Question about Hotpoint Refrigerators
Installing HOTPOINT FF187EG
What installation guidelines do I have t follow when my bew fridge arrives. Does it have to be left on for a period of time before Ic an use it?
  • yaadwinder_d Dec 03, 2008
    Leading from this - I then need to take my old fridge 15 mins down the road. Can I simply plug-drive-replug in and use straight away or does it have to be switched off for a period of time and same again when turning it back on?
    Thanks again
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
Call 800-ge-cares for specifics, but generally you can use it right away. The unit should pull down to temp in under a half an hour. If you are trading out a working refrigerator do a direct transfer and the cold food will help it pull down. Make sure the new one works before getting rid of the old. Delivery can be brutal and show no signs of damage.
Posted on Dec 03, 2008
  • Joe McG Dec 03, 2008
    If you can transport the old one standing up. If you are going to put it on a pick or trailer have the unit front facing away from the wind so you don't get road debris hitting it, I recommend you using the box off the new as a cover. Make sure the doors are secured with a tie down strap to prevent them from opening during transport. If you do have to lay it down you want let it sit for a while to let the oil return to the compressor.
Where is the thermostat located on the Hotpoint fridge/freezer RSAV21
Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer
? 3:27
www.youtube.com/watch?v=YPglk963cXM
Sep 7, 2012 - Uploaded by Ezee-Fix Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer. Ezee-Fix .... Refrigerator Repair- Replacing ...Missing: rsav21
Free Hotpoint Refrigerator User Manuals ' ManualsOnline.com
kitchen.manualsonline.com > ... > Hotpoint > Kitchen Appliance Hotpoin
Products 1 - 50 of 299 - Hotpoint Top-Freezer Refrigerators Owner's Manual and Installation Instructions 18, 19 .... Hotpoint BL31 Larder Fridge Instructions for Use.
Oct 29, 2015 | Heating & Cooling
How do I find step by step Instructions for installing a nitrous kit in a HEMI and SRT8 6.4 Liter Dodge Charger?
best people are speed shops and engineering shops that specialize in high performance engines. Best advice--- talk a lot and get real advice because if you get it wrong you will be looking at real serious damage to the engine and car.
The engine will have to be specifically built to handle the nitro addition, the nitro should only be used at high rpms and for short periods ( seconds)
Do not believe what you see in the movies as that is not what it is all about.
Jan 23, 2015 | 2012 Dodge Charger SRT8 Sedan 6.4L V8...
I have a hot point fridge freezer ff187eg and there is power getting to it but nothing happening only all the light indicators at the top are flashing please can you help
If the unit is not cooling and the compressor is not starting, replace the relay on the compressor and you should be good to go. Here is a link to that part. GE WR7X225 Relay AppliancePartsPros com
Oct 23, 2014 | Refrigerators
Why is Hotpoint RLA64T Fridge freezing up after new thermostat fitted?
Make sure that the temp probe from the thermostat is located exactly where the old one was. If it had a plastic sleeve on the old one, the new one will need that sleeve. You shouldn't need to calibrate the control if it is the one specified for this model. If it was a generic replacement then possibly it could need some adjustment.
Aug 02, 2014 | Hotpoint Refrigerators
Hotpoint RLA64T fridge freezing up after new thermostat fitted
WHEN U TALK ABOUT THE THERMOSTAT U MEAN THE COLD CONTROL THERMOSTAT OR DEFROST TIMER THERMOSTAT? WHEN UR PROBLEM SOUNDS MORE LIKE THE DEFROST TERMINATOR OR BAD HEATING ELEMENT, LOCATED ON THE FREEZER EVAPORATOR COILS? IF ITS STAYING ON ALL THE TIME U HAVE A DEFROST ISSUE? OR BAD SEALS ON DOOR AND DIRTY COMPRESSOR
Computer beep codes
Installing Memory), and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  • Installing Memory).
  • Memory Installation Guidelines).
  • Replacing the Battery).
  • If the problem persists, contact Dell.
  • 6
    Video BIOS Test Failure
    Contact Dell.
    7
    CPU cache test failure
    Contact Dell.
    Nov 11, 2013 | Dell Computers & Internet
    Calculator calculated (solving for FV) 5 N, 10 I/YR, -2000 PMT, FV= 10,168.06 But the answer should be 12,210.20 Help? :(
    This is happening because your calculator is converting the 10% interest figure into a monthly amount (ie 0.833333%), but it isn't changing the number of periods or the periodic payment into monthly equivalents. In both cases, it is assuming that payments are made at the end of each period.
    So the figure of 10,168.06 is arrived at as follows:
    end of period 1: 2,000.00
    end of period 2: 2,000 x 1.00833333 + 2,000 = 4,016.67
    end of period 3: 4,016.67 x 1.00833333 + 2,000 = 6,050.14
    end of period 4: 6,050.14 x 1.00833333 + 2,000 = 8,100.56
    end of period 5: 8,100.56 x 1.00833333 + 2,000 = 10,168.06
    whereas the figure of 12,210.20 is arrived at as follows:
    end of period 2: 2,000 x 1.1 + 2,000 = 4,200.00
    end of period 3: 4,200 x 1.1 + 2,000 = 6,620.00
    end of period 4: 6,620 x 1.1 + 2,000 = 9,282.00
    end of period 5: 9,282 x 1.1 + 2,000 = 12,210.20
    You will need to find out from your user manual how to stop this from happening, so that all the numbers remain as annual figures. It will involve setting the number of payments per year [P/YR] to 1 instead of 12.
    Sep 06, 2011 | HP 10bII Calculator
    How do we install a burner on a fireplace?
    Thinking of adding a fireplace or wood stove to your home? If so, proper installation and maintenance is absolutely critical to ensuring the fire stays inside your freestanding fireplace or wood stove and doesn't venture outside of it.
    If your manufactured home already has a fireplace or wood stove, it's a good idea to go look over these safety guidelines to confirm that it was installed correctly. If you plan to install a fireplace or wood stove, follow these safety guidelines carefully.
    First, don't try to tackle this project yourself. While installation manuals usually provide all the instructions necessary for a manufactured home owner to install a wood-burning fireplace or wood stove, the consequences of a mistake are so disastrous, it's a task best left to experts.
    It's a good idea to first check with your insurance company for their guidelines before installing these items. Your insurance policy may not cover damages if a fireplace or wood stove was not professionally installed. Plus, the manufacturer's warranty on the fireplace or wood stove may not apply unless the unit is installed by a professional.
    Also can check this ARTICLE for other details.
    Hope helps.
    Jun 02, 2010 | Heating & Cooling
    Refrigerators Logo
    Top Hotpoint Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Sal De
    Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
