Question about Lexmark X4270 All-In-One InkJet Printer
Connecting how can i hook up my x4270 when i have a cable modem for my phone line? do i have to use a splitter at the modem?
    Novelist:
    Champion:
  • 202 Answers
Jon, I am assuming you have DSL modem. Sending a fax by DSL requires one of two methods: 1. You obtain a DSL line filter suitable for connecting a standard voice telephone to the DSL line, then connect an analog fax modem to the line through the line filter. Good Luck, Tim
Posted on Feb 04, 2007
How do i hook up phone line to dsl??
You need to connect the phone line to the DSL splitter... From the DSL splitter you will have 2 RJ11ports. one should be connected to the telephone and another should be connected to the modem....
Jan 28, 2011 | 2wire Computers & Internet
I've recently switched to charter as my providerand they installeda modem ( sbv51220) which works fine, but the monthly charge of five dollars irks me. I bought another modem from Bestbuy at the urging of...
Do you have phone service with Charter as well? If so the modem you have been provided is made to run both the phone service and the internet. If you purchased your own modem from best buy the phone portion would not be present so that is why those connections are not on the new one.
To cut to the point the new modem will work just fine for you internet but bear in mind it will now require another splitter for the coax cable line and each time that you add a splitter you will loose a portion of the incoming signal and this may affect your services.
Thanks,
Robert
Jan 03, 2011 | Arris (SB5101U) Cable Modem
Modem
Your connections are screwed up. Call your cable company for help in getting you straightened out.
Apr 24, 2017 | Telebit Refurbished OPEN BOX EXTERNAL...
I use the RCA model 425 modem through Media Com. My wiring for internet enters a bedroom. Now I also want to hook up a tv using this modem. A Media Com employee suggested using a splitter. Will this work...
Theoretically you can because the purpose your cable serves is a conduit for data transmissions. Just a few cautions here. Just as in any circuit, the more the wire is spliced,split, or anything that taps into it on its way . to the modem will add resistance to the line, thus it could degrade or "slow down" your signal. There is a splitter I know mediacom haves that will help with lessening this effect.
Feb 04, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
My phone line comes through a cable modem. how do i connect
well no promises but this may work
items you will need
2 coaxial cables
3 way coaxial splitter
1 old phone cable you can sacrifice
soldering iron (optional)
solder (optional)
steps,
take a coaxial cable and cut on of the ends off, throw the severed end away and strip the insulation of the coaxial cable (only strip about 3 inches of it away.
seperate the coper (or sliver wire) from the wire center wire and twist toeghter to make a neat wire
strip some of the insulation away from the white center post revealing the coper wire inside
cut end off phone cable and take about 4 inched of insulation away
5
connect the green wire of the phone cable to the copper outter most wire of the coaxial cable and tape it so that there isnt any of the outer most wire showing
6
connect the white wire to the center wire of the coaxial cable and tape so that there isnt any wire showing
7
connect the coaxial/phone cable you just made to the 3 way splitter
8
connect the coaxial line that comes from your house to the splitter
9
connect the other coaxail cable to the last available port on the splitter
10
connect the non-modified coxial line to your modem/router
11
connect the phone cable to the fax
this might work, no promises, i havent tried it, but it might work and is worth a try
Jun 14, 2009 | Brother MFC-5460CN All-In-One InkJet...
Hooking up mx310 all in one
The phone line should plug directly into the Line plug on the DSL modem and the all-in-one should plug into the Phone plug next to it. If you need to split the line do it AFTER the line comes out of the Phone plug.
Feb 21, 2009 | Canon PIXMA MX310 All-In-One Printer
How to connect the telephone lines
Please let the fax line be connected to computer itself do not remove , In the DSL line you get a splitter which the lines for phone and ADSL modem connect the splitter to DSL Line and from the Splitter you 2 o/p ports with phone marking or symbol connect the phone line to it and to line port connect the main 8957and then to ADSL line to ADSL modem from the ADSL modem connect to lan port which is behind the computer (not to dial up modem
i.e is fax line ) or the usb port in the computer ...
Good luck...
Feb 02, 2009 | RCA 25201RE1 Corded Phone
Xbox360 conection to modem
you will need a ethernet cable to connect it to the modem. the modem then needs a DSL cable wihch should connect to splitter in your phone line.
Jan 27, 2009 | Microsoft Xbox 360 Console
Problem connectine fax line to...
First of all what type of phone line r u using ....is it a normal phone leine or DSL....
IF u have a DSL...u need to have a splitter...
If u have normal phone line then connect it directly to printer in the line jack...and from Ext jack to phone...
Check if get on hook dail...ie..see if u can hear the dial tone...
Try sending a fax and if u get a msg "fax Complete " then its working
Jun 20, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
107 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
