Question about Garden
Used a new makita electric chainsaw, cut 5 pieces and stopped
Today it was new and unused and it cut only 5 pieces and no more. I pressed lock-off button & switch trigger and it would not operate.
I have changed the 13A fuse to no avail.
  • 211 Answers
Hi
check the on- off inside with a measure apparat.If needed change it.
regards savumihai71
Posted on Dec 03, 2008
I have a makita electric chainsaw rated at 1800w , do i need a special extension lead ?
I would say not
a normal 10 amp lead should be good enough
what you need is an extension box that has an inbuilt ELB in case you cut the lead or from a power point that has a ELB in the circuit breaker
Apr 12, 2016 | Makita Garden
Husqvarna Chainsaw Chain stopped turning
Have you take the chain brake off..? This is a band which grips the clutch drum and must be disengaged before use.
Check chain tension, this shouldn't be too tight.
Did you also put chain oil in the oil tank.?
Mar 09, 2013 | Husqvarna Garden
McCulloch ES335 electric chainsaw whilst cutting a fallen tree into pieces The saw made a load click like sound when restarted and them the engine run but no movement on the chain. I took off the cover and...
In front of the handle on top of the saw is a hand guard. If in the course of cutting wood you hit it or pushed it forward, it will lock up the chain drive system. It should pull back towards the handle until it again clicks to release the chain. It's designed to lock up the chain drive and stop the chain when the saw kicks back.
Feb 10, 2011 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
How do I adjust the laser on my Makita LS1214fl miter saw.
Make a long cut on a piece of plywood or other scrap and without moving anything (use clamps), adjust the laser to fall on the cut. Hope this helps!
Oct 16, 2010 | Garden
I have a dolmar ps 52 chainsaw keeps cutting out when warm any ideas thanks
Try a new spark plug first. The ignition system may be failing with heat. Try cleaning the engine with compressed air to get rid of accumulated sawdust. Check for muffler for plugging. Make sure the engine 4-strokes at full throttle, but immediately 2-strokes when cutting. Adjust the H needle somewhat to achieve this. Hope this helps
Mar 15, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
All of a sudden it will not run.
Please try to rotate the motor shaft a few degrees (UNPLUGGED) then try a different outlet without an extension cord just to eliminate those possibilities.
Makita 5012B IPL
http://www.ereplacementparts.com/makita-5012b-chainsaw-parts-c-97_98_245_246.html
I see 4 items that could cause this and a possible 5th that is unidentified. Not knowing your level of expertise I suggest if the different outlet does not work you contact Makita for an authorizes repair center near you.
Alternately you might copy the IPL and try a local electric repair service.
If you have more questions you can reply below and I will get back to you. HTH
Lou
Feb 22, 2010 | Makita 5012B Electric Chain Saws
Non-oiling chainsaw
go to an automotive store and get a quart of oil flush. It is usually used to flush out a car engine to remove sludge.
Put some in it, and let it sit for a bit. That will loosen it up. then try running the saw to see if the flush fluid ends up on the chain.
If it does, I would run it for a bit to let the flush run through the workings.
After that you can dump the rest into an empty oil container and recycle as you would your car oil.
Repeat if necessary.
If this does not free it up, manual disassembly and repair of the oiler mechinism may be required.
Jan 10, 2010 | Garden
My electric chain saw makita 5014 is not cutting seems to burn the wood. Can it need sharpening or a new chain. I am a mere woman and don't know too much.:o)
A dull chain can cause this so can installing it backwards. Find a local chainsaw seller/mechanic about 5 - 10$ to sharpen. Ask for their help to relinstall it. Stihl is the best dealer in my area.
fa94627.gif I have many chains when one dulls easy to swap in sharp one, no emergency to sharpen the dull one. HTH
Lou
Mere women are amongst the strongest things on the planet.
Oct 26, 2009 | Makita 5012B 12'' Electric Chain Saw
Makita 5012B chain cannot be tightened
some chainsaws have different knotches where the bar locks onto the saw. loosen the nuts and see if you can move the bar.
Nov 14, 2008 | Makita 5012B 12'' Electric Chain Saw
Garden Logo
113 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
