Question about Sharp LC32D62U 32 in. LCD HDTV
Sharp lc-32d62u tv guide, E202&E203 fix
Any way to get a tv guide on this tv?also having a problem with the E202&E203 on digital channels.any way i can fix these?I am picking up between a 88-92 signal strength just no pic or sound..any help would be greatly appreciated..thanks
The power light blinks green when i plug it in. when i press the power button it doesn't turn on. What can be wrong?
Posted on Feb 16, 2010
I have a non-functional Sharp LC-32D62U (32") TV.
It would be possible if you can go into service menu and write all settings and implement with the new board by going back in and changing what you wrote down.
Feb 17, 2011 | Sharp Aquos LC-32D62U 32 in. HDTV-Ready...
Broadcast fail to show (E202)
U just take ur tv original remote just turn to channel 3?Why is ur cable service connected to channel 3?The proper way to connect to cable service is get the pay cable connected.Take ur original tv remote.Push Menu on ur remote,go to SET UP go down the CH Setup,pick cable,than scan for all the pay cables channels you pay for.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Turned on set....screen all black except a dark blue rectangle in center which reads:Failed to receive broadcast [E202]
That message is presented when a selected digital channel is too weak to decode. Let us hope that something was accidentally changed:
Is the channel legitimate?
Is the antenna/cable still connected (to the Digital input)?
Go into menu - setup - channel setup. Is the selection of either cable or air channels correct for your situation?
Use menu - setup - Antenna Setup-DIGITAL to examine the signal strength. Is there nothing at all, or is it just a question of strength?
Odds favor a change in channel setup that you would not have made intentionally, or a simple physical problem (input cable, etc.). Start from scratch, and check the settings and connections you originally made. Hopefully it will be simple and cheap!
May 22, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Error code e203 tv sharp lc-46sb54u
My sharp manual says E203 means "No broadcast now".
Under possible solution, it says " Check the broadcast time in the program guide".
My manual says nothing else after that.
I hope that helps. Please rate me. :)
Feb 28, 2009 | Sharp LC46SB54U 46 in. LCD TV
Sharp Aquos LC-52D64U LCD-52 wdscrn tht won't scan in digital...
Seeing that you have a superior brand and not getting channels is a bummer. It may have to do with the setting, make sure you're set to cable rather antenna and then do a rescan. Btw, often times channels from an over the antenna is much clearer than from cable because cable tv has to compress the signal. If you're high in the air like the top floor of a building a cheap $10 will pull in great free digital channels. It helps to experiment and read the troubleshooting guide in your manual.
Dec 03, 2008 | Sharp Aqous LC-26D5U Television
I broght a 32 Sharp T.V. 1080P (LC-32D62U)wroks fine. Attached is VCR(RCA) & DVD(GE) works fine except when I record on the VCR. Play back is just snow?
try channel Line 1 or Line 2 on your TV and or VCR... not channel "3" if  you're using "RCA cords".  Also, make sure your VCR and TV are "SETUP" to look for composite input's rather than coaxial.
good luck!
thomseye
May 11, 2008 | Sharp Televison & Video
Sharp LC32D62U 32 in. LCD HDTV Logo
379 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
