Question about Dryers
Maytag SE1000 Dryer - high pitch buzz, then total non-start
Trouble started with a high pitched buzz from the speaker; then over time it has now stopped the starting of any cycles. Is it just that 1 ''start'' touchpad OR whole board? How much should I replace? This is just the dryer so far. What would that high pitch whine be the signal to?
  • wharbin53 Dec 03, 2008
    So I purchase just the circuit board and replace it? Is there also a way to protect against any future power surges?
  • 525 Answers
Often, after a power surge that exceeds the parameters of surge suppression devices on the circuit board, the unit will do this. You will more than likely have a failed control board now and will need to replace it.
Posted on Dec 03, 2008
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
High pitch squeal-metal on metal contact
A lot of dryers have plastic or felt slides on the drum. This is to reduce friction as it rotates. They are probably worn off.
Dec 24, 2009 | Maytag MDE4806 Electric Dryer
97 f-150 high pitched wine from radio, buzzing behind instruments
If the whine changes pitch with engine RPM it could be a serious problem with the alternator. Possibly the voltage regulator, or a shorted diode in the alternator causing high frequency AC to be fed into the harness.
Oct 09, 2009 | 1997 Ford F150 Regular Cab
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Rca 27410tyx1 will not shut off
Sounds like trouble in the standby/power up circuit. have you tried unplugging the TV for a half hour and seeing what happens? It might start up but I think this problem won't go away. If you heard a high pitched buzzing it sounds like a problem in the high voltage not letting the start up circuit work. threy are related. The start up circuit waits for the high voltage to stablize and then switches it on.
Sep 16, 2008 | RCA TruFlat 27F520T 27" TV
Works - but the sound has changed
Possibly, the "fault" was the buzzing in the first place! Buzzing is usually a cabinet vibration caused by magnetic fields from the "gubbins". If the buzzing should occur again, try pushing/ pulling/ poking the cabinet while the oven is running, you may find a position that causes the buzz to stop.
Another possibility is you previously had something else placed in close proximity to the oven.
If a rattling cabinet is the problem, either try to reposition something, or just ignore it!
Apr 29, 2008 | Maytag MMV4205 Microwave Oven
Alesis M1-Active left speaker emitts a very high pitched wine that sounds like feedback
have your built-in amp checked for trouble. there should be trouble in the output stage feedback loop. this is something to be done by a repair technician
Apr 11, 2008 | Alesis M1-Active MkII Main / Stereo...
High pitch sound from the speakers
Is the noise present even when there is no input?
Jan 27, 2008 | Olevia LT32HVE 32 in. LCD Television
Dryers Logo
129 people viewed this question
Top Dryers Experts
