor. The fuser can be sent directly to the customer with instructions to upgrade their firmware.
What this means is that HP will send you a new fuser to fit yourself.
The models covered by this service note are:
HP LaserJet P4014 Printer series, HP LaserJet P4015 Printer series, HP LaserJet P4510 Printer series.
EFFECTIVE DATES
Start: 2010-01-01
Expiration: 2010-12-31
What this means, is that HP will send you a new fuser for this fault until the end of 2010, although they do sometimes extend the active time period for service notes.
Hope it helps..
Thanks for using fixya......
Nov 08, 2010 | HP LaserJet P4014n Printer
Can't reset maintenance count on laserjet p4015
Reset the maintenance-kit counter 1. Turn the product power off and then on. 2. When XXX MB appears on the control-panel display, press and hold down the OK button until all three control-panel lights flash once, and then stay on. This might take up to 10 seconds. 3. Release the OK button and press the up arrow to scroll to NEW MAINTENANCE KIT. 4. Press OK to reset the maintenance-kit counter.
Aug 03, 2010 | HP LaserJet P4015 Printer
HP P4015X LaserJet Printer with Automatic Two Sided Printing Logo
227 people viewed this question
Seeker5211
Seeker5211
