Question about Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher
Puddle on the floor, 36" diag. SW of Dishwasher door after cycle
I have a DU11000XTPT dishwasher. It is 4 years old. After the dishwasher has run there are two puddles. One small one in front of the sink, that is to the left of the dishwasher. There is a bigger puddle about 3 feet, sw from the left bottom corner of the dishwasher door. The water is brownish. There is no moisture under the kitchen sink or nearer to the dishwasher. There is a tiny bit of water on the center of the lower spray arm. I have cleaned the gasket around the door and inside the bottom of the dishwasher door. There is no debris on the spray arm or around the filter module.Overfill protection float is able to move up and down freely.
    An expert who has written 2 tips or uploaded 1 video tip.
  • 119 Answers
Posted on Jan 31, 2010
Hello! I have an issue with my maytag dishwasher model number MDB6100AWQ. It is running, and it goes to drain, and slowly starts leaking onto my kitchen floor! We took it out about a year ago and...
check the door gasket. check that it is draining. disconnect drain line from under sink ad put into a bucket. most likely it isn't draining ad is overflowing.
Sep 22, 2011 | Maytag Dishwasher
Kitchenaid dishwasher is leaking
depends. take the lower panels off the dishwasher below the door right at the floor. Once this is done you will need a flashlight. If possible lay on the floor with the flashlight and activate the dishwasher. Look for the leak at that point. If it starts leaking in the drain cycle then the impeller is leaking and will need to be replaced. These can be a little pricey so take the model and serial numbers and call an appliance parts house for the cost and it is a little bit of a hassel to replace so only you will know if you want to tackle it yourself or buy a new dishwasher. If is leaking during the rinse cycle then the gasket at the base if the washer (where the motor connects to the dishwasher itself) has gone bad and this is a bugger bear to repair. So it's up to you if you want to repair or replace.
Good luck on repairs Hope I helped you some
Dr Berry
Feb 17, 2010 | Dishwashers
Dishwasher is leaking from under the door
the lower door seals may be damaged or contaminated with old food debris. also check the "n" seal around the door are clean.
Mar 18, 2009 | Frigidaire 24 in. FDBB944C Built-in...
My 12 year old daughter accidentially put dish liquid in my dishwasher instead of dishwasher detergent. What do I do?
Can't see this doing too much harm in the long term.
Biggest problem is likely to be that it will froth a bit.
Suggest you run the machine empty on a "rinse and hold" cycle a couple of times. Stand by with a cloth and bucket, so that if the machine does froth up, you can mop up anything that seeps out before it makes a mess on the floor (watch the waste water outlet at the back as well as the front door.
Question: How on earth did you get your 12 year old daughter to put anything in the dishwasher in the first place - it's all I can do to stop mine leaving dirty crockery in her bed!
Dec 17, 2008 | Dishwashers
Bosch Dishwasher leaking
I had the same problem it turned out that the upper rack was not being pushed back all the way so the door was slightly ajar. If you open the door you should see a bit of water going past the seal If the door is not seating.
Henry in Toronto
Jun 30, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch dishwasher will not drain - causing moldy odor
Hello Mimhoff it depends on how much water is down there. The sump area always has a little water in it to prevent the circulation pump seals from sticking. Usually around 1 to 2 inches. If there is more than that, check the slots at the bottom of the sump on the left side for being clogged and check the end of the drain hose to make sure it is clear. If you are getting a moldy/odor from the dishwasher, try running Dishwasher Magic or Tang thru the dishwasher. This will remove any build up of food or detergent from the dishwasher. If you are running the dishwasher every few days and just scraping your dishes, then either leave the door ajar or run the rinse & hold cycle to help keep the odor down. Bosch doesn't reccommend running bleach thru the dishwasher as this can cause damage to the rubber seals. However 2 tablespoons of bleach once a year won't hurt.
Feb 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
1h (?) signal, and soap dispenser doesn't open
The part called a Wax Motor (about 2 inches) inside the door is responsible for opening your dispenser.Check it / replace it.
Oct 09, 2007 | GE 24 in. Profile PDW7800 Built-in...
Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher Logo
259 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
