Question about KLH ASW10-120 Subwoofer
Fried electronics in KLH ASW10-120B subwoofer
I would like to junk the amp and install a passive crossover since the speaker works fine. I need to know if it is a dual voice coil speaker and what the impedance is. Any help is appreciated.
  • d_price55 Mar 23, 2009
    Thanks. I found out that it is a 4 ohm.speaker
  • SharkyRiveth May 11, 2010
    Well, if it's a dual voice coil, there would be 4 wire connections. 2 pos and 2 neg. Not to be confused with a single post connection that has 4 male pins on it. There will be 2 of these posts. Each will have 2 wires going to the voice coil.
    I just looked at mine. I could not find the Ohm rating on it. So I will not suggest anything on that. Sorry.
  • 4 Answers
It is a 4 ohm nominal impedance woofer. If you put a new woofer in, it will last maybe half an hour and then fry/melt. The problem is the amp, not the woofer. Throw the amp out and use the box as a passive sub. Get a 100 hz sub crossover.
Posted on Sep 01, 2009
    President:
  • 547 Answers
It is a single voice coil, 4 ohm speaker, rated to 150 watts.
Depending on the amp you're using, I don't know that I'd push more than 100 watts through it.
Posted on Jun 15, 2009
This subwoofer does the duty of it's intended purpose... However its nice to have a home stereo subwoofer amplifier, considering the lack of general availability. Like many of other audiophiles- once you hit the bass you need more... As i found this product to be sufficient in its purpose- i still wanted to frankenstein a meaner system using the built in crossover/ volume controls on a stand-alone subwoofer amplifer for home audio. Fortunately in my case i have about 10 extra subwoofers (competition grade car audio) lying about in several sizes, not to mention my hockey stick went through the cone so- replacement was inevitable. The sub does have a single 4 ohm voice coil so you need to match that resistance value or at least be higher (or you end up over-working the amp- making it unstable and turn potential sound to heat). So replace the speaker with any 10" single 4 Ohm, dual 2 ohm voice coil subwoofer.(wired in seires [+ to -]) , or in my case- use the amp and use it as a master amp, then run it to a reciever of some sort to gain some watts. The other way to use the amp itself solely for driving subs with amplification is find yourself any low watt subwoofer combination with a posibility of a total 4 ohm configuration in total, and mount them in an enclosure of your own choice... Maybe a nice TV stand with integrated subs or a coffee table.
ANd for the knuckle heads who say the sound is only hitting certain areas.... HOUSE SUBS ARE MEANT TO BE AIMED AT THE WALL TO PRODUCE A BOUNCE EFFECT TO ESSENTIALLY REVERBERATE OFF OF THE ROOM STRUCTURE CREATING A SPEAKER OUT OF THE WALL. BASS NOISE IS THE MOVEMENT OF AIR AND MAKING THE WALLS VIBERATE CREATES MICRO-FLUCTUATIONS THAT IN- TURN MOVE AIR ACROSS THE ROOM ( the reason subs are in enclosures in the first place....)
Posted on Feb 17, 2010
I have a KLH subwoofer which is connected to my reciever and speakers with speaker wire. It is not connected to an outlet. It has recently started making a buzzing/rattling type sound. Do I need to take...
Yes, probably, if you aren't capable of repair yourself. However, IMHO, a replacement will probably cost less in the long run. I have a KLH passive subwoofer myself. I wouldn't pay for any repair if it failed. Replacements are far too inexpensive.
Aug 18, 2014 | KLH Audio Players & Recorders
Klh s120eth subwoofer not producing sound.
Normaly C26 has turned bad. It's 22uF/25V and is easy to access when module is disassembled.
Dec 29, 2012 | KLH Audio Players & Recorders
How do i connect my pv2600amp to my peavey subs and top speakers, i have the leads but what do i do?
Line outs Left and Right from mixer to power amp Left and Right inputs,
Power amp outs to Subs(if they have passive crossovers built in check specs on subs).
From Subs then to Main spkrs. Make sure power amp is set in stereo mode using this way.
Alternative: You will need at least a 2-way stereo crossover unit inline after mixer and before power amps if the subs don't have a built in passive crossover. Most of them do have passive crossovers in the subs these days. Then separate amps or one channel would drive the subs and the other the main speakers. True stereo would require at least a 2 way crossover and two stereo power amps if hooking them up this way.
There is another option as is common with many sub setups. Send the signal to the mains using L/R outputs from mixer and a separate Mono output to the subs only. Putting only bass/kick and low frequency outputs in this send would help too.
Oct 13, 2009 | Peavey PRO-12 (00497070) Main / Stereo...
I have an auto amp with no crossover for subwoofer. i am wanting to know if i can hookup a passive crossover for sub speakers through amp to speakers say from radioshack or other home speaker system? i...
You could go with a type of passive crossover, and that should allow you to also control gain as well as the bass input, and you can also go with a low pass filter as well. These are quite inexpensive at Wal-Mart and other places, and just run in-line with the wiring. There is no real cutomizability with the latter option, but it could be a means to get better sound while you save for a stronger crossover.
Sep 26, 2009 | Car Audio & Video
KLH Rave-12 speakers - some drivers are not working
If you place an ohm meter across the capacitors, the ohms should slowly drop as the capacitor charges. You can check continuity of the coils with continuity function of the multi tester.
Madisound.com is a good source for quality components.
Aug 16, 2009 | KLH Rave-12 Main / Stereo Speaker
I realize that this is an old problem, but folks are still finding it on searches, so here goes.
Here are the two pages of schematics from KLH. I wrote to their tech department and explicitly asked for permission to share them here.
Here's the lower board, which has the power supply:
KLH ASW 10-120 subwoofer schematic - lower board
Here's the upper board:
KLH ASW 10-120 subwoofer schematic - upper board
Jan 25, 2008 | KLH ASW10-120 Subwoofer
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Jan 07, 2008 | KLH HT-9900 System
Bypassing the 150 watt blown amp with passive crossover
I'm purchasing 2 infinity 3-way passive crossovers on eBay with the same crossover freqs as my two overture 3's with blown amps. For 19.99 each, it's worth a try. Good luck to you!
Jan 06, 2008 | Infinity Overture 2 Speaker
Car stereo crossovers
you should be able to remove the passive in-line crossover, but since it is blocking everything below 3500 hz, there is no need. leaving the passive crossover in place will also help protect the tweeters if something fails in your setup as any amped frequency below 3500 can seriously damage them.
Nov 11, 2007 | Infinity Kappa 10.7t 1'' M.M.D. Dome...
KLH ASW10-120 Subwoofer Logo
1,037 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
