Question about NetGear RangeMax Dual-Band Wireless-N Router with 4-Port Ethernet Switch
Dell 630m Ethernet CarD?
I just got virgin internet on my laptop and when i set it up it appeared my default gateway was blank so i rang virgin media and they told me that my ethernet card was out of date or somethingg like that and i need to uninstall and install my ethernet card or update it i asked were i could find the ethernet card he sed he doesnt no so i need to know where it is and how to update , or how to fix my default gateway lol , thanks people
  • James121 Dec 04, 2008
    its ok people
    ive sorted the problem , well not me actually my nan and grandad!! lol ,
    if anyone of you had the same problem just e-mal me or send me a message and al help strayt away thanks
  • 538 Answers
Put 192.168.1.1 default gateway.
Posted on Mar 20, 2009
What do i type in for virginmedia home page
All you want to know about Virgin Media...
http://en.wikipedia.org/wiki/Virgin_Media
May 18, 2014 | Computers & Internet
Tip
How to Share your Internet Connection through laptop's WLAN(Wifi) card?
Every Windows Operating System after Windows 98 can share its Internet Connection using this Technique. Microsoft defines this technique as Internet Connection Sharing (ICS). But setting ICS is very obscure to most of the users. This comes very useful if you live with your roommates and you guys have single internet source like a USB modem Connected to one laptop only. Using Internet Connection Sharing(ICS) that laptop can Broadcast its Internet to other laptops in the room. Technically, the range of a laptop's WLAN adapter is around 20-25 meters. So it can easily handle near by rooms also. This can also be done with a PC having a WLAN card.
To setup and broadcast your internet it is mandatory that you are accessing internet using anything other than Your WLAN card like a USB modem, Ethernet etc. This is because your Wireless adapter(WLAN) will be used for Broadcasting your Internet connection to your friends.
Server laptop:- Laptop with Internet Connection.Client Laptop:- Laptops accessing the internet of server laptop.
Follow the steps to share your internet connection..here it goes:--0b73509.gif
  1. Open the "Control Panel" of the laptop that is accessing Internet and go to "Network and Internet" then "Network and Sharing Center".
  2. On the right side of the "Network and Sharing Center" click the "Change Adapter Settings" and you will see all the available network adapters in your laptop.
  3. Now Right-Click the adapter through which you access internet and click "Properties" option. The properties window will open.
  4. In "properies" Window click the "sharing" tab check "Allow other network user to connect through this computer's Internet connection"97ac799.jpg
  5. In the sharing tab, Select "Home networking connection" type as "Wireless Network Connection" click "OK" and select "Yes" to the Confirmation warning. see above image.
  6. Now Right-Click the "Wireless Network Connection" in "Change Adapter Settings"and Open Its Properties.
  7. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and select the "Use following IP address"
  8. Enter the IP address as "192.168.000.001" and "Subnet mask" as "255.255.255.0"
  9. Leave all other fields blank in Server laptop, which has access to internet.0219162.jpg
  10. Now setup a wireless "ad hoc" computer to computer connection using "setup a new connection or network" in "network and sharing center" and Name it as anything like "Internet_sharing".c2debe7.jpg3a69972.jpg
  11. Now bring other laptops that will use the Shared Internet connection.
  12. Open "Change adapter Setting" (Described in step 2).
  13. In "Change adapter settings" Right-click "wireless Network Adapter" and Click its properties.
  14. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and enter following IP address:-
  15. IP address-"192.168.000.002", Subnet mask "255.255.255.0", Default gateway-"192.168.0.001" and Preferred DNS server: "192.168.000.001".
  16. Use the same step from 11 to 15 to connect other laptops and Increase the IP address by +1. Ex- 192.168.0.3, 192.168.0.4 & so on. Rest of the settings like Default gateway etc will be same on all laptops. Only the server laptop will have blank entries in these settings.
  17. Now connect all the laptop with the Wireless network(ad-hoc) named "Internet-sharing" that you had previously broadcasted in step 10 in server laptop.
  18. Now in the server laptop, disconnect and then reconnect the internet connection(This is a necessary step for Internet Connection sharing(ICS) to work).
  19. Now access internet in all laptops...ENjoy.
Note:- For Advance Users.. this information is necessary only--The IP address of server laptop work as the "Default gateway" and Preferred DNS server of Client laptop and on server laptop these fields are blank. Use same series of IP address as used in the server.
please vote if you found this helpful.. --Abhishek
on Sep 30, 2010 | Computers & Internet
Ps3 connection to internet
Hi friend
These routers practicall has a range of 55 to 65 meters. If your ps3 is within the range then try thses steps or else you need to buy an access point to get the signal from your router to the ps3.
1) click start menu>run? type cmd and hit enter
2) in the black box and type ipconfig/all
3)note the default gateway
4)open the internet explorer and type the default gateway number
5) username is blank(dont type anything) and password is admin
6) click advanced wireless settings
7) change the following settings beacon interval-75
Fragmantation threshold-2306
RTS threshold-2307
8) save settings and turn off the router for 30 secs and then give power
Enjoy
warm regards
Chiranjeet Mitra
Oct 08, 2009 | Linksys WRT610N IEEE 802.3/3u IEEE...
Laptop won't connect to internet
Once connected to the ethernet cable you might have to press the tiny reset button on the back of either your gateway,router,modem of whichever service you have(Cable,DSL)
May 27, 2009 | Dell Latitude C400 Notebook
I cant connect internet through hardwire(ethernet) but i can connect to internet by wireless... and it keeps on telling me Unidentified network.
Not really ...
1 thing that should not be in common between your wireless and modem is GATEWAY...
Your default modem gateway will be 192.168.1.1
change your router gateway to 192.168.2.1 or 192.168.3.1
to do this ...
1. click on start menu , type cmd , enter
2. COMMAND PROMPT dialogue box opens .
3. type . IPCONFIG
3. note your Default gateway.
4. open internet explorer
5. type your default gateway in browser address
6. it will prompt you to give user ID and password .
7 Your USER ID and password is ADMIN .
8. your router setup page opens .
9 change your local IP address to 192.168.3.1 .
10. Check mark on BRIDGING MODE .
11. Disable and enable your ethernet .
12 . now try connecting to INTERNET .
It should work . .
May 22, 2009 | D-Link Vonage-enabled Wireless Router...
Dell inspiron E1505 cannot connect to internet
A hardware error usualy indicated a bad network cable or a bad network card. Have you tried using a different Cable?
Mar 04, 2009 | Dell Inspiron 1501 Notebook
I have Dell laptop inspiron 630m. I formated the laptop then the display driver is missing. Its showing all the things except its display got more wider
just check your video card model, then go online to download the video card driver.
in case you have a build-in-video card like intel .....somethings, just go back dell.com and check your model , and download the video card driver.
Jan 14, 2009 | Dell Inspiron 630M Notebook
Dynex 4 port ethernet router
When the TCP/IP is set to dynamic or "Obtain Automatically", the default gateway is supposed to blank. The default gateway address of your network is actually the router's IP address.
What is the IP address that you get when you performed step 3?
Nov 17, 2008 | Dynex 4-Port Ethernet Broadband Router...
Dell inspiron 1525
check your lan card maybe it is disable, try to enable it
Apr 12, 2008 | Dell Inspiron 6400 Notebook
NetGear RangeMax Dual-Band Wireless-N Router with 4-Port Ethernet Switch Logo
65 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
