Question about LG Electronic Window Air Conditioner
LG window AC turns on and off by itself
We have a LG window unit, about a week ago it started coming on and turning off. We only use it at night, and it just goes off then comes back on. Sometime it may be off for a few minutes and come back on, or goes on and off, on and off. We have tried unpluging it, thinking that may reset something and hitting the breaker button on the cord. Nothing has helped. I go in the room during the day and it will be running. What could be the problem? thanks for your help.
We have had a similar problm and it has ended up being the energy saving light bulbs in the house, when we turn on the light switch on the energy saving bulbs they can send out a similar frequency turning on the ac unit, if you do not have the light bulbs its more than likely a fault in the pc or you have programmed the on/off timer to start the ac? hope this helps
Posted on May 07, 2009
  • 128 Answers
Replace the thermostat is the element starts and stops the cooling( compressor)
or replace the selector switch if all unit is cycling on and off
Posted on Apr 27, 2009
2 Suggested Answers
  • 26 Answers
SOURCE: Last night the frigidare AC with breaker in line
if the breaker reset and the display lights are lit its not the cord sorry to say could be compressor or fan motors.
Posted on May 06, 2010
Ask com lg ac window unit control panel stopped working
Hi Gina, Try turning off the unit at the electrical panel. turn off switch, wait 15 min. turn switch back to on position. Turn on AC unit. Hope this helps.
Oct 21, 2013 | Heating & Cooling
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
Oct 10, 2012 | Dometic Heating & Cooling
My LG portable AC Model #LP1111WXR wouldn't turn off had to unplug it. Now won't turn on.
Unplugging the unit lets the tiny computer like microprocessor reset--means problem is in the brain of the unit or its power circuit.
Jun 14, 2012 | LG 11,000 BTU PortabAir Conditioner -...
2006 Humer H3, Won't start and electrical resets itself
Check the battery terminals real good.Make sure they are clean and tight.Check and see if any of the side terminals are leaking. As far as the blower motor.It is more than likely that the blower motor resistor is bad.It is located by the blower motor.Hope this helps.Good luck.
Dec 18, 2009 | 2006 Hummer H3
Fridgidaire ac window unit
More than likely this unit could be fixed reasonably. It sounds from your explanation like a bad connection inside the control panel of your unit. Could possibly be what is called a cold soldered joint.
Jul 18, 2008 | Frigidaire FAC126P1 wall/window Air...
LD 37LC7D
This set has a modification that needs to be done. It will also start turning on by itself and changing channels rapidly. It's two weeks old. Take it back to the Retailer or if that is not an option contact LG at 1-800-243-0000 to get a local servicer in your area.
Aug 18, 2007 | LG 42LC2D 42 in. LCD HDTV
LG Electronic Window Air Conditioner Logo
1,138 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
