Question about Pentax Optio M30 Digital Camera
Remove green mode - Pentax Optio M30 Digital Camera
    Problem Solver:
  • 15 Answers
Hi their bettyboop021
i have a pentax e30 and my green mode is the delete button
Posted on Jan 04, 2009
How do i remove green mode on a camera pentax RS1000
Pentax Optio RS1000 Digital Camera Green - Questions ...
www.fixya.com > ... > Optio > Pentax Optio RS1000 Digital Camera
turn green mode off my camera how to turn offf green mode just hit the green button, its the delete pic button as well, but it can be used to turn green mode on ...
Oct 27, 2015 | Pentax Cameras
How do I down load photo's from my Samsung 2 phone please
First make sure you have the correct USB drivers for your phone installed on your pc. Go to device manager and see if your phone or mass storage device is listed. If not, download the drivers here, http://www.samsung.com/us/support/downloads. Make sure debugging on your phone is enabled. Please refer to the following:
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > Applications > Development" and enable "USB debugging".
  2. Then drag the status bar down and tap on "USB connected".
  3. The "USB connected" screen with the large green Android icon will appear. Tap on "Connect USB storage".
A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 4.0)
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > More... > USB utilities" and tap on "Connect Storage to PC".
  2. Then plug the USB cable into the device and connect to your computer.
  4. A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 2.3)
Jan 09, 2015 | Samsung Cell Phones
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    May 04, 2012 | 1994 Nissan Maxima
    How do i remove the green mode from my pentax e40
    If you press the green button again it cancels green mode.
    If you want to select a different mode press the down arrow on the four way controller when you are in capture mode.
    That has icons for different modes like landscape or program mode.
    Move to the icon you want by using the 4 way controller then press ok.
    The button with a triangle on it that is above the 4 way controller switches between playback and capture modes.
    Jan 30, 2010 | Pentax Optio E40 Digital Camera
    Green mode
    Remove the battery and wait two minutes for the camera to reset. Then reinstall the battery and turn it back on.
    if you still have the problem you will have to take your camera to the repair shop.
    Oct 01, 2009 | Pentax Optio M40 Digital Camera
    Mp780 displays "wrong cartridge"
    Service Mode: EEPROM initialization
    This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
    Service Mode Operations
    1) With the printer powered off, hold down the resume button and press the power button.
    2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The
    indicator will blink in green and remain lit in green.
    3) Select one of the following service mode functions by pressing the resume button the specified number of times.
    Press Resume Indicator Functions
    Zero times Green Power off the printer
    1 time Orange Service test print
    2 times Green EEPROM information print
    3 times Orange EEPROM initialization
    4 times Green Waste ink counter setting
    5 times Orange Destination settings
    6 times Green Print head deep cleaning
    7 times Green CD-R test print
    8 times Orange CD-R print position correction (horizontal)
    9 times Green CD-R print position correction (vertical)
    4) Execute the function you have selected (except for model setting) by pressing the power button. The printer will switch itself off after performing the function.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    May 24, 2009 | Canon PIXMA MP780 All-In-One InkJet...
    Convergence problem
    This is out of the service manual
    don't forget to write the setting to rom by hitting the pip button twice
    Good luck and don't hesitate to ask questions
    2.12.5 Convergence point adjustment
    Adjustment preparation
    (1) Select color to adjust.
    “STATUS” - Green
    “0” - Red
    “ANT” - Blue
    (2) Use 4, 6, 2, and 5 to move the cursor position
    (dotted lines).
    (3) Use thumb stick to move the convergence point.
    (4) Three adjustment modes are available:
    1. (3x3) Press “STATUS” 5 times (only works
    when DCU is in uncorrected state)
    2. (7x5) Press “0” 5 times
    3. (13x9) Press “ANT” 5 times
    For touch-up, only the (13x9) mode is necessary.
    This will adjust every cross-hatch intersection point
    on the screen.
    For complete adjustment, start with (3x3) mode. This
    will adjust center point and eight edge points only,
    but will greatly reduce adjustment time. Then use
    (7x5) mode, and finally (13x9) mode to finish
    convergence.
    If “S” distortion appears between cross-hatch lines
    repeat (7x5) mode to change calculation process
    while adjusting to remove distortion, then return to
    (13x9) mode to finish touch-up convergence.
    Adjustment procedure
    (1) Receive any NTSC signal.
    (2) Start adjustment at the center of the screen.
    (3) Continue adjustment at next closest position.
    (4) Adjust center area first, ending with edge sections.
    (5) Press INFO button to perform calculation operation.
    This process will take about 2 seconds and no
    picture will be seen at this time.
    (6) After interpolation, check convergence again and
    repeat (1)-(5) if necessary.
    (7) When convergence is acceptable, press PIP MODE
    to write data to ROM memory. ROM WRITE? is
    displayed to alarm system that ROM will be
    overwritten with new data. Press the PIP MODE
    button again to write displayed data to ROM.
    (8) DATA WRITE TO ROM will take approximately 4
    seconds and no picture will be displayed.
    (9) Green dots will be displayed when operation is
    completed.
    (10) Press MUTE to return to convergence pattern, then
    confirm again convergence is acceptable.
    (11) Press PIP MODE (ROM WRITE) mode, then press
    PIP CH to initialize sensor data positions.
    (12) Input any 1080I signal.
    (13)Press EXIT key 5 times to exit video mode.
    (14) Select an input with 1080i signal.
    (15)Access menu and select ASPECT 5 mode.
    (16)Press the SERVICE SW. ONLY button to enter to
    DCU crosshatch signal.
    (17)Repeat steps 2~11 above.
    Notes: (1) Display only green for easier adjustment and
    match to jig screen. Press “MENU”, THEN
    PRESS “STATUS”.
    (2) Perform interpolation and data write to ROM
    after green adjustment. Once green has been
    confirmed to match jig screen, the jig screen can
    be removed. Do not readjust the green color
    after jig screen has been removed. This is now
    your reference color.
    (3) Display green and red only and match red to
    green.
    (4) Display all colors and match blue to green and
    red. Touch-up red color if necessary.
    (5) Existing DATA in ROM can be read by pressing
    the SWAP button 2 times. This data can be used
    after replacing a component (CRT, DY, etc.)
    Where complete convergence adjustment is not
    necessary, be careful not to overwrite this data.
    DO NOT write cleared RAM data into ROM or a
    complete convergence adjustment will be
    necessary. Remember to try MAGIC FOCUS
    before starting convergence adjustment to
    minimize adjustment time.
    Feb 01, 2009 | Hitachi 53UDX10B 53" Rear Projection...
    Progressive scan mode
    THis one should be easy--just read it in the manual--reset your video mode by removing any disks from the player, close the drawer, and then press and hold the "stop" button for five seconds. The green power button should flash red and back to green. Hope that solves it.
    Sep 17, 2008 | Cyberhome CH-DVD 300 DVD Player
    Pentax Optio M20
    Found the following on a website about these cameras...
    http://www.digitalcamerainfo.com/content/Pentax-Optio-M20-Digital-Camera-Review/Modes.htm
    "The second, and previously mentioned automatic mode, is the Green mode that restricts the camera controls to two flash settings, three AF options, zoom, and a self-timer setting. This mode locks out the menu systems, manual focus, mode menus and other options. It’s definitely easy to use, as all one can really do is point and shoot."
    This may be a internal software confusion problem. If it is, the following may help.
    Make sure your buttons or dials are not on AUTOMATIC, that appears to set the green mode.
    I think I would remove the batteries. Next, if the camera has a small battery (similar to the bios battery in computers) remove that as well. Let the camera sit over night. You will need enough time for the capacitors to discharge. Then put the batteries in again, and try.
    Jun 30, 2008 | Pentax Optio M20 Digital Camera
    Pentax Optio M30 Digital Camera Logo
    185 people viewed this question
    Top Pentax Cameras Experts
    Greg Cann
    Greg Cann
    Are you a Pentax Camera Expert? Answer questions, earn points and help others
