Question about Toshiba Computers & Internet
Need driver cd for new laptop
My laptop with Model no. L305-S5908 needs a driver cd for DVD writer ,Lan Card Operation and Wi - FI operation. I could not find reference of this particular model on your site.
    President:
  • 1,073 Answers
Lost wi fi connection to our wireless network, tablet displays "turning off" under the wi fi settings.
I suggest to reinstall the wireless card driver first ..just in case, this will solve any driver issues and will make it functional in case the driver or the setting are corrupted..
To download the driver in case you do not have it on disk or saved somewhere ..just go to acer.com ...select downloads ...drivers and select the model and operation system you use..
download the wifi driver ..run it again ..and after that restart ..and try to make the connection again ...Check the wireless card in device manager to see if it shows in order ...and did not appear in yellow which indicates driver related issues..
also be sure you have network signal ..and the router is functional ..in case other computer is working with this network ..check to see if the connection actually works ..
To redo the connection ..just open the settings for wireless...and click scan for networks ...In the list of available connections ..select yours..and click connect ..insert password if needed.
Good luck !
Nov 14, 2011 | Acer Aspire One Netbook 8.9" Notebook
IBM ThinkPad T40 no LAN or internet connection
Fot that first you need wi fi router with intenret connection .
Then check in your laptop that your wi fi network adapter driver are installed.
Also check its wi fi switch is turn on it is on laptop.
Check your wireless in router is enabled.
also check your wi fi network adapter is enabled in your LAPTOP.
Let me know if you want to configure your router and if you need more assistanse .
thanks.
Aug 26, 2009 | IBM ThinkPad T40 2373 Notebook
WI'll not open in safe mode it displays that unable to enable in safe mode or activate windows in safe mode
In this case the windows is corrupted beyond recovery ..and you have to make a new installation of the operation system or to engage the recovery partition or use the recovery disk if you have such a thing available ...If you do not ,just use a regular bootable disk with the operation system on ...and make a clean install ..after that locate the drivers for it ..from the manufacturer's support site ..sownload them and use them so that your laptop be able to work ..
if you do not have a disk with the drivers..I recommend to make one ..ore store the drivers on a memory unit ..before starting to install the operation system , cause after that you will not be able to connect it to the internet without the Lan card driver..unless you use an external wireless or so ..and have a separate driver for it ..So ..first make sure you download the drivers from here ..
http://support.dell.com/
(select drivers...than model /than operation system ..and download them all just to be sure...For some models there are more than one driver for a device ..cause they use more than one type on a model ..)
after that borrow or buy or make a bootable cd with the operation system ..and go for it ..
Press F12 on boot and select to boot from cd ...and be sure you have the bootable cd inserted ..and confirm the boot from cd by pressing a key (any) when it asks ..and the install process will go on ..
Oct 03, 2011 | Dell Inspiron 1501 Notebook
I have a compaq presario F756nr with an Atheros wireless wi-fi card in it. Can I replace the wi-fi card with a Broadcom 802.11 b/g wireless LAN card?
no you cannot replace the built-in wi-fi card...
if you try to change the drivers for atheros wi-fi to Broadcam driver, your wi-fi card will not function anymore.... but you can always install another WI-FI card in your laptop... you can buy a USB Adapter or a Cardbus(PCMCIA) adapter for this purpose...if you want your wi-fi signal strenth and range to be higher, you can opt to buy an adapter which comes under N standard....N standard wi-fi adapters are capable of connecting at a speed of more than 300mbps(practically) to any N standard device like router....
Mar 29, 2010 | HP Compaq Presario F756NR Notebook
Lan card driver and wi fi driver sd card driver
depending upon the manufacturer of the laptop you can go to their websites, from their you can select drivers and downloads and then select the model no of your laptop and then download the drivers you need.
If you have any further problems please reply with the model no of your laptop and i will send you the link.
Mar 10, 2010 | Computers & Internet
Cannot turn on wireless lan with fn+f2 keys
1. first turn on the "wi-fi/wireless" switch on ur laptop manually.
2. now use the key combination for wi-fi/wireless
3. if it still not working, reinstall the wi-fi/wireless driver again, and restart ur system
Jan 01, 2010 | ASUS F6A-X2 PC Notebook
Driver for extensa 2300 wifi on board .
you can get your extensa wi fi driver from below link.
click here
Then select your operating ssytema nd download driver of wi fi lan.
Let me kow if you need more assistanse.
Thanks.
Sep 17, 2009 | Computers & Internet
Wi-Fi and Lan Network is not working, drivers required.
You can download the drivers from Dell WEB site, the support download page. Make sure you select your model laptop, better still type in the Service Tag number, it is printed on the label on the bottom of the laptop. Also make sure you select the Windows XP version of the driver for your Windows operating system.
Click on this link :-
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Apr 04, 2009 | Dell Vostro 1510 Laptop
XP driver for toshiba Satellite L305-S5908
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2180480&rpn=PSLB8U&modelFilter=L305-S5908&selCategory=3&selFamily=1073768663&selModel=2180480|PSLB8U
Jan 19, 2009 | Toshiba Satellite L305-S5908 Notebook
Computers & Internet Logo
55 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
