SOURCE: motherboard replacement instructions vaio vgn
IF YOU CHANGE THE MB.. SHOULD THE PCU IS COMPATIBLE WITH THEN MB.. ABOUT THE RAM SHOULD BE COMPATIBLE ALSO...LOOK THE COMPATIBLITY OF YOUR SPESIFICATION OF YOUR SYSTEM.... THE VIDEO GRAPHICS ACTUALLY IS BUILT IN THE MB JUST INSTALL THE RIGHT DRIVER.. ABOUT THE BIOS NO NEED TO RESET.. AFTER THE FIXING THE MB..FORMAT YOU HDD. OR INSTALL NEW ONE NOT OLD.. BECAUSE NEW MB.. IF YOU USE THE OLD OS YOU WILL MEET A LOT OF PROBLEM,, LIKE BLUE SCREENN,, AUTOSHUT OFF,, SOUND NOT WORKING, OR ANY POSIBLE BECAUSE OF FEATURES SOMTIMES.
SOURCE: Sony Vaio VGN-FE770G windows 7 upgrade problems
hello, try the link below;
ftp://download.sony.com/US/pc/TIDMSC-01424702-US.EXE
the driver above is for vista and should work with windows 7.
I hope this helps.
Kind regards,
Amar Sondhi
SOURCE: vaio vgn-sz430n upgrade to Win 7 from Vista
Yea, should not have a problem, but i do believe you will need to get the Nvidia drivers for windows 7. However, that should not be the case, when i did an upgrade I didn't need the drivers, I got them any way, so I will recommend to go to Nvidia website and get the drivers for the video card you have.
SOURCE: my sony vaio (VGN-FS515B) has audio drivers which
Download " Driver Genius pro" from the link below
Just install the software and let it update your drivers, and don't worry about anything just let it download the updates and let it install.
http://rapidshare.com/files/270454654/Driver.Genius.Pro.9.0.0.180_by.tano1221.rar.html
That's it.
SOURCE: Sony VAIO VGN-CR320E Motion eye camera never
Have a look in device manager
Press the Windows key (bottom left of the keyboard} and at the same time press the R key, now in the search box that appears - type devmgmt.msc
have a look under imaging systems click on the + sign and see if you have a Camera listed
Also on Sony they should have supplied an application for the camera
maybe called ArcSoft WebCam Companion - see if you have that program folder - listed at all
