Question about HP P4015TN LaserJet Printer with 500 Sheet Input Tray
Laserjet P4015 hi i got a hp laserjet P4015 that keep saying printing i replace the formatter and i still have the same problem any idea thanks
  • 37 Answers
SOURCE: laserjet P4015
Unplug the cord that you are using to print to the machine.(USB, Ethernet). Clear the print que that is going to the machine. Power off then back on machine. Rehook up print cable and try to print again.
Hope this helps
Posted on Dec 04, 2008
  • 50 Answers
SOURCE: Hi My HP Laserjet 5P
Hi
Please find the manual for printer it has troubleshooting tips hope it help
http://72.14.235.132/search?q=cache:Hr7_H4j9T4YJ:www.hylink.com/web/LJ5P-6P-Supplement%2520Service%2520Manual.pdf+LaserJet+5p+Printer+troubleshooting&hl=en&ct=clnk&cd=5
Good Luck
Posted on Jan 18, 2009
leroyal
  • 2120 Answers
SOURCE: Hp laserjet 1200N
C7857-60001
Posted on Jan 23, 2009
  • 108 Answers
SOURCE: HP P1505 LaserJet won't print Acrobat files
I would update to the latest adobe acrobat reader and see if that works.
Posted on Jul 30, 2009
  • 313 Answers
SOURCE: my hp color laserjet 1600 ''incorrect yellow''
did you use a genuine toner cart.........!!!!
Posted on Mar 31, 2010
My hp laserjet 4015 is displaying an error 50.3 after printing smarged copies
Thank you for contacting FixYa with your printer inquiry.
The 50.3 is a fuser Temperature error. If your pages have toner and image but are smudging or smearing you know the fuser is not heating and needs to be replaced.
If your printer is still under warranty contact HP Customer Care for warranty replacement of fuser part numbers: RM1-1082 for 110 volt, RM1-1083 for 220 volt. (888) 999-4747.
If your printer is out of warranty, suggest you purchase a maintenance kit part # CB388A HP maintenance kit for LaserJet P4014 P4015 P4515, includes other needed high wear parts.
Excellent Illustrations:
http://www.printertechs.com/tech/mkinst/P4015/mk-p4015-2fuser.php
Maintenance Kit Contents:
Contents
1. What is included in a LaserJet P4014 P4015 P4515 maintenance kit?
2. Fuser installation.
3. Transfer roller installation.
4. Cassette feed/pickup rollers.
5. Tray 1 (manual feed) pickup rollers/feed rollers.
6. Reset the maintenance count.
Please rate this solution and post a comment if you need additional assistance.
Jan 19, 2011 | HP LaserJet 4350 Printer
Jam in tray 2
This is an update to:
HP LaserJet P4015 - Not Picking Up Paper
HP now recognise this as a manufacturing fault and have released a service note for it and will send you a new fuser free of charge. The description of the fault is:
When a print job is sent to the printer, the printer will display processing job on the control panel, and will continually ramp up and down attempting to print the job. After several minutes the printer will return to ready without posting any error messages. Occasionally, after several minutes the print job will print.
The fix for the fault is:
The fuser needs to be replaced and firmware needs to be upgraded to version 04.060.7 or higher.
The customer will need to download the latest firmware from hp.com, version 4.060.7 or higher. The firmware can be downloaded from hp at "hp.com/go/support" . Select Download drivers and software (and firmware) in step 1 and in step 2 type in the printer name, LJ P4014, LJ P4015 or LJ P4515
It's probably best to update the firmware before you phone HP to report the fault, or at least tell them you have. If you do update the firmware, you will notice some extra numbers and letters on the display when the printer initialises. This is normal, it's probably used by HP staff for diagnosis.
The fuser is a customer replaceable part, and does not require a service technician to install. If the customer requests a service technician to install the fuser the customer will be responsible for the labor. The fuser can be sent directly to the customer with instructions to upgrade their firmware.
What this means is that HP will send you a new fuser to fit yourself.
The models covered by this service note are:
HP LaserJet P4014 Printer series, HP LaserJet P4015 Printer series, HP LaserJet P4510 Printer series.
EFFECTIVE DATES
Start: 2010-01-01
Expiration: 2010-12-31
What this means, is that HP will send you a new fuser for this fault until the end of 2010, although they do sometimes extend the active time period for service notes.
Hope it helps..
Thanks for using fixya......
Nov 08, 2010 | HP LaserJet P4014n Printer
Everytime I try to print it says I have a paper jam. I have completely cleared all paper and it still indicates a jam.
Hi There,
This is a known issue with the
HP Color LaserJet CP 1215 Printer. If your printers formatter is gone bad then you'll have this kind of error with the light status on the printer.
All you need to do is to call the technical support of HP and get the formatter replaced for free if your printer is under warranty.
Hope this solution resolves your issue.
Please vote for me if your issue is resolved.
Thanks
Enjoy and Cheers !!!!
Nov 02, 2010 | HP LaserJet CP1215 Color Printer
Error 49.00ff
Formatter issue. I would attempt a cold reset if that doesn't resolve it then you are going to have to replace the formatter.
How to cold reset a P4015
Turn the machine off
1- Turn the Machine on.
2- Press and Hold The OK button until the memory stops counting and all 3 lights are lit up.
3- Arrow up to cold reset then hit OK to start the reset.
If the machine still comes back to the 49 error after the reset the formatter will need to be replaced.
Oct 21, 2010 | HP LaserJet P4015N Printer
How to solve error 4900ff on hp 4015 printer
The LJ4015 Series printers are the latest upgrade of HP's most reliable LJ4000 series printer. . 49.xx errors are usually firmware, formatter, or sometimes print-job related.
The first step in troubleshooting this error is to isolate the printer from any computer source - disconnect from any I/O ports, Network/USB etc... Power cycle the printer. Does the error still report? If NO then an application may be causing the error, try to isolate the file causing the problem. Clear any pending print jobs. If YES then Firmware/Formatter most are the problem. The newest firmware is version 04.046.2A released in early September.
Critical Firmware Error.
Causes are invalid print commands, corrupt data, invalid operations or even a bad formatter.Power cycle the printer. Press STOP to clear the print job from memory.
Power cycle again. Try printing something from a different software program. If it works, print the job that failed before. If it still fails, repeat the power cycling again and then print something using the failing program but a different file. If it works the file that failed before is corrupt.
If it fails no matter what you print, your printer has a hardware problem and would suggest going to HP for warranty. Try updating the firmware.
Turn the machine off (Remove the Jet Direct Card - Retains IP Address)
  1. Turn the Machine on.
  2. Press and Hold The OK button until the memory stops counting and all 3 lights are lit up.
  3. Arrow up to cold reset then hit OK to start the reset.
If the machine still comes back to the 49 error after the reset the formatter will need to be replaced. Formatter Part Number - CB438-67901 for HP LaserJet P4015x (HP CB511A)
Hope this helps. Please keep us updated and remember to rate this answer.
TF
Oct 04, 2010 | HP LaserJet P4015N Printer
I have a HP laserjet 4015 and it shows a 49ff04 error.
TF
Jun 17, 2010 | HP Laserjet P4015x Printer
We have an error 49.2 F83 come up on our HPLJ 4015n, How do I fix this and what is causing this?
TF
Feb 26, 2010 | HP LaserJet P4015N Printer
HP LaserJet P2014 keeps showing paper jam when there is no paper jam. How to clear?
If paper jam light is solid than checked paper path sensors and toner sensors and if they are aligned correctly than perform cold reset(Keep pressing and holding the green button) if still the issue persists and orange light remains solid than i m sure formatter board is faulty and we need to get formatter board replaced.
Thanks and Regards
Neeraj Sharma
Jul 01, 2009 | HP Office Equipment & Supplies
Laserjet P4015
Hope this helps
Dec 03, 2008 | HP P4015X LaserJet Printer with Automatic...
HP P4015TN LaserJet Printer with 500 Sheet Input Tray Logo
Seeker5211
Seeker5211
