Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Blurry copies on Workcentre C2424. Tried the solution regarding the encoder on the drive/drum motor. However, now the unit is back together but showing two codes: 04,024.4X & 07, 007.40. Not copying but will print???? HELP.
    President:
  • 2,072 Answers
Both are related to the process control signal. That is the motor assembly on the right side of the machine that is responcible for the movement of the maintenance kit.
You may have something disconnected from it. Or the sensor on the maintenance lift plate is disconnected or knocked out of position. But those coded both relate to the process control motor and gear chain. That is the motor on the right side, toward the front with the gear cluster attached.
Posted on Dec 03, 2008
System error # 07,010.43:27456 on a xerox c2424 copier
The printhead is stuck in the tilt position, need to replace the process motor camshaft kit, part number WCC2424-Z2
http://www.iteminconline.com/wcc2424-z2_wcc2424-z2-xerox-workcentre-c2424-process-motor-camshaft-kit.htm
Jul 07, 2015 | Xerox Office Equipment & Supplies
Workcentre C2424 System Error
That sounds like a problem with what is called the process drive motor. It is the assembly that moves the maintenance kit up and down to clean the drum.
It is located on the front right side of the machine and has a multi gear assembly to it.
It can be mistimed, there are 2 holes and an arrow on the bottom that must be aligned.
For service, to save money. you can contact a service dealer or an ASP in your area that would charge you far less than Xerox. If you don;t know who those service providers are, just let me know what your zip code is and I can look up the nearest ones for you.
May 27, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox workcentre c2424 error code
One of two things most likely.
1. The wiper blade is stuck to the print head,or 2, The print head blosk has a lot of spill over ink built up in it.
That code is caused by the inability of the print head to move properly. Either left to right or pivot front to back to get into the print position.
You have to remove the covers to access the stainless steel print block. It is located about 2/3 of the way back on the lower left side of the frame. It is a one inch by one inch square block that may have a lot of buildup of spill over ink in it. If the wiper is stuck you have to remove the ink loader , where you add the ink sticks , to access the area between the print head and drum, It is a pink blade the is between the drum and print head, it wold be stuck to the print head not allowing it to move. Just carefully unstick it from the print head
Mar 27, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Blurry images
Yeah , that is most likely the problem. If ou remove the right side cover , there is an encoder on the end of the drum motor shaft, It becomes contaminated with the silicon from the maintenance kit.
Fixing it requires you to pop the encoder off and flush it well with alcohol. It is unlikely is has failed, but when dirty is causes the drum to turn at the wrong speed.
Mar 27, 2009 | Xerox Phaser 8550/DP Thermal Printer
Blurry Copies on Xerox WorkCentre C2424
There are three typical reasons for fuzzy text
1. Y-axis drum rotation problem.
2. Wrong drum temperature.
3. X-axis movement problem.
Sometimes the y-axis encoder will get oil inside and confuse the sensors, causing fuzzy/blurry print.
Most likely the drum assembly will need replaced.
Dec 03, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Posted the original problem as Blurry Copies for the Xerox WorkCentre X2424. Did what was suggested which was to clean the encoder with alcohol which is located in the drive/drum motor. Now the unit is...
Have u tried the any of the following?
Clean the Charge Scorotron and the Transfer Corotron
Unlatch Then Relatch the Transfer Unit Below the Xerographic Module
Remove Paper and Other Obstructions From the Paper Path
Use Paper or Other Stock From a Fresh, Unopened ****
Blurry copies
On the drum drive motor there is an encoder, it gets contaminated by the silicon oil in the maintenance kit. Removing it and cleaning it will alcohol will normally resolve that problem.
Sometimes that encoder will need to be replaced. But if you need further instructions, ask, I will let you know what to do.
Nov 26, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox Workcentre C2424
Yeah, That is the process drive assembly.
You have to remove that motor, I think it's 4 torx screws and you have to move a couple of wires etc.
Once you do that, you can turn the upper and lower portions to align the holes in the clear plastic frame with the holes in the gears. I normally pin them with just some papre clips.
Then when installing the assembly back into the machine, make sure the arrows line up on the bottom of the frame and gear.
That should line that up and time it for you.That motor is responsible for driving the maintenance kit up and down to the prep and clean the drum. You may want to be sure your maintenance kit is not somehow binding and throwing that process drive out of timing.
A C2424 does not often have probmes with the maintenance kit binding, but it can occur.
That process drive timing has some problems staying stable.
Oct 23, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
WORKCENTRE C2424
It can be the problem. You want be sure you have the ink cleaned out of that area . The block should slide out easily. Look and see if there is ink laying under the block and also under the waste tray.
The 07,007 code is more from the process control motor. That drives the maintenance kit up and down into position to clean the drum.
if there is ink in that area the maintenance roll with not move properly. Also there are small holes in the process drive motor frame that must align with the holes in the gears for it to work properly.
It is a clear plastic frame, you can also see the holes in the gears which can be pinned with paper clips. When re installing the motor assembly make sure the arrows on the bottom of the assembly align. Its not hard. 4 tors screws and remove the wires running across it. I have seen that gear chain be out of timing a few times.
Aug 02, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
MAINT. KIT
Here is what you need. Its is easily replaced through the maintenance drawer on the right side of the printer Part # spacer.gif Description spacer.gif Capacity2 spacer.gif Price spacer.gif spacer.gif spacer.gif 108R00656 spacer.gif Standard-Capacity Maintenance Kit, Work Centre C2424 spacer.gif Up to 10,000 pages spacer.gif $99.99 spacer.gif spacer.gif spacer.gif 108R00657 spacer.gif Extended-Capacity Maintenance Kit, WorkCentre C2424 spacer.gif Up to 30,000 pages spacer.gif $149.99
Oct 30, 2007 | Xerox C2424 Copier
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
115 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
