Question about LG Televison & Video
I have LG DKS-6000 DVD -Karaoke which stop working. Basically it does not turn on.
I want to run lg karaoke files in my pc
type in karaoke fun player they give you free player and karaoke song's just by down loading the religious song with it . free !
Mar 28, 2014 | LG Computers & Internet
When singing the mic has a delay
I had the same problem. How I fixed it I hooked the audio out (red and white) cables direct to my stereo. Seemed to stop the delay.
Feb 16, 2014 | Karaoke USA DV102 - Dv102 Dvd/cdg/mp3g...
Mic won't work at auxiliary mode
On the remote control, there is a blue "Magic Mic" button. Press on that your mic will turn on in any mode.
Just joking but I've been mad about how bad this LG home theater system is. It can only play extremely limited video files and turn off the mic in AUX mode. So the answer is you really can't do that. Buy a mixer instead.
Jan 19, 2013 | LG Audio Players & Recorders
I want to burn a karaeoke disc
The problem isn't the burner. You need karaoke software to burn and view cdg files. Below is a link to free karaoke software. Install the software (or a software package of your choosing) and re-burn your files.
Karaoke Builder
Dec 27, 2011 | LG GSA-H22N DVD±RW Dual Layer Burner
We bought a 2nd hand iktv karaoke system and it came with no CD how do we get a CD? Thanks
Hi ANY KARAOKE CD/CD-G DISK WILL WORK IN THESE UNITS BUT NOT KARAOKE DVDS YOU CAN BUY THEM ON EBAY CLAIRE
Nov 29, 2010 | Tao -IKTV-DVD : DVD Karaoke Entertainment...
My DVD player shows a "00" in each chapter change
Go to settings, Audio options, if your dvd has something called "Semi Karaoke", turn it the %#$% off...
It should do the trick.
That annoyed me for months, until i discovered it, gonna share this with you all
May 12, 2010 | LG HT303SU Theater System
Karaoke not working
Hi, got this info from philips customer service. Was desperately trying to get the karaoke function to work for 2 weeks! Plug in your microphone. Press "KARAOKE" button until you see "MIC OFF" text, and immediately press RIGHT button. It will now shows "MIC ON"! "ECHO", "KEY" options will now shows up when pressing "KARAOKE" button repeatedly. However, microphone sound will not be available on digital output, you'll have to use the audio RCA. Happy singing!
Dec 31, 2009 | Philips Televison & Video
MY KARAOKE MACHINE
I have the same type Caraoke machine that turns on but it does not play the CD....
Apr 30, 2008 | Audiologic DVCR-251
Zenith ZHX-313 DVD/Video Player
I also have this model and it took me a long time to find the solution. It turns out this model is actually an LG.
If you use the instructions for an lg-6000, it worked for me.
Here is a thread I found on another site:
I found a website (http://lgregionfree.tripod.com/) that has a different CD image for LG 6000 series players. I tried that and it works, my player is now set to region 0 and has played region 1, 2 and 4 discs.
Here is the process:
1) Download http://lgregionfree.tripod.com/6000.zip
2) Extract the ZIP file, which contains a Readme file and a directory named RMTM0000
3) Using a CD burning program, burn the RMTM0000 directory to a CDR, making sure to use the ISO9660 file system instead of the default Joliet. Finalize the disc.
3) Turn on the player and insert the disc. The Region Test Menu screen should appear.
4) On the remote, press your desired region (or 0 for regionfree), then press Enter then Pause.
5) Eject the CDR and turn the player off.
6) Turn the player back on and enjoy.
NOTES:
a) I did not need to wait a minute between region selection and pause.
b) On some players this hack causes the buttons on the player itself (not the remote) to stop working. I can confirm that on the XBV443 the player buttons continue to work.
Feb 23, 2008 | Televison & Video
Digix Ht-1056A Chapter Pause Problem
Tu home theater tiene karaoke integrado? Si es as?, ve al menu del aparato, dirigete al submenu audio y apaga (off) la opci?n "Semi Karaoke".
Eso deber?a de resolver tu problema ya que es com?n en algunos modelos LG con karaoke integrado.
Sep 14, 2006 | Digix HT1056A 5.1 Channel DVD-Home Theater...
Televison & Video Logo
362 people viewed this question
Computer Repairing
Computer Repairing
