I have a maxtor basics desktop hard drive and when i plug it in and connect the usb the pc does not recognize it... what's wrong?
  • 46 Answers
Are you attempting to detect new hardware? A lot of times you need to go into the control panel and run the hardware detection wizard.
Alternatively, you can check Maxtor's website and see if a special driver is needed, and install that, then detect hardware.
The last solution I have is to leave it plugged in and reboot your computer. Windows will do an auto detect upon log in, and might be able to find it that way.
Posted on Dec 03, 2008
My pc and laptop not detect my Maxtor OneTouch III Mini External 100GB USB 2.0 Hard Drive R01E100 what can i do please help me soon as possible
Good Day Anantsharma8!
If your PC and Laptop can not detect your external hard drive, I do suggest you check its usb cable. A substitute cable will confirm if your current usb cable is faulty or has an open wire.
Most common reason why the external hard drive is not recognize by PC or Laptop is due to loose connection of the hard disk inside the connectors of the enclosure.
Anantsharma8, if you have a small precision screw, I recommend you open the enclosure of the external hard drive. Remove the front face where usb and power plug connects, then slide it out to expose the hard disk also. You will see two connectors. These are the ones that always loosen. Please disconnect both the connectors and then connect it again properly. Put the hard disk back, close the enclosure and try to connect again with your PC or laptop via usb cable.
Good Luck! I hope that it will soon recognize your external hard drive.
Jun 10, 2011 | Maxtor OneTouch III Mini Edition R01E100...
My maxtor 500gb usb hard drive is not responding when I plug to my pc, so I can't access to any of my file
hello,
-make sure that the cables from the ext hard drive is properly connected like power if there is and USB -try other USB port -try other USB devices -try other USB cable for that Maxtor -try other computer
the reason why you are doing that is to know if the USB port is broken of if the ext hard drive is not responding.
cheers.
Feb 24, 2011 | Maxtor BASICS Personal Storage 3200...
Computer will not recognise external hard drive
Here are a few things to try. If you have access to a secondary PC or laptop, try connecting your drive to it using a different USB cable. Also try unplugging your drive from the power outlet for a few seconds and then connecting it again. If it?s still not being recognized, Maxtor has a free utility called PowerMax (available at www.maxtor.com) that lets you run various tests on your drive till it identifies the problem.
Apr 07, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
USB Memory Key not Recognized on Desktop running Windows Vista
check the formats of the keys. if they are NTFS they might not be recognized by earlier Windows versions. What version of windows does the laptop computer use? It may be as simple as using the correct formatting (FAT or FAT32) on the USB memory key.
Sep 14, 2009 | Maxtor Hard Drive
Maxtor Basics 320 GB external harddrive cant be recognized
There's a good chance the shop you bought the drive from didn't have SP3 installed. For some reason, SP3 has an issue with USB peripheral devices. Windows has created a patch to rectify the problem. Click on the link below and install the "Fixit" patch to enable your PC to recognize your HD. Best of luck.
Greg
http://support.microsoft.com/kb/925196#fixit4me
Jun 18, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Can't access Maxtor Manager on 250GB Maxtor Basics portable USB
ANY WAY I WOULD JUST LIKE TO KNOW WHY U WANT TO USE MAXTOR MANAGER..
IF U JUST WANT TO WORK WITH THE HARD DISK U CAN GO TO DISKMANAGEMENT AND INTIALIZE THE HARD DISK AND IT WORKS NORMAL IF U NEED THE MAXTOR MANAGER JUST TRY TO FIND THE APPROPRIATE ONE FRO THERE SITE WHICH MATCHES YOUR HARD DRIVE MODEL.
GOOD LUCK
Jan 01, 2009 | Computers & Internet
Install a maxtor basic external hard drive
All you have to do is plug in the device into the USB Port, and connect the drives AC Adapter if neccesary. Thats all there is to it. The drive you plug in will show up as a hard drive in My Computer.
Aug 25, 2008 | Computers & Internet
Maxtor and vista
Try some other USB device (memory-stick, printer, camera) in the USB slot in the Vista computer, just to "prove" that Vista will recognize _any_ USB device connected to that slot.
May 31, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
MAXTOR OneTouch III mini edition 100GB
does the hard drive spin up? is there any ticking / grinding sounds from the hard drive? are you plugging it into a different usb port than you were before?
May 01, 2008 | Maxtor Hard Drive
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
