Question about i-mate K-jam Smartphone
Hi actually i had gone to option clear storage n had cleared phone restarted n was askin to follow the instructions n i followed,at last option the asked me to keep a sim paasword n i had ,unfortunately i forgot n my phone is not accepting that password which i had set .what should i do to open my phone
  • 178 Answers
Keep Pressed the Power key, and then press the point where you inset you stylus for soft reset.
Then leave everything.
You PDA shall start formatting (Clear storage).
-Please Rate.
Posted on Dec 25, 2008
  • Mohd. Ismail Ansari
    Mohd. Ismail Ansari Dec 25, 2008
    To perform a hard reset
    1.
    Press and hold the Comm Manager button and Voice Command
    button on the device.
    2.
    Keep the two buttons pressed, and at the same time, use the
    stylus to lightly press and hold the RESET button.
My son put a screenlock on my my touch 3g an dont know what coad he put
Hi
IF you don't know what code he put on your phone.then only one way is left for you.
you have to hard reset this phone means you will loose everything that you have save on your phone.
follow this steps for my touch 3g slide phone
1.turn off your phone.
2.press both volume key.
3. while still pressing the phone turn your phone.
4. you will see the manu for clear storage,revcovery..etc
5. by pressing volume down key select clear storage.
6. press power button to select option.
7 phone will reboot.
done.
thank you.
Sep 09, 2011 | Cell Phones
Hi, phone has been switching itself off lately when im using 3g internet or sat nav etc, would struggle to reboot till i took battery out, it would then fire up. it has just switched off again and i...
You need to perform a hard reset. Unfortunately you will lose all data you have on the device. Please remove your microSD card to salvage the files saved on there after performing the reset.
Follow these instructions:
Hard Reset
  1. Remove the battery and replace it.
  2. Press and hold the Volume Button
  3. Press and hold the Power Button until the phone powers on.
  4. You should see a simple menu showing options such as Fastbook, Recovery, Clear Storage and Simlock.
  5. Using the Volume Down button to navigate, Highlight Clear Storage
  6. Press the Power Button to select Clear Storage
  7. Confirm your decision with Volume Up for Yes. If you feel like backing out, press Volume Down.
This will return your phone to it's original, out-of-the-box condition, software-wise.
If even, after the Hard Reset your phone still reboots, contact your Customer Service department for a warranty replacement.
Jun 03, 2011 | HTC Desire Cell Phone
My daughter has been playing with my Samsung Galaxy phone and tried the pattern too many times, Tis then asked me for my google account details. As i did not have one, i went on line to creat one through...
Unfortunately, you will need to master reset the phone, there is no other way to access it when it is locked in this manner.
Before proceeding I suggest doing a backup of your data stored on the phone's memory. Then power off your device. Hold the Volume Down button and press and release the Power button. A window with some options will be displayed on the screen. You can use the Volume Up/Down buttons to scroll between these options. The following options are present to you on the screen: Fastboot, Recovery, Clear Storage and Simlock. You need to select the Clear Storage option and then click and release the Power button again. The last step of the process is simply confirming your selection, press Volume Up for YES and Volume Down for NO.
Hope this helps
Feb 07, 2011 | Samsung Galaxy S GTI9000 Smartphone
I have forgotten my security code
Please use one of the below Samsung secret codes to format your phone:
There are actually two codes that you can actually use to
reset the password. Below are these codes. Please dial them
up and have the problem solved.
*2767*3855#
*2767*2878#
Through this mean the security code will be reset to 0000.
This will allow you to format the phone easily.
If the problem is same follow another step
Please hard-reset the phone.
Please note that this will erase all data in phone memory and storage memory! It's better to save all your data on a memory card before resetting the phone.
To do hard reset:
Press "Main Menu" > "Settings",
Tap on the "System" Tab,
Tap the "Hard Reset" option,
You can choose the type of memory you want to reset, either Main and Storage Memory.
OR
Just click on "Clear Memory" button to reset the phone completely.
Your phone will be restarted and reset to factory settings.
Hope this helps.
Jan 10, 2011 | Samsung Alias 2 SCH-U750 Cell Phone
How can I do Hard reset my HTC S730 ?
1) Click Start
2) Click Expert
3) Click "Clear storage"
and follow on-screen instructions to reset your phone.
REMEMBER that all of your data will be deleted and the phone returns to factory deafult settings.
That should be all :)
Aug 21, 2009 | HTC FUZE Smartphone
Reset htc740
Resetting your phone will remove all the data from its memory and restore the phone back to the factory default settings.
So, it is recommended that you back up your
data first before resetting your phone.
To reset your phone:
- Click Start > All Programs > Accessories > Clear Storage.
- Follow the on-screen instructions to reset the phone. The phone will restart after it has been reset.
May 20, 2009 | HTC S740 Smartphone
My htc phone got stuck on WINDOWS MOBILE screen. it wont do anything, not even turn off. ive taken out the battery and turn back on, still same thing. what can i do?
Hello, These methods have been confirmed on my phone with both T-Mobile's ROM and Excalibur (S620 original ROM)
Turn the hand-held off, hold the two soft keys (the dashes to the left and right of the phone buttons) hold the power button for 1-2 seconds and then release the soft keys. It should prompt you to clear storage. The “send” button is considered as the green phone button.
Let us know if you have any other questions. If this information was helpful, please take a moment to rate the solution. Thank you.
Apr 18, 2009 | HTC S620 Smartphone
i-mate K-jam Smartphone Logo
89 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
