Question about Brookstone Micro CD System with MP3 Shelf System
Radio reception This thing sounds great, but the radio receptio is horrible. It has one of those thin wire antennas hanging out the back, several feet long. The wire was originally tightly wound up when the unit arrived. Radio reception was ok, but with a bit of static. I figured that I would unwind the antenna for better reception. Boy was I wrong! The unit is on a shelf. Letting the wire hang off the shelf (vertically) or lay on the shelf (horizontally) results in horrible static, so much so that the radio loses the station. The only solution that I have found is to crumple the antenna up into a little ball...I can at least hear the station then, but alas, the slight static remains. This problem occurs even when the unit is near a window. The station that I'm interested in hearing is at the lower end of the dial, 90.5. It's a 25,000 watt station and I'm only about six miles from the transmitter. I can pick up the station easily with all of the other radios in the house, just not this one. Hopefully, someone can offer some helpful advice. Otherwise, this thing is going back to Brookstone! Thanks in advance...
  • Matthew Clark Feb 19, 2007
  • frmartin493 Apr 22, 2009
    poor radio reception on both AM & FM Stations
    Genius:
  • 1,074 Answers
The wire you use for the antenna is damage replace it or change the set to a other location.
Posted on Feb 25, 2007
I have had a pioneer X-ray p970 f model.. had it for years. However getting radio reception has always been an issue. I live rurally. I would like ABC AM 720. Any ideas. Thani you Susan
A web search for your model turned up a blank. You aren't kidding about having it for years. I'll give you some generic information about AM radio reception and hope you find something useful.
Generally, AM reception is through a wire coil wrapped around a ferrite (very fast magnetic material) rod. Received signal strength is dependent on the angle between the rod and the radio station's transmitter antenna, so rotating it in a horizontal direction (around an imaginary vertical line through the center of the receiver) is often helpful. The angle of the best direction can be affected by nearby equipment (metal appliances, ductwork, computers, etc.)
Many non-portable audio receivers and a few boom box types have both an AM and and FM antenna terminal on the back. The FM antenna is very much like a TV antenna (you can use a TV antenna) and is generally required to get FM reception except in units with a telescoping antenna mounted to the case. The AM antenna is used to augment the coil signal, and is generally needed only if you are trying to pick up a weak signal. Attaching a wire to the AM terminal may help (make sure you have a good electrical connection between the terminal and the metal of the wire). This wire will also have an optimal angle for best reception. Try arranging it vertically; many AM radio stations transmit vertically polarized signals for the benefit of car radio antennas.The longer the wire is, the better, but it doesn't have to be very large. The physical limit is about 110 yards, the practical limit is how much you can stand to have stretched out behind the stereo. (A thin wire going up the wall to the hook behind a picture will probably not attract much attention.)
Portable radios often use a single telescoping antenna for both AM and FM along with the internal coil previously described. If you have this, experiment with antenna position and radio location. I have been told that some early model LED light bulbs may interfere with AM radio reception, especially if they are within a few feet of the radio.
Feb 26, 2018 | Pioneer Audio Players & Recorders
I have a insta - set clock radio model 44200 just open pkg noticed next to electrical cord hole there a small hole and there a 7 inch thin wire hanging out of hole is this extra wire they forgot to cut is...
That's the radio antenna. Just tuck it under the unit or along the back of the shelf or whatever if you get adequate reception. If you don't then you might try fussing with it--taping it up the wall, draping it over a book, that kind of stuff.
Oct 17, 2013 | Equity Time USA Audio Players & Recorders
Very poor FM receptio, and virtually no AM reception
The cascadia has an integrated AM-FM-WX, XM?, and CB antenna system, that is also prone to poor grounding. The best solution is to install aftermarket antenna systems for all of the equipment... I am driving a 2013 Cascadia with quite poor FM, and non existant AM, and WX reception. The XM works. I am afraid to hook up my CB to this, as it is pushing too much power, and is a sideband unit. I would like to hang the engineer by his/her toenails from the nearest tree for comming up with this garbage...
Mar 24, 2012 | Panasonic Car radio CD CQ-C1110GN CD...
Am fm reception bad
FM reception is weak
What to do
• Extend the power cord as much as possible. The FM antenna is in the power cord.
• Move the power cord to adjust the FM antenna
• If you still have problems with FM reception, you may need an external antenna.
* Call Bose®Customer Service to request one.
The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
Cheapest solution next to putting an extension cord on radio power cord.
Jan 03, 2011 | Bose Wave Radio
Poor radio reception with Jensen VM9512 in 2001 Nissan Altima
If you used the 2 plug nissan radio harness, there should be a blue wire on there which is the (power antenna) even if your car doesn't have a power antenna, this wire needs to be connect to power on the am/fm amplified ant which is used in many nissan cars.
if the jensen has a blue or a blue/white wire, connect it to one of those. if not, you can always connect it to the red ACC wire. that should solve your reception problem..
hope this helps
Aug 25, 2009 | Audiovox VM9512 Car DVD Player
Bad reception
Sounds like you have an antenna problem. Find where the antenna plugs into the radio. Unplug it and find a nail or something the same diameter as the center pin wrap about 3-5 turns of a four foot piece of wire around the nail and plug the nail into the antenna input on the radio. If it clears up reception you have a bad or grounded antenna. Follow the antenna wire back to the windshield or fender etc. mounted antenna, sometimes there are other plug in points that get knocked loose.
Jan 12, 2009 | JVC KD-G720 CD Player
JVC detachable face with auxillary input
You may have a bad antenna or antenna cable.
FM signals are measured in microvolts and are easily influenced by poor antennas or a mashed antenna cable.
Aug 12, 2008 | JVC AM FM CD DET FACE CAR STEREO
Better fm reception
Is it just a single wire?
If so, purchase a cheap FM antena. It looks like a "T" when spread out (4' to 5'). That should help.
You can purchase an "amplified" antenna, but if your area reception is really bad (such as in a valley) the antenna would just amplify the noise as well. Look for web based radio in this case or if you have cable there are stations on it.
Jeff
Jan 11, 2008 | GPX HM3817DT Shelf System
GES050 undercounter radio/cd player
..just read about your reception/interference problems and, having lived through similar situations for some time — particularly with different weather conditions. The following solution has settled it all : wrap power cable around storage brackets at back of radio with a short length then wound around support posts (between radio and cupboard from which radio hangs), then run short length to power supply outlet. In my case this result comes after much experimentation with the length of unwapped power cord (including fully unwrapped and stretched out) and different patterns of winding around the support posts. This final result takes care of everything (better sound, no interference/loss-of-reception when moving around in the room or in front of the radio, weather has no effect, stations received that could not be before due to overlap by nearby, more powerful ones). I have only about 2 1/2 feet of cable running from the brackets at back of radio, then wound once around center support and half around right support to then go to wall and down to receptacle close by (I tried all kinds of combinations of unwrapped lengths and winding patterns around 1 to 3 posts)...individual cases may be different. so GOOD LUCK, 'cause the radio is great...!
Oct 26, 2007 | GE 7-5295 Undercounter DC /Radio Combo -...
311 people viewed this question
Top Brookstone Audio Players & Recorders Experts
Jerry Albright
Level 1 Expert
Tom Chichester
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
